Re: Turbo Action valve body
[Re: tubtar]
#2624265
02/21/19 04:18 PM
02/21/19 04:18 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Order extra solenoids.....I've had numerous failures when I had a TA brake in the Duster. Also it's a slowwwwwwwww brake compared to that Griner.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: tubtar]
#2624285
02/21/19 04:46 PM
02/21/19 04:46 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I am not going for a brake........I foot brake the car for now. One more facet of the old dog , new trick phenomenon. That , and the valve body is just the start. Then , it is a delay box. Or two. And all the limiters , chips and assorted doo dads that go with it. I'll be in the home before I figure all that out.
[Re: John_Kunkel]
#2624337
02/21/19 06:44 PM
02/21/19 06:44 PM
BradH
That model TA valve body is NOT a full manual, it's a "manual/automatic" that still requires using the kickdown linkage. If you're looking for a TA forward-pattern manual vb, the older and current model #s are as follows: 17675 - CHEETAH Pro Street Valve Body - PRN321 Stock Pattern, Manual Only (Pro Street and Competition Use) --> Low Band Apply 17680 - CHEETAH Manual SP Valve Body - PRN321 Stock Pattern (Competition Drag Strip Use Only) --> No LBA 17875XA - CHEETAH XtremeAction Pro Street Valve Body - PRN321 Stock Pattern, Manual Only --> Low Band Apply - https://www.turboaction.com/17875XA%206-04-18.pdfThe 17875XA also has the same "If your Low/Reverse rear servo has a heavy aftermarket spring you must change it back to a stock return spring. If you do not use a stock rear servo spring you will burn up the rear band." warning, which I asked about on here last year.
[Re: tubtar]
#2624410
02/21/19 09:50 PM
02/21/19 09:50 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
I run the older version Turbo Action 17676 Auto/Manual Valve Body on the street in my 71 Bee
My Low/Reverse uses the heavy duty spring that came with the Valve Body
The newer Turbo Action 17876 Auto/Manual Valve Body doesn’t use this heavy duty spring per instructions
Has the auto shift feature or shift manually
And uses the factory kick down linkage
I just installed one in my friends car in fall
Anyways
I had the chance to talk with Randy in detail about this when I bought my billet servos from him thru email , what is the difference between both valve bodies , old and new
Man , what awesome customer service a few years back by the way
He wanted to know what exact valve body I was using because he said the newer 17876 Valve Body uses these two bleed holes in the picture , hence eliminating the need for the heavy duty Low / Reverse spring
My 17676 Valve Body did not have both of these bleed holes
I am not a Transmission expert hence my questions when I was buying his billet servos and installing my Turbo Action 17676 Valve Body that was still new in the box , never installed , that I bought from a local guy
And yes I am running the factory kick down linkage with this 17676 Valve Body
And yes the Valve Body has the auto shift feature with part throttle kick down
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: BradH]
#2627785
03/02/19 03:07 AM
03/02/19 03:07 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
FWIW, I was asking questions on here about the TA 17875XA valve body sometime last year. It might be worth searching on that valve body # and see if anything else you might want to know comes up. At the time I was looking into changing from my TA 17680 to something w/ LBA, since mine's a street/strip car. Brad we put the A & A low band apply reverse manual valve body in my sons Dart last summer. It had the old Turbo Action valve body I bought in the 80's that was a reverse manual valve body with no low band apply which is the kind I use in my 63. The A & A unit works great in his car as it did not slow down at all and we feel no 2 element fight as the 1-2 shift feels just like it did with the TA no low band apply. We did install their low/reverse servo and spring which they recommended with it. Ron
[Re: bee1971]
#2627793
03/02/19 03:24 AM
03/02/19 03:24 AM
383man
Balt. Md
Anyways
And yes the Valve Body has the auto shift feature with part throttle kick down That makes me think back to around 1996 I believe it was where we had a lot of snow in Md where I live in about a months time. We got like 8" of snow and then 6" of snow about 4 days later and then a few days later even more snow. But I remember a service bulletin where many were complaining their trucks went into reverse to hard and they hit kinda hard when going in reverse. The service bulletin had us remove that check ball and the truck did not hit so hard then going in reverse. But right in the middle of the snow storms we started seeing trucks coming in with no reverse as they were burning up the low/reverse bands. And they all had snow plows on them as it seems they would shift from drive to reverse so fast and then nail the gas before the truck had reverse fully engaged since reverse took longer to engage with the check ball removed. I still remember we had 12 trucks at the shop with reverse gone out of them and we had 3 trans people as I was one of them. I stayed very busy for them few weeks after the big snow storms and of course Mopar had us putting the check balls back in the valve body and telling people that a little bang going in reverse is normal. But they did bring another service bulletin out later to address the banging in reverse. Ron
[Re: BradH]
#2628936
03/05/19 12:25 AM
03/05/19 12:25 AM
tubtar
St. Paul , Mn.
I've got a CRT RMVB with LBA waiting for me to swap out my current TA FMVB. That is exactly what I was hoping for. Forward pattern and full manual. If this deal goes south , and you want to sell yours , I am probably the guy. lol
[Re: SILVER67]
#2629256
03/05/19 03:44 PM
03/05/19 03:44 PM
tubtar
St. Paul , Mn.
Have to wonder what it is about forward pattern.........i see plenty of GM tranny's that fwd manual shift For me , it is simply a matter of what I am used to. I tried the RMVB for a couple years and it still felt foreign to me. Gonna stick to what I know. Old dog............new trick.
[Re: J_BODY]
#2629476
03/06/19 01:45 AM
03/06/19 01:45 AM
tubtar
St. Paul , Mn.
I think you can get a PPP shifter that will forward shift a RMVB.... just to throw that out there Too late. Installed the forward pattern gate in the Cheetah shifter last week. The proverbial object is in motion.
