Page 97 of 159 1 2 95 96 97 98 99 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ #26378
12/03/06 10:47 PM
12/03/06 10:47 PM
YES! Wetsanding is supposed to take away all the gloss.
The purpose of wetsanding is to remove all of the orange peel and other imperfections. You want a uniformly dull surface with no gloss by the time you are finished sanding. Some people even use a squee-gee to remove the water and check for gloss on the sanded surface.
When you get into the polishing phase, you get your gloss back and, if you did your wetsanding properly, you will get a mirror-smooth finish.
Hope this helps.
Re: Paint job on a budget!? CONTINUED..page 44........ #26379
12/03/06 10:48 PM
12/03/06 10:48 PM
My car looked like total crap after wet-sanding it. You can see how the hood looked in the pic on pg 47. That surface wasn't particularly well sanded either.
After a 'good' wet-sanding the paint should be totally matt and as smooth as a babies butt. Then it will polish up to a mirror reflection provided you polish it properly.
Re: Paint job on a budget!? CONTINUED..page 44............ #26380
12/03/06 11:15 PM
12/03/06 11:15 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
Wouldn't that only work w/ single stage paint?
I didn't know that solvents could affect paints that have a catalyst/hardener. Was it laquer? You said 1962 original paint?
Last night I was watching "Classic Car Restoration" on DIY network; they were restoring a 1962 T-Bird. Anyway, they were planning to colorsand and polish the original paint. Before they did so they did some tests on a couple of fenders that had been painted more recently.
Kevin Tetz did a demonstration to ascertain whether the paint on the fenders had hardened sufficiently to polish. His simple test was to put some solvent on a clean white cloth and lightly rub it across the surface of the paint. If the rag came up with color on it that indicated that the paint had not hardened, if it came up clean (i.e. the solvent wasn't able to cause the paint to get wet again).
This technique may be useful for determining when our roller jobs using Rustoleum are ready for polishing. I guess we'd use mineral spirits as a solvent.
Anyone else ever heard of this?
Re: Paint job on a budget!? CONTINUED..page 44............ #26381
12/05/06 12:03 PM
12/05/06 12:03 PM
I saw this too but that's not what I gathered. I understood them to be testing for the type of paint and whether or not it was clear coated. This determined whether they could color sand and polish. If I remember right they were checking for:
1. Clear coat
2. Enamel paint
3. Laquer paint
Re: Paint job on a budget!? CONTINUED..page 44........ #26382
12/08/06 01:31 AM
12/08/06 01:31 AM
Since painting/detailing my car has stopped for a while, I decided to play with my track bootlid and rear wing. They used to be white. I have given the thing two coats of the Brightside and that pic was taken just after the second coat had finished drying.
Re: Paint job on a budget!? CONTINUED..page 44........ #26383
12/08/06 09:20 AM
12/08/06 09:20 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Steve looks great you used Mineral Spirits to thin right, what ratio approx and this is before sanding. I'm doing the final sanding on my truck and could start rolling late today or tomorrow.
Interior finished up yesterday. looks better in person then the picture.
Tom
Re: Paint job on a budget!? CONTINUED..page 44........ #26384
12/08/06 10:57 AM
12/08/06 10:57 AM
^^ Nice work, but I thought your just gonna get everything resprayed?
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26385
12/08/06 01:37 PM
12/08/06 01:37 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Ready for paint, looks like heck but smooth to the hand. I'll give it a mineral spirits wipe down and tack rag just before I put the first coat on.
Re: Paint job on a budget!? CONTINUED..page 44........ #26386
12/08/06 04:30 PM
12/08/06 04:30 PM
Nope, I'm probably the only guy on the planet dumb enough to say no to a free re-spray.
I have put so much work into learning and practicing my roller painting that I feel like I'm being cheated because of that accident.
I know that it's not rational but most of my pride in my car has come from me doing work on it myself. I have built/installed/tuned a Megasquirt ECU and I was the fourth person on the planet getting the Megasquirt working for fuel and spark on a Miata. I want to be the first person on the planet who has the perfect roller paint job on a Miata.
