Re: Signs of excessive or abnormal bronze gear wear?
[Re: BradH]
#2640000
04/02/19 12:13 AM
04/02/19 12:13 AM
BradH
Slightly different view of cam gear.
[Re: BradH]
#2640001
04/02/19 12:20 AM
04/02/19 12:20 AM
BradH
Bronze gear wear pattern from one direction of rotation...
[Re: BradH]
#2640003
04/02/19 12:24 AM
04/02/19 12:24 AM
BradH
Bronze gear wear pattern from the other direction...
[Re: BradH]
#2640067
04/02/19 08:49 AM
04/02/19 08:49 AM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I don't like the looks of the wear in the bushing.
[Re: Stanton]
#2640102
04/02/19 09:46 AM
04/02/19 09:46 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d put a few hundred miles on it, then look at the gear again.
The teeth on the cam gear don’t have the nice chamfer on them like cams of days gone by, but at least they don’t have a sharp edge.
[Re: lewtot184]
#2640129
04/02/19 10:48 AM
04/02/19 10:48 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I always compare the gear wear to the inside most area of the teeth. I noticed some weird gear wear on my small block on this last inspection and when I put it in the block to check how much slop it had it turns out the bushing in the block was shot. It hadn't been in very long but it was very worn so I changed it and put another gear I had in. I have always just dropped the gear in and never checked that bushing, I am glad I noticed it before it chewed up another gear. bushings can be a big issue. I've got a bunch of new ones that are too loose to use. That could be the issue I have. The new bushing i put in went in easy and the install tool was easy to pull out.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2640134
04/02/19 10:59 AM
04/02/19 10:59 AM
Posts: 1,319 Ohio
jlatessa
Ohio
Looks as if the gear meshing forces are pushing the intermediate shaft forward.
Could the geometry of the cam or shaft gear be off somehow?? Was the oil pump allowed to find it's alignment with the shaft before tightening??
Just thinking out loud...
Joe
PS, if the intermediate shaft gear was pinned to the shaft a little high or low?? Can you measure and compare?
[Re: second 70]
#2640145
04/02/19 11:24 AM
04/02/19 11:24 AM
BradH
Brad here’s one I pulled out of the hemi after a couple years. Hard to see but it was slowly wearing into the teeth. You can see how the what I call edge is worn from looking down from top. The edges are very sharp and there’s a little burr on the bottom edge. This is a solid roller with a melling HV pump. I changed to a melonized gear from Hughes a couple of years ago and pulled it out last fall and it and the cam showed zero wear. I know they say never use on a used cam but never say never I’ve didn’t have any problems. Cam gear and the melonized gear holding up, despite going against two of the warnings for using the melonized gear?
[Re: BradH]
#2640148
04/02/19 11:27 AM
04/02/19 11:27 AM
Posts: 1,319 Ohio
jlatessa
Ohio
As long as you have the gear out, check the cam's forward movement once more to see if the cam button is holding the right clearance.
Joe
[Re: second 70]
#2640174
04/02/19 12:23 PM
04/02/19 12:23 PM
Posts: 4,457 Washington
madscientist
Washington
Hey Brad...I think there was a thread over on ST several years ago by now where a guy was having issues with gear wear and they eventually found the gear on the cam was ground incorrectly. That's IF my memory isn't jacked up. May be worth a search over there just to verify what I recall.
Also, you can change the bushing without a taking it apart. The best bet for that bushing is to just eat the money for the correct bushing tool and buy the undersized bushing. The tool then installs the bushing and sizes the I.D. at the same time and you don't have to worry about the bushing being loose. I fought that for awhile. Then I bought the tool and stopped using the pre-sized bushings.
