Re: Valve Spring Height
[Re: Cab_Burge]
#2633099
03/15/19 05:24 PM
03/15/19 05:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just use the Summit height tool plus I do spring pressure also.. been fine to 8500+ rpm
[Re: MR_P_BODY]
#2633114
03/15/19 06:10 PM
03/15/19 06:10 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
To take it a step further, what is the latest thought on room to coil bind? I have heard more than.060 but less than .100, and if the spring is short on load in that range, a different spring is needed. Having more seat pressure than planned is much less of a problem.
[Re: Cab_Burge]
#2633239
03/16/19 08:40 AM
03/16/19 08:40 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Running close to coil bind is to crush harmonics out of the spring cycle, and often just a necessity of room under the retainer . The goal, changes where, and what you set up. Spring longevity, and performance, are two different goals. High HP na goal engines run really high intake pressures, and very low exhaust pressure as one example. I've seen longevity goal run a 2.3 set up spring where 2.1 would have worked at near coil bind. The cam never challenges the spring, Not enough action to start a harmonic, and they go 200 passes on what would be 50 at 2.1. They do pay for it in needing high quality valve gear.
[Re: 71birdJ68]
#2633450
03/16/19 07:58 PM
03/16/19 07:58 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Guys, I just wanted to know which brand. Starrett, Craftsman, some others I can't remember now and Mititoyo is what I use and have now on micrometers, both inside and outside there are a lot of other good brands out there also, the big thing is to have the set up standards and use them to insure the accuracy of each gauge
[Re: 71birdJ68]
#2633554
03/17/19 09:41 AM
03/17/19 09:41 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Guys, I just wanted to know which brand. That answer would be PAC. Twice as much as others, 100% quality piece.
RIP Monte Smith
[Re: Cab_Burge]
#2633588
03/17/19 10:49 AM
03/17/19 10:49 AM
Posts: 19,633 north of coder
moparx
Guys, I just wanted to know which brand. Starrett, Craftsman, some others I can't remember now and Mititoyo is what I use and have now on micrometers, both inside and outside there are a lot of other good brands out there also, the big thing is to have the set up standards and use them to insure the accuracy of each gauge also, don't forget : use them with CARE. don't pick them up to use with gritty, greasy hands. this also helps keep you from dropping them. store them as SURGICAL INSTRUMENTS. don't just toss 'em in your box. quality measuring instruments come in a storage container. that is where they belong. keep them CLEAN. gently wipe them clean after each use, and use the appropriate lubricant at the recommended intervals. do this, and these tools will repeat measurements every time and last several lifetimes.
[Re: 71birdJ68]
#2633775
03/17/19 05:35 PM
03/17/19 05:35 PM
Posts: 884 Missouri
jwb123
Missouri
What is a snap gauge? Are the ones from ProForm any good? It is shaped like a tee and when you twist the handle it locks the measurement you have, They have a weak spring inside the tool, so you hold the retainer up snap the tool to record the measurement, and then lock it, and then measure with a dial caliper. Also works to measure cylinder bores, main and rod bearing bores, etc. Every engine builder should have one. https://www.googleadservices.com/pa...vdkIrhAhWDn4MKHepGBPIQ9aACCDY&adurl=Proform ones would be fine.
[Re: 71birdJ68]
#2633825
03/17/19 08:28 PM
03/17/19 08:28 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Ok, I know what you are talking about. Are the ProForm mikes any good? There are reviews on each one that Summit sells just follow the link Andy posted. Seems like the PAC unit is very nice and the others will do the job but I would check them against a known micrometer Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
