Page 7 of 10 1 2 5 6 7 8 9 10
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2634114
03/18/19 04:37 PM
03/18/19 04:37 PM
an8sec70cuda Offline
Gotcha...for some reason I thought you were going to run breathers on the covers.
A better option than the grommets is to weld some -10 male fittings onto the covers.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: an8sec70cuda] #2634900
03/20/19 04:40 PM
03/20/19 04:40 PM
Aubigny, MB Canada
69 F5 R/T Offline
69 F5 R/T  Offline
Aubigny, MB Canada
Lovin the detailed pics showing clearances! That always seems to be the hardest to find......
Bringin Back the Iron!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: 69 F5 R/T] #2636110
03/23/19 08:09 PM
03/23/19 08:09 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
The new grommets came in and work great! I ordered a nice filler cap for the other side from Hughes and am tossing around the idea of doing wrinkle black on the valve covers with an Air Grabber air cleaner and HEMI sticker.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2639490
04/01/19 07:52 AM
04/01/19 07:52 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Valve covers finished! I found this cool filler cap at Hughe's Engines!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2639501
04/01/19 08:30 AM
04/01/19 08:30 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looking good.
69 GTX 68 Road Runner
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2642490
04/07/19 10:04 PM
04/07/19 10:04 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Planning to paint the lid body color with a HEMI decal. Not sure what type of hood will be able to cover this. May have to rethink the intake... confused
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2642549
04/08/19 12:59 AM
04/08/19 12:59 AM
Canada
Cape Offline
Cape  Offline
Canada
What hood are you planning on using? And who makes that air cleaner? Thanks
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Cape] #2642599
04/08/19 08:32 AM
04/08/19 08:32 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I don't know on the hood. Air Cleaner is from PG Classics. I modified a stock one for the 4500. It's a metal base, not fiberglass like others I've seen.
https://pgclassic.com/air-cleaners-air-grabber/
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2642621
04/08/19 09:04 AM
04/08/19 09:04 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'd get a Glasstek hood, with a Sunoco style "scoop/cowl" on it. Here is Larry Boyd's GTX with a Glasstek front and Sunoco hood.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2642648
04/08/19 10:16 AM
04/08/19 10:16 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
That looks AWESOME!
*edit*
Do you have any more pics of that car?
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2642729
04/08/19 12:58 PM
04/08/19 12:58 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Larry's car has just been redone, so not many new pictures are out yet.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2642736
04/08/19 01:12 PM
04/08/19 01:12 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
That GTX is off the hook.
That K&N E-3840 element is on national backorder right now.
I tried 4 times to buy one, not happening lol.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: ZIPPY] #2642802
04/08/19 03:26 PM
04/08/19 03:26 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Summit had it to my door in a couple days???
**edit**
I just checked and they still show it available to ship today.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2643085
04/09/19 06:19 AM
04/09/19 06:19 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Was wondering when those Sunoco's were going to start showing up on mopars………….they look GOOD up
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2643096
04/09/19 07:50 AM
04/09/19 07:50 AM
S.E. Michigan
S.E. Michigan
**edit**
Won't need it for awhile but THANK YOU, I am picking that up. Tried everywhere except there.
Rich H.
Esse Quam Videri
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: ZIPPY] #2647482
04/21/19 08:32 AM
04/21/19 08:32 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I managed to get one side of the exhaust buzzed up. Waiting on a couple bends for the other side. I went under the axle as I mentioned in a separate thread. This is the first time the car has had exhaust past the rear axle in ~20 years... May have to install a stereo if it works out! smoke
Tacked together:
[Linked Image]Untitled by Greg Ault, on Flickr
All buzzed up!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2647556
04/21/19 01:06 PM
04/21/19 01:06 PM
What are you doing to allow the motor to breathe?
I see one outlet with no inlet for breathing confused
I would and do use a PCV on all my non vacuum pump motors to help suck moisture out of them as well as allow the motor to breath when revved up above 3000 RPM shruggy work
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Cab_Burge] #2647985
04/22/19 10:05 PM
04/22/19 10:05 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
PVC valve connected to a Jegs Breather tank on one valve cover.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2651783
05/04/19 05:06 AM
05/04/19 05:06 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I remember seeing a Charger a while back with a Sunoco style hood. Well I just came across it on Facebook, and here it is.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2651784
05/04/19 05:07 AM
05/04/19 05:07 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
