Body color or ????? #2626998
02/28/19 04:26 AM
02/28/19 04:26 AM
tx
N
nobrakesneeded Offline OP
N
tx
1973 roadrunner
What color is the underside of the Body?
Body color? Black? Primer?
Re: Body color or ????? [Re: nobrakesneeded] #2627003
02/28/19 05:25 AM
02/28/19 05:25 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
This may not be helpful as I don't have experience with the early 70s models, but in 68-69 for example, the undersides were primered a grayish color. The body color was feathered in on each side a bit beyond the rocker panels, but the majority of the underside was primered.
This is how I did my 69 roadrunner, similar to factory.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Body color or ????? [Re: BigDaddy440] #2627026
02/28/19 11:12 AM
02/28/19 11:12 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Same way I did mine, overspray.
1969 Hemi Roadrunner 2nd owner
Re: Body color or ????? [Re: nobrakesneeded] #2627036
02/28/19 11:57 AM
02/28/19 11:57 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Your 73 would have been done the same way. Primer with body color overspray. If your car came with underhood insulation, the underside would have been completely undercoated. Undercoating and hood insulation were part of the same package.
Re: Body color or ????? [Re: nobrakesneeded] #2627104
02/28/19 02:31 PM
02/28/19 02:31 PM
tx
N
N
tx
Thanks for the info. The owner is a gm guy and adamant that the proper color for the underside of all vehicles is black. I've already had to back him off painting the engine bay black......
Re: Body color or ????? [Re: nobrakesneeded] #2627179
02/28/19 05:38 PM
02/28/19 05:38 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Primer with overspray
Re: Body color or ????? [Re: BigDaddy440] #2627191
02/28/19 06:26 PM
02/28/19 06:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
More examples of how Lynch Road '69 B=bodies were underside color over sprayed with the bottom center dip gray (primer?) corrosion bath left unpainted body color.
This is a low mileage survivor Super Bee, you can see the Bahama Yellow on the outside and the gray dip still inboard.
There's more examples but can't get to them right now. I'd do a gray epoxy paint, not primer, then over spray it on the out side in body color if I was looking for O.E. but really I think it's best and less time and prep to just do the bottom body color and be done with it.
Re: Body color or ????? [Re: A12] #2627248
02/28/19 09:36 PM
02/28/19 09:36 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look.
69 GTX 68 Road Runner
Re: Body color or ????? [Re: JERICOGTX] #2627259
02/28/19 09:52 PM
02/28/19 09:52 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I caught someone on their hands and knees looking under my '68 Road Runner for what I don't know but I said to him "hey if I hand you a wrench could you check a couple of muffler clamps for me while your down there" grin laugh2 purple It was something stupid and if someone is checking out the underside of your car and they're not an OE judge then just ask them what they found so interesting and to also check a couple of muffler clamps too. wink
Mike
Re: Body color or ????? [Re: JERICOGTX] #2627316
02/28/19 11:36 PM
02/28/19 11:36 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Disagree. Instead paint it flat grey. Resto Rick sells a paint to do this. Then you have the protection of paint and the right look.
Re: Body color or ????? [Re: A12] #2627329
02/28/19 11:54 PM
02/28/19 11:54 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Mike
Some of these folks crack me up...had one call me out at a show...told me all 69 big block motors were orange.... "Uh...its a 68".... he scampered off.... lol
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Body color or ????? [Re: JMCFAN] #2627333
03/01/19 12:14 AM
03/01/19 12:14 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Mike
Just ask "Where is your car, I would like to critique it?
Re: Body color or ????? [Re: JMCFAN] #2627361
03/01/19 01:32 AM
03/01/19 01:32 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Mike
I was selling my '68 Road Runner and got the same thing from a guy and his "Mopar Expert" too on the engine color being wrong. Got real cocky and wanted me to knock the price off by $5k or more for that mistake and the fact it may not even be a RR engine.........before I could say anything my friend (a real Mopar guy) said "you know it's a '68 and even if it were a '69 this ('68 RR) is an original A/C car and the '69 RR A/C engine it turquoise too. I had no interest in selling the RR to this guy even if he offered more then the asking price.
Re: Body color or ????? [Re: nobrakesneeded] #2627415
03/01/19 10:02 AM
03/01/19 10:02 AM
cbusters Offline
cbusters  Offline
Do a sprayout with primer and have the shop color match the primer with regular paint.
Re: Body color or ????? [Re: cbusters] #2627510
03/01/19 01:45 PM
03/01/19 01:45 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
I painted the whole underside same as body hemi orange. i think it looks better the OEM.
Re: Body color or ????? [Re: ct440rod] #2627888
03/02/19 01:40 PM
03/02/19 01:40 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You will only be here once so why would you do anything but restore it the way the factory did. Painting the undercarriage body color is as bad as painting the trunk with spatter paint or the engine compartment black. It's all WRONG!
There are plenty of products that will protect and have the appearance of the original correct look from the factory.
To the OP. If you have a GM guy restoring your Mopar you will have a ton of problems unless you watch him like a Hawk! Do your research and make him do it the way you want or on completion you will be disappointed.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Body color or ????? [Re: nobrakesneeded] #2628032
03/02/19 07:59 PM
03/02/19 07:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I have a '65 coronet and a '69 coronet r/t. both have the original underbody paint. looks to be a flat black to me. both have some body color overspray showing.
Re: Body color or ????? [Re: lewtot184] #2628036
03/02/19 08:08 PM
03/02/19 08:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Wouldn't by chance both are LA assembly plant cars?
Re: Body color or ????? [Re: nobrakesneeded] #2628081
03/02/19 10:37 PM
03/02/19 10:37 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
None of the underbody colors were truly "Flat", all had a dull sheen to them, just nothing like the paint did. The factory dipped the cars in a rust prohibitive sealer/primer bath up to about the armrest pad level, then the cars were baked in an oven which hardened drips you see on the bottom contours of the floor pans and caused the thick hardened bubbly residue inside the cars trunk floor and interior floor pan areas. The cars were then shot with primer and paint and baked again. The dip coating they received was a medium elephant grey color for most plants, the Los Angeles plant used a much darker colored material that was close to black but was actually a very dark bluish grey. The duster example shown here shows the proper Los Angeles dip primer color, before and after restroation.
Re: Body color or ????? [Re: nobrakesneeded] #2628651
03/04/19 01:10 PM
03/04/19 01:10 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I think it's way easier to paint the bottom side of the car in the factory primer overspray method. It IS how they came new! No time consuming masking, and heck of $ savings in paint materials! I want to puke everytime I see a car full painted body color underneath. The ironic part is after restoring it incorrectly they add paint dabs and parts tags to detail it up. Why bother, it's incorrect from the get-go!
