Re: 518 TRANSMISSION A-Body Install, Need Help
[Re: formula S]
#2636242
03/24/19 02:58 AM
03/24/19 02:58 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
The best advice I can give you is to use a GM200R4 from Extreme Automatics instead. They consume a significantly less amount of your precious HP, and are substantially smaller = no floor cutting. You will need to use the US Cartool kit to make the torsion bar cross member cut, which you will be doing anyway. Besides, they are much stronger and have better gear ratios.
Or, put that old, patched 727 w/OD added on the back A.K.A 518 in it, and hack your floor too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2637392
03/26/19 03:08 PM
03/26/19 03:08 PM
Posts: 861 lancaster,california
johnnycuda
I used the A500 in my '69 Valiant behind the 408, the tunnel itself did not have to be cut, the section of the crossmember that went up and over the trans, had to be removed, and we made a flatter version in it's place. Of course the trans mount/crossmember had to be custom made. I don't plan on racing it much, if at all, so the A500 should hold up, I had Darren at ProTrans build it.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: BigBlockMopar]
#2637923
03/27/19 11:30 PM
03/27/19 11:30 PM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
I installed a 518 behind my 6.4 Hemi. Reverse manual with trans brake and lock up torque converter.
