Re: Signs of excessive or abnormal bronze gear wear?
[Re: BradH]
#2640213
04/02/19 01:35 PM
04/02/19 01:35 PM
Posts: 4,457 Washington
madscientist
Washington
I've seen tools for installing the bushing, but what's required to remove one from an assembled engine? I thread them and pull them out with a slide hammer when the engine is together. If you do, make damn sure you thread the whole bushing and screw the slide hammer to the bottom of the bushing.,otherwise you just pull the top of it off. And then I say a few cuss words, throw the tool, take a break and start over. That's what works best for me. YMMV
[Re: BradH]
#2640232
04/02/19 02:40 PM
04/02/19 02:40 PM
Posts: 2,059 MD
RTSE4ME
MD
I've seen tools for installing the bushing, but what's required to remove one from an assembled engine? Is the engine installed in the car? I just took off the oil pump. Also had a friend who ran a bronze gear and lost all the teeth after a year of street driving put in a melonized gear. No problems since.
[Re: fast68plymouth]
#2640249
04/02/19 03:10 PM
04/02/19 03:10 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I’d put a few hundred miles on it, then look at the gear again.
The teeth on the cam gear don’t have the nice chamfer on them like cams of days gone by, but at least they don’t have a sharp edge. On another thread you mentioned the older Crane roller I picked up recently came from the era when they were a little nicer to intermediate shaft gears. At the time, it went in one ear and out the other. I just checked my picture, and I get it now. Never gave the cam gear a second thought before. Thanks. From what I can see in the pics, Brad's gear doesn't look horribly bad.
[Re: BradH]
#2640309
04/02/19 05:34 PM
04/02/19 05:34 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I posted the first set of pics to highlight the wear/contact areas in direct light.
These next ones were taken without flash (ambient florescent light), FWIW. I'll bet money that the gear you have is NOT a Milidon or one of the early Mopar brand that had the roll pins installed in them instead of the solid retaining pin yours has ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) The one I'm having trouble with is a early Mopar brand and it has the bright colored roll pin with the ends mashed, the two Milidons I'm using have a black coated colored roll pin in them ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: BradH]
#2640439
04/02/19 10:14 PM
04/02/19 10:14 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I've seen tools for installing the bushing, but what's required to remove one from an assembled engine? From the factory service manual:
[Re: markz528]
#2640474
04/02/19 11:49 PM
04/02/19 11:49 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I bought the tool to remove and reinstall the bushing. One thing most people overlook is to fill the bushing opening with redline synthetic gear oil and squeeze it between your finger and thumb until it oozes out through the pours of the sintered brass. Then press it in and burnish it with the tool.
Another idea is to use the treated steel gear on a new cam. If you can't do that, have the gear cryogenically treated .and coat it with synthetic disc brake grease.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: markz528]
#2640482
04/03/19 12:24 AM
04/03/19 12:24 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
That bushing tool makes me smile every time I have used it.
"Just a Bracket car dressed up like a streetcar"
[Re: BradH]
#2640601
04/03/19 11:43 AM
04/03/19 11:43 AM
madscientist
Washington
Currently looking into sources for both the extraction & installation tools... ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Looks like about $200 +/-, from what I've seen so far. Dig around a bit Brad because I was looking about a year ago for a friend and I found them for about a hundred bucks.
[Re: madscientist]
#2640606
04/03/19 11:48 AM
04/03/19 11:48 AM
Cab_Burge
[Re: BradH]
#2640629
04/03/19 12:35 PM
04/03/19 12:35 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Currently looking into sources for both the extraction & installation tools... ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Looks like about $200 +/-, from what I've seen so far. I changed mine on my small block without pulling the pan. I have a harbor freight bearing puller kit and it worked perfect. My Dad has the install tool so I was able to use that.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2640654
04/03/19 01:41 PM
04/03/19 01:41 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Currently looking into sources for both the extraction & installation tools... scope Looks like about $200 +/-, from what I've seen so far. $100 from Hughes
[Re: Stanton]
#2640724
04/03/19 04:27 PM
04/03/19 04:27 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
$99.00 at Jegs , just over 100 from Summit . Proform brand tool 66488
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BradH]
#2640744
04/03/19 05:21 PM
04/03/19 05:21 PM
BradH
Currently looking into sources for both the extraction & installation tools... ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Looks like about $200 +/-, from what I've seen so far. I should have been more clear and said it was looking like about $200 (give or take) for both tools combined. The HF puller approach looks like a good idea. I found a video on YouTube last night showing someone pulling a bushing w/ a small OTC-brand puller, so I kinda had that idea in mind already. Nice to see that something I can buy 10 minutes from my house will work. I think the installation tool is a better approach than driving in the bushing with an intermediate shaft alone. Seems like not using the tool to stabilize the driver in the distributor opening is more likely to result in the bushing not going in straight, which means the shaft won't be truly parallel to the bushing's inner surface, thus wearing it out faster.
