Front Frame Rail Splash Guard Rivet #2638721
03/30/19 08:50 AM
03/30/19 08:50 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
It's time for me to install my frame rail splash guards on my Duster. Does anybody know the size of the original rivets? Unfortunately, I didn't keep the pieces of my originals when I remived them.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Front Frame Rail Splash Guard Rivet [Re: FJR doc] #2638725
03/30/19 09:07 AM
03/30/19 09:07 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
They were sheet metal screws with heads like a bolt. You have to remove them every now and again
Re: Front Frame Rail Splash Guard Rivet [Re: 71birdJ68] #2638731
03/30/19 09:22 AM
03/30/19 09:22 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
1970 used rivets. 3/16" large head.
71-up used screws.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Front Frame Rail Splash Guard Rivet [Re: moparmarks] #2639080
03/31/19 08:26 AM
03/31/19 08:26 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Thanks mopamarks.
Kevin
Re: Front Frame Rail Splash Guard Rivet [Re: FJR doc] #2639094
03/31/19 09:11 AM
03/31/19 09:11 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have 4 of these I bought and never needed.
Re: Front Frame Rail Splash Guard Rivet [Re: moparmarks] #2639103
03/31/19 09:44 AM
03/31/19 09:44 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
71-up used screws.
Hey Mark would you have one of those old screws rolling around or a picture and size? I need to find the size and maybe get some accurate ones for my own 71 Challenger. Some pulled those off long before I bought the car frown
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Front Frame Rail Splash Guard Rivet [Re: 71TA] #2639110
03/31/19 09:58 AM
03/31/19 09:58 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I had to buy some for my car, I think I got them from RT Specialities
Re: Front Frame Rail Splash Guard Rivet [Re: 71birdJ68] #2639116
03/31/19 10:03 AM
03/31/19 10:03 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Thanks. I see them on Toms (RT's) site!
So were rivets used till 1970 and then screws from 71 on all models?
Re: Front Frame Rail Splash Guard Rivet [Re: 71TA] #2639583
04/01/19 11:07 AM
04/01/19 11:07 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think some earlier than 1970 cars used screws as well.
the 65 - maybe 66 shields were metal and they used screws I know
Btw, the screw is the same screw used to attach the rear axle to frame bumper and E body exhaust heat shields
EDIT ;
picture I found on the net
Re: Front Frame Rail Splash Guard Rivet [Re: gtx6970] #2647580
04/21/19 03:49 PM
04/21/19 03:49 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Dug this off my own 71 Challenger. Must have been a bad day "on the line" was only ONE of these holding my plastic t-bar splash shields on.
Looks like 1/4 x 7/8 Type AB (AB is the pointy tip and fine threads) 7/16 hex head 5/8 washer
Re: Front Frame Rail Splash Guard Rivet [Re: 71TA] #2647581
04/21/19 04:06 PM
04/21/19 04:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Got a better pic of the head markings ?
Re: Front Frame Rail Splash Guard Rivet [Re: gtx6970] #2647598
04/21/19 06:23 PM
04/21/19 06:23 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
You can kinda see them in the picture. I cleaned the head off to see if AMK had anything like that but they didn't. They are just 2 equal signs (=). one on each side.
Re: Front Frame Rail Splash Guard Rivet [Re: gtx6970] #2648278
04/23/19 08:45 PM
04/23/19 08:45 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
I own a 71 charger that has rivets no screws.
Re: Front Frame Rail Splash Guard Rivet [Re: 340cpe] #2648285
04/23/19 09:23 PM
04/23/19 09:23 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Thanks for the info.
