Page 3 of 3 1 2 3
Post deleted by Defbob #585948
01/21/10 12:26 PM
01/21/10 12:26 PM
Re: Hemi problems again.. valve to valve clearance #585949
01/21/10 01:43 PM
01/21/10 01:43 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Bob, hopefully this post has lost steam
I talked to Jack Moore(Moore&Moore) over the weekend at the Columbus swap met. He said, he actually ran as good if not better with an old profile cam(R296) in his 572incher.
I still run a 70's Crane it's been in my last 3 motors. I think maybe that the rate of lift in the older grinds was much more severe at lower lifts and could have caused the valve clearance problems.
my cam card
PART 66R000424 ENGINE TYPE: MECHANICAL ROLLER
SPECIAL
GRINDN R-288/4714-2S-10
ENGINE 1966-1971 PLYMOUTH-DODGE V8 HEMI 426 CU.IN.
(THREE BOLT GEAR)
VALVE SETTING: .026 EXHAUST .026 HOT
INTAKE @ CAM
4714 @
740 ROCKER ARM
INTAKE @ CAM
480 @
730 IN 1.57/EX 1.52 ROCKER ARM
LIFT: EXHAUST @ @
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOS
CAM
OPENS
CLOSES
ADVERTISED
.0162 EXHAUS INTAKE 56.0 BTDC 92.0 ABDC 328 ° °
TAPPET LIFT EXHAUS
98.0 BBDC 54.0 ATDC 332 °
SPRING
RECOMMENDED RPM
RANGE WITH
TRIPLE DUAL OUTER MATCHING
PART
99877 MINIMUM RPM 4500
LOAD CLOSE
220 LBS 2.000 O 2" MAXIMUM RPM 9000
OPEN:
592 LBS 1.320 VALVE FLOAT 9600
CAM
OPENS
CLOSES
MAX LIFT
DURATIO
@ .050 INTAKE
37.0 BTDC 71.0 ABDC 105 ° ATDC 288 °
TAPPET LIFT EXHAUS
79.0 BBDC 33.0 ATDC 115 ° BTDC 292 °
IMPORTANT!
Crane Cams continuously improves and upgrades its cam designs. In some cases this may mean that two
Crane Cams with the same part number may actually be different grinds. You must check the GRIND
NUMBER stamped on the front of the camshaft and check it against the Grind Number near the top of the
Spec Card.
That looks real close to my cam specs..Matter of fact overlap is the same..Its the diff between 110 vs 112 LSA...
I recall the youtube video of the Duster...and wow it sounds killer..
Re: Hemi problems again.. valve to valve clearance #585950
01/21/10 10:17 PM
01/21/10 10:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Fred is that the cam we put in your 588"?
yes not just same grind it was same cam and it was in the 484 " motor when I bought the car back in 1997 then used in the 572 and now your 588" [/quot
Keep in mind Fred you are using Indy Legend heads with the moved exhaust angle and don't have the clearence problem.
Re: Hemi problems again.. valve to valve clearance [Re: B G Racing] #2642022
04/06/19 05:30 PM
04/06/19 05:30 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This was a helpful thread to me many years later, I have .040" measured from the bottom and it seemed
Fine, but I was questioning it.
Thanks for the knowledge shared here.
Zombie thread alert.
Rich H.
Esse Quam Videri
Page 3 of 3 1 2 3
