Re: Rebuilt 360 cranks and then stops
[Re: magnum440d100]
#2628064
03/02/19 09:26 PM
03/02/19 09:26 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Stock rocker arms will be punched thru by the pushrod went a stiffer valve spring is used...
MP made or makes a heavy duty non adjustable rocker arm to correct that problem. Still for sale at Mancini Racing..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: magnum440d100]
#2628097
03/02/19 11:32 PM
03/02/19 11:32 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
And in my opinion your cam, lifters, pushrods, rockers. valves, and keepers are all junk now. You will also need new springs and retainers that are for whatever cam you use. Did you tell whoever did the valve job what cam you had. No excuse for this if you did...
[Re: 4406bbl]
#2628106
03/02/19 11:47 PM
03/02/19 11:47 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
And in my opinion your cam, lifters, pushrods, rockers. valves, and keepers are all junk now. You will also need new springs and retainers that are for whatever cam you use. Did you tell whoever did the valve job what cam you had. No excuse for this if you did... Yes. Everything was supposed to have been spec’d out for this cam. What springs/retainers/pushrods/valves/etc should I go with?
[Re: 4406bbl]
#2628136
03/03/19 01:01 AM
03/03/19 01:01 AM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
You were getting coil bind on both intake and exhaust valve springs, proof is both rocker arms failed. You'll most likely find a bunch of bent pushrods.
[Re: magnum440d100]
#2628157
03/03/19 02:33 AM
03/03/19 02:33 AM
4406bbl
Nebraska
Do not run or rotate this engine anymore until you pull heads and correct retainer to guide clearance about .060, check for coilbind, and check piston to valve clearance. It is not normal for pushrods to go thru stock rockers with that cam. I have done it, and gone thousands of miles no problems with that cam and correct springs.
[Re: magnum440d100]
#2628801
03/04/19 06:24 PM
03/04/19 06:24 PM
Posts: 530 SW CO
HemiSportFury
SW CO
I'd replace it. Be sure to check the rod too. But most importantly, why did this happen in the first place?
How does the cylinder wall look?
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: magnum440d100]
#2628945
03/05/19 12:54 AM
03/05/19 12:54 AM
Posts: 530 SW CO
HemiSportFury
SW CO
So are you thinking the coil bind is your only problem? It looks like the valve was tagging the piston too. Did you check P-V clearance and degree the cam? What does the head look like? Any sign to piston-valve contact on any other cylinder. You don't want to go through this again. It could have been much worse.
[Re: HemiSportFury]
#2628949
03/05/19 01:02 AM
03/05/19 01:02 AM
RapidRobert
^^^ agreed, I would mockup with a pair of light springs & go thru all of the clearance checks
