Where to hook up to jump start 2018 Jeep Compass?
#2633314
03/16/19 12:13 PM
03/16/19 12:13 PM
Posts: 5,738 Port Huron, Michigan
MI_Custumz
Wife got a 2018 Jeep Compass with the 2.4L engine. I always look at how to jump our cars just in case she needs it done. I read the owner's manual and looked under the hood. I don't see a positive remote post and the pics attached show the battery area with the cover on and cover off. The negative post is near the bottom of the pic (the front of the jeep) and positive is near the top. Am I missing something here, I just don't see it. Didn't notice another post anywhere in the engine compartment either. Manual says it's by the battery. Pics got rotated, so the firewall (top as I took it) is to the left.
Re: Where to hook up to jump start 2018 Jeep Compass?
[Re: MI_Custumz]
#2633334
03/16/19 12:47 PM
03/16/19 12:47 PM
Posts: 21,122 Niles , Ohio
therocks
Niles , Ohio
My 12 Journey has 2 post inder the hood to attach to.The hot is covered with a piece of pastic so as it cant be accidenty grounded.I had to look fora while.The PT you had to remove the air filter box above the battery.Journeys is in the wheel well PTs was under hood.Rocky
Chrysler Firepower
[Re: moparx]
#2633870
03/17/19 10:28 PM
03/17/19 10:28 PM
therocks
Niles , Ohio
Should tell you in the factory owners manual if it has one.My journey does.Rocky
Chrysler Firepower
[Re: moparx]
#2633908
03/18/19 05:17 AM
03/18/19 05:17 AM
Posts: 9,973 MI, usa
dvw
MI, usa
what is the grey plastic piece between the two studs you refer to doug ? All those colored blocks are fuses, grey, blown, orange, green,red. I see these blown all the time at work. I wok in the electrical garage at Chrysler in Auburn Hills debugging prototypes. Doug
[Re: therocks]
#2633913
03/18/19 06:41 AM
03/18/19 06:41 AM
MI_Custumz
Should tell you in the factory owners manual if it has one.My journey does.Rocky Says to jump off the remote positive post with a red cap. As you can see, it's not there.
[Re: dvw]
#2633914
03/18/19 06:47 AM
03/18/19 06:47 AM
MI_Custumz
You can use the large stud next to the red plastic piece with the 2 screws holding it. Don't use the large stud with the cable attached. All those colored blocks are fuses. jump on the out put side and you'll blow them. Doug Would it be the red, green, blue, or purple area circled? Purple is the actual battery terminal and not sure a jumper cable end can get into there. Red and blue look small, like a side post and should work. I was actually thinking it was the green when I first looked at it.
[Re: MI_Custumz]
#2634011
03/18/19 11:37 AM
03/18/19 11:37 AM
dvw
MI, usa
You can use the large stud next to the red plastic piece with the 2 screws holding it. Don't use the large stud with the cable attached. All those colored blocks are fuses. jump on the out put side and you'll blow them. Doug Would it be the red, green, blue, or purple area circled? Purple is the actual battery terminal and not sure a jumper cable end can get into there. Red and blue look small, like a side post and should work. I was actually thinking it was the green when I first looked at it. The stud circled in red Doug
