Hole in new timing gear !!
#263619
03/23/09 05:32 PM
03/23/09 05:32 PM
Posts: 188 Murrayville, Illinois, usa
scotts66charger
I am replacing an old timing chain and gear set, with a new Edelbrock doub;e roller set. the old gear(Cam gear) has a off centered hole in it, and then new one does not. The hole in the old one, is drilled at an "Angle" not straight through like a drill press would be able to do. My question is, Is the hole maybe for " Oiling" something, and if so, do I need to have a hole drilled in the new one to match ? thanx. scott
Re: Hole in new timing gear !!
[Re: scotts66charger]
#263622
03/24/09 06:44 AM
03/24/09 06:44 AM
Posts: 10,777 North Dakota
6PakBee
North Dakota
You have to have a hole in the cam gear for the locating dowel on a B/RB camshaft nose. Something doesn't sound right here.
[Re: aarcuda]
#263624
03/24/09 01:16 PM
03/24/09 01:16 PM
Are you sure it's not an adjustable, offset, advance/retard sprocket? (They are NOT 'gears')
#263625
03/24/09 01:21 PM
03/24/09 01:21 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
That hole is for lubrication to the back of the gear.
[Re: 6PakBee]
#263627
03/24/09 03:44 PM
03/24/09 03:44 PM
RapidRobert
Certainly not for balance, not for (rear side of chain) oiling as the oil drips from the rear(oiling hole) and from the cam bearing as mentioned. I havent seen a pic but I dont know if it's to sling oil forward to the eccentric (which is sorely needed) but it's an extra machining step thats incorporated in there for a good reason(time is money) & money is #1. Wouldn't make sense that they are hung on pegs as they are on the assembly line.
[Re: RapidRobert]
#263630
03/24/09 04:21 PM
03/24/09 04:21 PM
Posts: 15,487 Florida
scratchnfotraction
I could be wrong I dont do BB I am going by what I read for a gear drive for a BB said it need a 3 bolt cam and some are listed as a one bolt I have seen some with the dowl pin in the end of the cam aslo so.... we need pics...this post is worthless with no pics ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: John_Kunkel]
#263638
03/26/09 08:28 AM
03/26/09 08:28 AM
scratchnfotraction
yep, I would say for t-chain oiling I got the pics th op sent me,and was thinking ![](/ubbthreads/images/graemlins/iagree.gif) with snoopy the drill bit gives a clear veiw of the angle,which I could not see in the op pics ![](/ubbthreads/images/graemlins/popcrn.gif)
