Re: Moroso underdrive pulley on the street?
[Re: BradH]
#2637875
03/27/19 09:02 PM
03/27/19 09:02 PM
Posts: 4,210 New York
polyspheric
New York
With your high RM cruising speed you wouldn't even be slowing the accessories down to what a modern system would have. I'd try it.
Boffin Emeritus
[Re: BradH]
#2637941
03/28/19 01:00 AM
03/28/19 01:00 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I run an electric water pump but I have had zero charging issues with a 5" pulley on my car. GM CS130 alternator, two electric fuel pumps, electric water pump, two electric fans, fuel cooler fan, Fuel Injection, street car. It can still keep up with the lights and wipers on as well.
68 Barracuda Formula S 340
[Re: BradH]
#2637962
03/28/19 07:45 AM
03/28/19 07:45 AM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
I'm using one. The nicer dark blue billet style they discontinued (they didn't make them for very long...they're not easy to find...so I collect them, so far have only found two). You will probably be fine as long as you don't experiment with additional electric accessories. The charging system will be at it's limit with what little draw it has. Idle with the headlights on is pushing it. I use the same 5 blade fan, but went to a much tighter RV clutch due to low speed cooling concerns. (not verified problems...just concerns). I'm not 100% sure if the loose/power saving MP fan clutch (6 cylinder van application if I remember correctly?) will be adequate for you when spun at lower rpm. I think it will probably be fine but that is something to keep an eye on. Overall I'd say you are probably good to go.....but....."it depends" "You have to test on your specific combination and...." You already know the rest
[Re: ZIPPY]
#2637981
03/28/19 08:57 AM
03/28/19 08:57 AM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Imho, on the street, if you have enough motor, the power freed up by a pully swap will be too insignificant to notice. If you're not blowing away the tires, your motor is too small and the pulley won't change that.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2638032
03/28/19 11:16 AM
03/28/19 11:16 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Brad - I tried an underdrive pulley on my old 63 4 door w the 512" and I did not have success with cooling. It had a stock BB radiator, flex fan w/shroud and it could not keep up. I switched back to stock pulley and cooling issues went away. Matter of fact, I realized the cooling issues when I was driving to the track. Part way there I pulled over to let it cool down and then limped it back home. I never did get to find out what it was worth on the timeslip. It might have worked with a better cooling system, who knows.
2 kids and a dog
[Re: BradH]
#2638095
03/28/19 01:36 PM
03/28/19 01:36 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I used to run the same setup on my 14:1 compression 446" wedge on the street w/ no trouble at all. Stock clutch fan, water pump, and alternator w/ a Moroso underdrive crank pulley.
[Re: Hemi_Joel]
#2638130
03/28/19 03:19 PM
03/28/19 03:19 PM
BradH
Imho, on the street, if you have enough motor, the power freed up by a pully swap will be too insignificant to notice. If you're not blowing away the tires, your motor is too small and the pulley won't change that. Not sure where you're coming from with those comments. I haven't been worried about whether my car hooks on the street for 30+ years, since it's been that long since I street raced. My concern with using the car on public roads is purely whether the pulley change is likely to cause a charging and/or cooling problem. BTW, on any decent track where I hook up, my car is traditionally very consistent, which is why it's been a good test bed to see what helps the car's ET & MPH. The crank pulley tests Dwayne Porter ran & posted years ago showed a Moroso underdrive pulley picked up about 10 HP at peak over an OEM pulley on a 500+ HP 383 he built. If I picked up 10 HP from a pulley swap on a 650+ HP 440, it would definitely show up on the ET slip.
[Re: BradH]
#2638405
03/29/19 09:24 AM
03/29/19 09:24 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
We ran.run I still do March underdrives.My radical 440 runs under 190 all day with 22 inch rad.was stock now cheap Champion aluminum.My son ran the same with stock rad in his 62 300 and it also ran under 190 all day even in the 90s.never a problem charging or with temps.Ive run mine at least 20 years.My son een drove 40 miles to thetrack and back to race his 62.Rocky
Chrysler Firepower
[Re: therocks]
#2638446
03/29/19 12:11 PM
03/29/19 12:11 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I run the March underdrive set, no cooling issues, but at ~850 rpm idle I can sometimes overtax the charging system. even with the mini denso setup. But I've got elec fuel pump, elec fan, bottle heater...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
