Re: Shaker hood and aftermarket intake manifold? [Re: Lee446] #2626863
02/27/19 09:25 PM
02/27/19 09:25 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have always had good luck with the Holley Street Dominator intakes, too.
Master, again and still
Re: Shaker hood and aftermarket intake manifold? [Re: an8sec70cuda] #2626885
02/27/19 10:30 PM
02/27/19 10:30 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I used a Weiand dual plane intake on a E body with shaker. 440 engine. It fit fine. Don't know if these intakes are still available new. If not I am sure a used one can be located.
Re: Shaker hood and aftermarket intake manifold? [Re: an8sec70cuda] #2626919
02/27/19 11:27 PM
02/27/19 11:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
In order of height greater than the factory cast iron 4 bbl intake
CH4B & Weiand - 0.3-0.4"
Performer - 0.5"
Torker II - 0.8"
SD - 0.9"
Indy 2D & RPM - 1.5"
Re: Shaker hood and aftermarket intake manifold? [Re: an8sec70cuda] #2626942
02/28/19 12:20 AM
02/28/19 12:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You will be fine with a CH4B
Re: Shaker hood and aftermarket intake manifold? [Re: BSB67] #2627100
02/28/19 02:25 PM
02/28/19 02:25 PM
moparx Offline
moparx  Offline
Performer - 0.5"
Torker II - 0.8"
SD - 0.9"
i found my CH4B intake, but it's buried behind "a little stuff". from what i could see, it has a 28something part number cast, plus the CH4B cast number. the 2836150 intake pictured is probably the CH4B intake, as it looks identical to mine without the "eldebrock" [biggrin] casting numbers.
BSB67, thank you ! you confirmed my old mind's recollection of 3/8-7/16" height difference of the CH4B.
beer
Re: Shaker hood and aftermarket intake manifold? [Re: an8sec70cuda] #2627209
02/28/19 07:37 PM
02/28/19 07:37 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Ditch the carb and go with an EFI throttle body.
Pretty darn short:
