Bearing Clearance #2641575
04/05/19 01:32 PM
04/05/19 01:32 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
What do guys think of these clearances.
Molnar 3.9 Crank and rods.
Mains with King Race std =.0014
Mains with ACL Race stdX= .0035
Rods with King Race stdX= .0028
Should I go a bit tighter than .0035 on the mains?
Re: Bearing Clearance [Re: RTSE4ME] #2641632
04/05/19 04:10 PM
04/05/19 04:10 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
What are you doing with the build? That will determine how much clearance you want.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Bearing Clearance [Re: DemonDust] #2641653
04/05/19 05:14 PM
04/05/19 05:14 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
High comp N/A bracket race engine
Re: Bearing Clearance [Re: RTSE4ME] #2641680
04/05/19 07:08 PM
04/05/19 07:08 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I wouldn't hesitate going with the .0035 and those rod bearings. The .0014 is fine for stock, but not an engine making big power.
SDG Motorsports
Re: Bearing Clearance [Re: DemonDust] #2641689
04/05/19 07:25 PM
04/05/19 07:25 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Thank you. I was thinking about getting a set of ACL Std and mixing with the StdX.
I will run it as is since am tired of buying bearings.
Re: Bearing Clearance [Re: RTSE4ME] #2641710
04/05/19 08:18 PM
04/05/19 08:18 PM
Get-X Offline
Get-X  Offline
I like to be .002-.003 on mains and .003ish rods in the engines I normally play with. I haven't built a race gen III but imagine they want about the same.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Bearing Clearance [Re: Get-X] #2641841
04/06/19 08:03 AM
04/06/19 08:03 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
I was hoping to get around .0025 on the mains and had King STDX bearings on order for over a month but they are on backorder till June.
Decided to try ACLs.
