Re: 2983696 Key buzzer.... or not ? [Re: dragon slayer] #2629568
03/06/19 11:16 AM
03/06/19 11:16 AM
New York
rarefish Offline
rarefish  Offline
New York
Originally Posted by dragon slayer
Neither of those look like a buzzer to me, but I do see it listed as that on google search as E body part. But if you google 2983872 you will find this buzzer on every thing including, A, B, C and E body.
I just went through my NOS buzzers and found this 3420885 one. The factory parts book has it listed as for 1970 R, W, P, D models.
Inside the box was a buzzer unit stamped 2983872.
I will assume that 3420885 is the correct part number for the part that is marked 2983872.
Re: 2983696 Key buzzer.... or not ? [Re: rarefish] #2629964
03/07/19 01:06 PM
03/07/19 01:06 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
3 actually grin
Re: 2983696 Key buzzer.... or not ? [Re: mccannix] #2629966
03/07/19 01:08 PM
03/07/19 01:08 PM
Valencia, España
Valencia, España
Originally Posted by mccannix
I was under the impression the OP was talking 1970 E-body since he was initially referring to the so 2983696 (pn 3420884 ) being a roadlamp relay.
I cant comment on the B body models but I believe the 2983696 was used in A body as well .
If I can find that old thread, it goes into deep detail on all relays, buzzers, harness, 70 and 71 all being different.
yes I allways have known being the 2983696 a buzzer, but some confusion come into mind when I read that description on the Road lamps sale. Thats why I asked.
Re: 2983696 Key buzzer.... or not ? [Re: NachoRT74] #2630010
03/07/19 02:32 PM
03/07/19 02:32 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I will just add that my own 70 road lamp equipped cuda, that I got in around 1978 had a clear "click" sound under dash when road lamp switch was turned on. I clearly recall the parking lights coming on while headlamp switch remained in off position. Some fellow mopar heads have disputed this over the years, and I tell them they're whacked. What I can't recall, is if the operation of the road lamps, relay and all required key to be on. I'm thinking yes.
Re: 2983696 Key buzzer.... or not ? [Re: NachoRT74] #2630063
03/07/19 05:44 PM
03/07/19 05:44 PM
New York
rarefish Offline
rarefish  Offline
New York
3 actually grin
Thanks...Time for new glasses.
Re: 2983696 Key buzzer.... or not ? [Re: rarefish] #2656048
05/16/19 04:02 PM
05/16/19 04:02 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
This is what mine looks like. Where is it mounted under the dash on a 70 Charger? I took it off about 30 years ago and forgot where it is mounted. Anybody have pictures of the location?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 2983696 Key buzzer.... or not ? [Re: 70sixpkrt] #2656057
05/16/19 04:41 PM
05/16/19 04:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Approximately 6-8 inches from the fuse block.
Re: 2983696 Key buzzer.... or not ? [Re: Alaskan_TA] #2656059
05/16/19 04:57 PM
05/16/19 04:57 PM
70sixpkrt Offline
70sixpkrt  Offline
Thanks. Any picture of the connector? I hate fooling around with electricals.
4-speed
3:54 Dana
Re: 2983696 Key buzzer.... or not ? [Re: 70sixpkrt] #2656065
05/16/19 05:14 PM
05/16/19 05:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I took four photos & posted them in your thread at http://www.1970chargerregistry.com/mboard/index.php?topic=5662.0
Re: 2983696 Key buzzer.... or not ? [Re: Alaskan_TA] #2656075
05/16/19 05:57 PM
05/16/19 05:57 PM
70sixpkrt Offline
70sixpkrt  Offline
Wow. Thank you very much. up
4-speed
3:54 Dana
