Re: Paint job on a budget!? CONTINUED..page 44........
[Re: Pool Fixer]
#26418
12/14/06 02:05 PM
12/14/06 02:05 PM
I have stayed at a HIE before, but not last night.
#26419
12/14/06 02:46 PM
12/14/06 02:46 PM
Exit1965,
Are you sure that brightside "has better gloss after wetsanding and polishing"?
I'm not sure brightside "has better gloss after wetsanding and polishing".
I'm certain brightside "has better gloss after wetsanding and polishing".
#26420
12/14/06 04:23 PM
12/14/06 04:23 PM
I am certainly not an expert on paint, but I am about to play one on the internet:) The representative's statement makes only half-sense to me. While there may be parts of the paint formulation that are clear and rise to the top of the Brightside paint when it dries, gloss as I know it is more than a layer of clear paint (sort of an internal clear coat if you will). Gloss to me is how efficiently AND how uniformly a surface reflects the light that shines on it. A "clear" surface can be perfectly efficient in the sense that it allows the layer below it to reflect back all the light that shines on it, but if it has minor imperfections, it will not relect the light back in parallel rays. We will perceive such a surface as wavy or even dull, if the surface is uneven enough. I believe that is what we are seeing with the orange peel in the raw coats of paint - yeah, they are shiny (glossy), but they dont look like mirrors because a roller and the self-leveling process cannot put down a perfectly flat surface. When we wet sand and then polish the surface, we are making it more uniform (more parallel) and giving the paint a chance to reflect the light in more parallel waves. Due to the minor scratches that even the finest polish leaves, the surface may not be as "shiny" as before, but it sure looks better because its reflecting most of the light, in a more uniform manner. In other words, polishing puts in many more minor imperfections than were there, but removes the major ones. Our eyes perceive this as a nicer looking surface because we can see ourselves in it without much distortion, as in the above photo. Whew! I hope that makes sense.
[Re: 69DartGT]
#26422
12/14/06 04:50 PM
12/14/06 04:50 PM
69DartGT - is that paint as bright as it appears on my computer moniter? It almost looks like a cross between orange and red. I have been following this thread with interest and want to paint my 1988 Volvo, which is a maroon sort of color. Looking at the color chips in the hard copy of the color chart I got at the boat store, it sometimes looks to me like it almost matches, but your truck is much brighter looking.
#26424
12/14/06 05:03 PM
12/14/06 05:03 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
Exit1965,
WOW, nobody will believe you used a roller to apply that paint, damm, you got it down pat, awesome job. I wonder if you'll ever consider spraying a car again??
[Re: 69chargeryeehaa]
#26426
12/14/06 05:43 PM
12/14/06 05:43 PM
I know I never will. I have always wanted to paint a car, but never wanted to mess with all the mess of spraying one in my garage, not to mention spending a fortune on a compressor good enough to do a professional job.
When I was a kid building plastic models almost 5 decades ago, I couldn't afford the fancy spray paints, so I used to paint them with a brush, then wet sand to get the brush strokes out. I would do that for as many coats as it took to get it decent looking. If I had only had some 1500 grit wet sand paper, and knew about polish then, I would have been the envy of my model building friends. I still can't believe that almost 50 years later, you have reminded us all of this age-old method for painting, charger.
#26427
12/14/06 05:53 PM
12/14/06 05:53 PM
Any problems with doing this in the outdoors?
Surely dust wont cause problems like with spraying? Im going to start mine soon as soon as I get my new body panels. As others have said can we see some more results pictures, has anyone considered making a website of this?
Ive sprayed once before and I hated it, mess, preparation, fumes and crappy results.
[Re: 69DartGT]
#26429
12/15/06 12:10 PM
12/15/06 12:10 PM
69chargeryeehaa
toronto canada
Question about HVLP spray guns: I understand you set the pressure on these guns depending on make/model to 40-60 psi that said do these guns then cut that down to around 10 psi and if so what kind of overspray do they generate? I'm thinking of using it to get in those hard to reach area's between the cab and the bed.
just use spray bombs, it's much eaiser. HVLP guns put out alot of overspray, and when you cut down the pressure they put out a crappy fan. it would be better if you use one of those "touchup" guns, often you can find them for $20 or so, they do alot better job for just small areas.
#26431
12/15/06 12:45 PM
12/15/06 12:45 PM
Posts: 12,405 Southern, Ca.
69DartGT
moparts member
moparts member
Southern, Ca.
This was taken this morning not much sun yet. Hope it helps but this paint is nowhere maroon.
[Re: 69DartGT]
#26432
12/15/06 02:41 PM
12/15/06 02:41 PM
Thanks Dart. I was hoping to avoid having to do a lot of coats with Rustoleum, and use Brightside instead. I may just pick up a can of Rustoleum Regal Red, which looks to be a close match. Either that, or change the color to one of the easily available Brightside colors and paint the door jambs, trunk and underhood stuff. Although they only imported less than 6,000 of my Volvo 780s into the country, they aren't worth much anyway, so I am not too worried about keeping its original color. By the way I am the webmeister for a site in Atlanta that sells mostly #1 and #2 grade classic muscle cars, including mopars. If you ever want to come and take a look we are at: Atlanta Muscle Car Site Or, if you need a few good pictures of a particular type muscle car, I probably still have it somewhere in my backup files. We have a full time paint and body man (retired) who mostly does buffing and polishing and general repairs,but I haven't told him I am dabbling in this heretical business of trying to paint cars with a roller.
[Re: 69DartGT]
#26434
12/15/06 03:44 PM
12/15/06 03:44 PM
Posts: 8,890 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
how much is that sunburst yellow(quart or a gallon) where can i get some of it would like to test on daughters 73 sattelite road runner clone ralph
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#26436
12/15/06 05:27 PM
12/15/06 05:27 PM
The Sunburst Yellow I showed is a Rustoleum color. About $9 a quart at Home Depot, and $30 a gallon almost anywhere. The full color card is here: RustOleum Gloss Colors
