o-ringed block to flat surface head #2630817
03/09/19 04:17 PM
03/09/19 04:17 PM
st.louis,mo.
dart games Offline OP
st.louis,mo.
have a o-ringed block and heads that has no receiver grooves,can I get by with using copper gaskets or do I need receiver cut heads,this will be a non blown,no nos wengine,will be ran on race gas
Re: o-ringed block to flat surface head [Re: dart games] #2630854
03/09/19 06:45 PM
03/09/19 06:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd use SCE's stainless steel o ring kit (Jegs), just make sure you put the "butt" ends near the closest head bolt, no need to cut the heads, IMHO I'd run copper head gaskets as well, whats the depth of the o ring groove on the block?...
Re: o-ringed block to flat surface head [Re: dart games] #2630881
03/09/19 07:54 PM
03/09/19 07:54 PM
How high above the block do your O rings measure?
Re: o-ringed block to flat surface head [Re: dart games] #2630911
03/09/19 09:32 PM
03/09/19 09:32 PM
NY
B1duster Offline
B1duster  Offline
NY
I ran an Oringed megablock with copper gaskets and 440-1 heads with no receiver groove, with a 200 shot, for a few years with no problems at all. I used a little red silicone around the coolant passages and a heavy coat of copper spray.
Never a leak of any kind.
Re: o-ringed block to flat surface head [Re: Cab_Burge] #2630944
03/09/19 11:23 PM
03/09/19 11:23 PM
st.louis,mo.
st.louis,mo.
.020 above the block
Re: o-ringed block to flat surface head [Re: dart games] #2630946
03/09/19 11:34 PM
03/09/19 11:34 PM
I have used new solid copper head gaskets on a block like yours (between .015 up to and around .022 O ring above the decks)with .045 thick gaskets with no issues from SCE before they offered their titan series with the Teflon embossed option around the coolant holes.
At that time they said it would be better to have the receiver groove, especially when above .022 positive on the O ring.
Do you have the head gaskets yet? If not I would order them in .045 thick and exactly the same size as the bore size, maybe .007 to .015 bigger diameter over all
Re: o-ringed block to flat surface head [Re: Cab_Burge] #2630952
03/09/19 11:46 PM
03/09/19 11:46 PM
st.louis,mo.
st.louis,mo.
I have ,042 copper gaskets
Re: o-ringed block to flat surface head [Re: dart games] #2631051
03/10/19 11:38 AM
03/10/19 11:38 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I use Flatout head gaskets.
I spray it pretty hard with no issues.
Re: o-ringed block to flat surface head [Re: a493demon] #2631061
03/10/19 12:11 PM
03/10/19 12:11 PM
st.louis,mo.
st.louis,mo.
thanks to all for input,have a 426 hemi block that's O-rings,have the iron heads that go with it that has receiver holes,but have aluminum heads that dont,want to do my dual plug thing as the aluminum heads are dual plug
Re: o-ringed block to flat surface head [Re: dart games] #2631065
03/10/19 12:16 PM
03/10/19 12:16 PM
Washington
madscientist Offline
Washington
The best fix is to either cut recover grooves in the heads (I actually run the wire in the head and use the block as the receiver) or pull the wires out of the block, fill the grooves with JB weld and file it off and run some MLS gaskets or if the compression is low enough (under 12:1) use a Fel-Pro gasket and be done with it.
It's NEVER correct to use an O-ring without a receiver groove. I know it's done, but that doesn't make it correct. It's wrong and guys pay because it becomes hard to seal oil and water leaks. The copper has to be displaced and if there is nowhere for it to go, it will hold the block off of the head.
Re: o-ringed block to flat surface head [Re: madscientist] #2631080
03/10/19 01:08 PM
03/10/19 01:08 PM
st.louis,mo.
st.louis,mo.
thanks mad,never thought of using jb weld
Re: o-ringed block to flat surface head [Re: dart games] #2631082
03/10/19 01:17 PM
03/10/19 01:17 PM
I would suggest a razor blade on the JB
Re: o-ringed block to flat surface head [Re: RapidRobert] #2631119
03/10/19 02:57 PM
03/10/19 02:57 PM
Washington
Washington
RR is correct in that you can use a razor blade if you don't let the JB weld set up fully. That's actually the easiest, cleanest best way to do it.
Re: o-ringed block to flat surface head [Re: madscientist] #2631254
03/10/19 10:31 PM
03/10/19 10:31 PM
st.louis,mo.
st.louis,mo.
thanks guys
Re: o-ringed block to flat surface head [Re: dart games] #2631274
03/10/19 11:23 PM
03/10/19 11:23 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Leave the wire out, and use cometics..no spray, and na, they'll serve you better for longer imo.
Re: o-ringed block to flat surface head [Re: dart games] #2631342
03/11/19 09:08 AM
03/11/19 09:08 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
used copper head gaskets for many years with only the o-ring in the block. Main issue is do not have the o-ring too tall out of the block.
from SCE "Recommended o-ring protrusion is not more than 25% of gasket thickness (see figure 1 below). Wire height in excess of 25% gasket thickness without receiver grooves may cause coolant leaks by supporting the cylinder head too high for proper coolant sealing. Example: Gasket thickness .043”, o-ring protrusion height should be .008” to .010”. This standard works with all thicknesses that are .050” and less. Gaskets thicker than .050” do not require o-ring height more than .012”.
I find .010 the proper height. Then I use motoseal, around the water ports, it is a thin silicone sealant designed for metal to metal applications. works great.
Re: o-ringed block to flat surface head [Re: dart games] #2631343
03/11/19 09:16 AM
03/11/19 09:16 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There is a Devcon plasti seal epoxy and JB extreme heat 2400*F to look into
Re: o-ringed block to flat surface head [Re: Clanton] #2633240
03/16/19 08:46 AM
03/16/19 08:46 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Should you use cometics, there is no need to fill anything with epoxy. They will work fine with no other mods. Done it several times on your situation, and with combos done with wire, and receivers. Pull the wire, and slap them on.
Re: o-ringed block to flat surface head [Re: B1duster] #2633758
03/17/19 04:26 PM
03/17/19 04:26 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
about the same here. O-ringed Mega Block, no grooves in the 440-1s, 13.5/1, SCE Copper gaskets, Hylomar for coolant passages...no NOS. Trouble free.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
