Re: new project 1966 Hemi Coronet 500
[Re: DoctorDiff]
#2638412
03/29/19 09:40 AM
03/29/19 09:40 AM
Posts: 3,151 tennessee,usa
mattsmopars
tennessee,usa
Cass, the drivers side control arm on this car, the one that is black painted, I would also assume to be original to the car. The passenger side however is the side that has had the fender replaced and looks like a bump to the wheel. I am going to try to locate the dates on the control arms as I get it on apart. Matt
[Re: mattsmopars]
#2640427
04/02/19 10:03 PM
04/02/19 10:03 PM
mattsmopars
tennessee,usa
Got the suspension apart tonight, the drivers side is original the passenger has been replaced like we suspected. It has the dated rivets, and surprising seems to have a lot of the gold coloring still on it. I will have to be on the look out for a nice passenger side 66/67 lower control arm with sway bar tabs. Matt
[Re: mattsmopars]
#2645843
04/16/19 09:44 PM
04/16/19 09:44 PM
mattsmopars
tennessee,usa
Did a little K frame repair and got the old 383 mount locations off and cleaned up. Now to have the K frame cleaned up and powder coated.
[Re: ScottSmith_Harms]
#2652905
05/07/19 10:10 AM
05/07/19 10:10 AM
mattsmopars
tennessee,usa
The entire leaf spring assembly was dipped in black. They came in natural unpainted as well. You've got plenty of evidence there to show yours were black. Thanks Scott. In your opinion what is the best way to clean them to get them ready to repaint?
[Re: mattsmopars]
#2653144
05/07/19 08:51 PM
05/07/19 08:51 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Disassemble them, use paint stripper to get the remaining paint off. Get a piece of PVC tubing (4" dia or so) cap and glue one end, add spring leaves, soak completely submerged in Evaporust overnight. Remove, rinse with solvent (not water). Buy real zink interleaves and new clamps (Frank Badelson sells them). After assembly clean them well with solvent to remove any oil or grease then make a trough to dip coat them in the paint. A wood box lined with heavy plastic or sprayed in a heavy coat of Flexseal works well, use a gallon or so of cheap gloss enamel paint (tractor supply store) thin with recommended solvent to water like consistency, use wire to hold spring eyes, dip in paint, let them drip dry over a catch cloth or paper.
