Need Help with Correct Spare Tire Setup for 1970 Charger
#2633379
03/16/19 03:03 PM
03/16/19 03:03 PM
Posts: 581 Texas
Texican
Texas
I need help determining the correct (full-size) spare tire setup for my 70 Charger R/T.
When searching for the hold down / bolt, wing nut, etc... there are several options and I don't want to throw money away (like I've done sooo many times).
I'd like to know the correct setup (kit) for my 70 Charger R/T with a full size spare.
Thank You Very Much for any help
Mike
Re: Need Help with Correct Spare Tire Setup for 1970 Charger
[Re: Morty426]
#2633448
03/16/19 07:49 PM
03/16/19 07:49 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Might be important to know if it is a 14" or 15" car. Doesn't matter....hold down hardware is the same regardless of tire size. PM me......I have a restored set that is ready to install.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2633840
03/17/19 09:04 PM
03/17/19 09:04 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Might be important to know if it is a 14" or 15" car. Doesn't matter....hold down hardware is the same regardless of tire size. PM me......I have a restored set that is ready to install. That is whet I thought but I wanted to be sure
[Re: Morty426]
#2634308
03/19/19 08:08 AM
03/19/19 08:08 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
Might be important to know if it is a 14" or 15" car. Doesn't matter....hold down hardware is the same regardless of tire size. PM me......I have a restored set that is ready to install. That is whet I thought but I wanted to be sure Still would be helpful to know, spare could be 14 x 6(327) rim or 450?
68 Charger 70 Cuda
[Re: FC7cuda]
#2634342
03/19/19 10:15 AM
03/19/19 10:15 AM
Posts: 601 Mass
charge70
Mass
I believe that on a car that had 14"wheels the spare tire rim width was 14x5.5. On a car with 15"wheels I don't know what the rim would be.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 6bblgt]
#2634539
03/19/19 07:21 PM
03/19/19 07:21 PM
Morty426
Sacramento CA
the spare wheel size matched what was on the car: 14x5.5", 14x6.0" or 15x7.0" yep - all steel wheels
[Re: RJS]
#2635425
03/22/19 02:30 AM
03/22/19 02:30 AM
Morty426
Sacramento CA
I had thought that 15x7 equipped cars the holddown stud was longer no?? Ron On E bodies it's different because 15" cars got Space Savers
