Re: 2983696 Key buzzer.... or not ?
[Re: dragon slayer]
#2629568
03/06/19 11:16 AM
03/06/19 11:16 AM
Posts: 2,263 New York
rarefish
New York
Neither of those look like a buzzer to me, but I do see it listed as that on google search as E body part. But if you google 2983872 you will find this buzzer on every thing including, A, B, C and E body. I just went through my NOS buzzers and found this 3420885 one. The factory parts book has it listed as for 1970 R, W, P, D models. Inside the box was a buzzer unit stamped 2983872. I will assume that 3420885 is the correct part number for the part that is marked 2983872.
[Re: rarefish]
#2629964
03/07/19 01:06 PM
03/07/19 01:06 PM
Posts: 6,109 Valencia, España
NachoRT74
Valencia, España
Neither of those look like a buzzer to me, but I do see it listed as that on google search as E body part. But if you google 2983872 you will find this buzzer on every thing including, A, B, C and E body. I just went through my NOS buzzers and found this 3420885 one. The factory parts book has it listed as for 1970 R, W, P, D models. Inside the box was a buzzer unit stamped 298387 2. I will assume that 3420885 is the correct part number for the part that is marked 298387 2. 3 actually
[Re: mccannix]
#2629966
03/07/19 01:08 PM
03/07/19 01:08 PM
NachoRT74
Valencia, España
I was under the impression the OP was talking 1970 E-body since he was initially referring to the so 2983696 (pn 3420884 ) being a roadlamp relay. I cant comment on the B body models but I believe the 2983696 was used in A body as well .
If I can find that old thread, it goes into deep detail on all relays, buzzers, harness, 70 and 71 all being different. yes I allways have known being the 2983696 a buzzer, but some confusion come into mind when I read that description on the Road lamps sale. Thats why I asked.
[Re: NachoRT74]
#2630063
03/07/19 05:44 PM
03/07/19 05:44 PM
rarefish
New York
Neither of those look like a buzzer to me, but I do see it listed as that on google search as E body part. But if you google 2983872 you will find this buzzer on every thing including, A, B, C and E body. I just went through my NOS buzzers and found this 3420885 one. The factory parts book has it listed as for 1970 R, W, P, D models. Inside the box was a buzzer unit stamped 298387 2. I will assume that 3420885 is the correct part number for the part that is marked 298387 2. 3 actually Thanks...Time for new glasses.
