Re: Best steering ratio in drag car
[Re: varunner]
#2631403
03/11/19 11:49 AM
03/11/19 11:49 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I wood leave it stock. increasing ratio would make it too sensitive. One of the biggest problems with crashes is over correcting so faster ratio would only compound the problem.
JAKES AUTOMOTIVE
[Re: varunner]
#2631561
03/11/19 07:47 PM
03/11/19 07:47 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
I like the standard ratio in the original A and B body cars, reducing the steering wheel diameter does affect how hard they are to turn and how quick the car starts to turn. My current S/P car has a early rack and pinion that is probably around a 12 to 1 ratio with a very small diameter steering wheel in it and it is a bear to turn when sitting still or barely moving, not so bad after 20+ MPH.
[Re: JAKE68]
#2631562
03/11/19 07:49 PM
03/11/19 07:49 PM
Posts: 22,731 Bitopia
jcc
Bitopia
I wood leave it stock. increasing ratio would make it too sensitive. One of the biggest problems with crashes is over correcting so faster ratio would only compound the problem. Would the second biggest problem be under correcting, and a faster ratio would then reduce the problem? : ![work work](/ubbthreads/images/graemlins/custom/work.gif) To me its still the driver, over-correcting is caused by limited driver skill set and onset of driver panic with their steering inputs Everyone is different, choose your ratio wisely.. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
[Re: jcc]
#2631585
03/11/19 08:49 PM
03/11/19 08:49 PM
Posts: 11,706 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
3 turns lock to lock is normal.
[Re: JAKE68]
#2631639
03/11/19 11:03 PM
03/11/19 11:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wood leave it stock. increasing ratio would make it too sensitive. One of the biggest problems with crashes is over correcting so faster ratio would only compound the problem. I agree with this... I have a short wheel base car and needed to slow the ratio twice to get what I wanted.. a rack and pinion set up ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2631785
03/12/19 10:47 AM
03/12/19 10:47 AM
RapidRobert
we went from 24:1 to 16:1 (manual) in the stock car & it was a night & day improvement, before it was hand over hand in the corners to turn it. In a 1/4 mile drag car I would think there'd be minimal turning in that pretty much strait line 1/4 mile stretch but I ain't a drag racer so I am just thinking out loud (FWIW). As said I would set in/test drive one that had the 16:1 & see what you think before you invest your time/$$$.
[Re: varunner]
#2631856
03/12/19 12:09 PM
03/12/19 12:09 PM
Posts: 289 Lowes
steve660
Lowes
Isnt there a 20:1 ratio also?
I had mine rebuilt and had a 20:1 put in.
Somebody on here did it, not sure who, been a long time ago. Maybe Resto by Rick?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: steve660]
#2631879
03/12/19 01:00 PM
03/12/19 01:00 PM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have mustangII rack in my dart, and the steering arms are shotened up a lot, to 2 1/4 turns lock to lock and about 45 degrees turn on the inside wheel. What this deal has done for me is allow me to make a snap correction at speed, and come out of a big slide ok. So as you can guess, I like fast ratios! Putting extra caster in really helps keep the car on track. Just don't overdo it. If you lose your grip on the wheel in a turn, it can do serious damage to some fingers.
[Re: gregsdart]
#2631884
03/12/19 01:20 PM
03/12/19 01:20 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Standard Pinto rack and spindles on mine were 20:1. Was satisfactory, but I wouldn't have wanted it any slower and wouldn't have minded it being a bit quicker.
[Re: Cab_Burge]
#2632052
03/12/19 08:30 PM
03/12/19 08:30 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Currently the best deal going on a 20:1 aluminum manual steering boxes is on ebay for around $150.
The best deal going on a 16:1 manual box is around $300 from PST.
For fast ratio power steering you have similar, more expensive options.
[Re: Cab_Burge]
#2632087
03/12/19 10:33 PM
03/12/19 10:33 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I would try contacting Firm Feel to see what they offer as far as ratio, gears and rebuilding or exchanging yours ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I have two stock boxes that will be used on both my future projects, I'm going to need the couplers for the stock standard steering shafts though, maybe I should call firm feel now Now why would you use a stock solid steering shaft instead of CM tube? ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: gregsdart]
#2632162
03/13/19 07:47 AM
03/13/19 07:47 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Totally agree with Gregsdart. I also favor fast ratios. Great advice on caster also.