Half of the fun of this for me is achieving something that no-one else thought could be possible. So there is no way that I'll re-spray.
Tom, I used a 10:1 mixture of paint to mineral spirits on the bootlid. That lid does have a few minor dents in it and the area near the wing supports isn't very flat either, but since this thing is only for the track, I haven't been as anal as I have been with the rest of my car.
Re: Paint job on a budget!? CONTINUED..page 44........ #26387
12/09/06 01:16 AM
12/09/06 01:16 AM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: kenzo42] #26388
12/09/06 03:47 PM
12/09/06 03:47 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Well took just under a quart to do the truck, I thinned using mineral spirits paint is Interlux Brightside. I used a 4" foam roller and used a 3" foam brush to knock down the air bubbles, but when I did the hood the bubbles were going away by their selves so I stopped with the foam brish tipping BIG mistake so I'll need to down some wet sanding before the second coat. One thing I'll say is the gloss is there
I'm told don't panic during the first coat :thinking I'll let this sit until Monday then I'll sand and apply the second coat.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26389
12/09/06 04:18 PM
12/09/06 04:18 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
BTW speaking of air bubbles what works best to minimize them?
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26390
12/09/06 04:55 PM
12/09/06 04:55 PM
Your truck is looking awesome already. I can't believe the difference from your 'preped' photos to your first coat photos. The coverage with the Brightside is fantastic.
When I do my painting I have a clean second 4" roller that I run over each 'finished' panel to remove all of the air bubbles. I don't use any weight with the second roller, I just gently and slowly move it across the panel and it ends up looking really good (at least until all of the dust and dog hairs etc start landing on the paint).
Re: Paint job on a budget!? CONTINUED..page 44........ #26391
12/09/06 05:12 PM
12/09/06 05:12 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Steve thanks I do have a spare foam roller I'll give that a try on coat two.
I may have put the paint on to heavy in a couple of places and that didn't help the bubble problem either.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26392
12/09/06 05:29 PM
12/09/06 05:29 PM
Yeah Tom, I found the same thing with the Brightside. It seems to get to a point where there can be too much paint on a panel and then it just doesn't settle properly at all.
Then to fix it, I've had to sand most of it back off to get it smooth again...
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26393
12/09/06 06:46 PM
12/09/06 06:46 PM
toronto canada
69chargeryeehaa Offline OP
toronto canada
best thing to get rid of bubbles for me was to either blow on them (careful you don't spit on the car!!!! lol) or just before you load up your roller for more paint just use the weight of the roller only, and really really gently roll over the surface, you can feel when the time is right; when the roller glides over the surface without sounding like the paint is still wet, mind you this is when using the tremclad/rustoleum paint not the stuff your using so i dunno, try it?
awesome job by the way, please tell me your doing that inside????
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26394
12/09/06 07:17 PM
12/09/06 07:17 PM
St Andrews ,Manitoba ,Canada
C38coupe Offline
C38coupe  Offline
That looks great, and the Red suits the truck. Now I am jealous, the first coat looks great, the 2nd and polishing will really make the paint.Plus I see Fan Palm trees in the background and green grass in December, that makes me jealous too....Fred
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: C38coupe] #26395
12/09/06 07:41 PM
12/09/06 07:41 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Yeah I'm just a few miles north of Mexico and 5 miles off the Pacific ocean, it was really nice when I painted right at 70 I was surprised how fast the paint dried to touch. Could be some of the reason for the air bubbles.
And it was painted right where it sits..
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26396
12/10/06 09:43 AM
12/10/06 09:43 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
When I was rolling brightside, I would go over it once with the loaded roller, then come back in 5-10 minutes (when it was convenient) and roll over it again without adding any paint. Most of the bubbles were gone on their own at that point, but if not, that would get them and would also highlight any runs that needed to be rolled out.
The trucks looking great!
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26397
12/10/06 03:01 PM
12/10/06 03:01 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
I'm using the foam rollers from home depot but it was suggested that a short nap roller works better then the foam but to be sure you buy the good ones so the hair doesn't come off.
Any comments?
