Re: NHRA require sfi engine diapers in 2019 ?
[Re: merpar]
#2625936
02/25/19 05:11 PM
02/25/19 05:11 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
I have a Allstar blanket on my Challenger with a 10 quart flat bottom top fuel type oil pan and an Accusump. With the tubular K Frame. It takes no longer then changing the oil to remove for driving on the street
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: merpar]
#2627571
03/01/19 03:31 PM
03/01/19 03:31 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
I have used DRE for three different cars and our dragster. Dennis is a great guy and the stuff fits and works, as we have unfortunately field tested them
[Re: merpar]
#2627657
03/01/19 08:32 PM
03/01/19 08:32 PM
Posts: 24 PA
1118Steve
PA
Pittsburgh Racer, John, you and I have had this discussion many times.
Try putting one on a Hemi B body......ain't no way. What gets me is that everyone makes a big deal out of this, then we all watched on TV the Hemi Shootout and watched Bucky Hess spin around in his own oil and hit the wall.....with an 8.30 second AH Cuda.....and, no diaper. And they spin those to over 10K. The average bracket guy is being busted for this, then we find the big money hitters don't have to have one. Why?
But, the biggest I wonder is this......what about the new cars? There are new Hellcats, and others that run 10.90s, easy. We've all seen the new Hemi Challengers and others do that at your local strip. Tell the guy he has to stick a diaper on his brand new car and see if he comes back. I'd bet he doesn't.
Although I don't have anything against them, at all, if one wants by all means use them.....but, I do think it's a money grab. One of the reasons I've kept my car at C/NSS at 11 flat index is to avoid the hassle.
"Old Age and Treachery beats youth and enthusiasm"
[Re: 1118Steve]
#2627670
03/01/19 09:24 PM
03/01/19 09:24 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
Although I don't have anything against them, at all, if one wants by all means use them.....but, I do think it's a money grab. One of the reasons I've kept my car at C/NSS at 11 flat index is to avoid the hassle. I am really glad to get out of that dumpster fire that is the NHRA. I got so tired of being hosed every time I turned around. It's not like it isn't already a huge amount of time and money to field a weekly bracket car but then having to adhere to every stupid little rule and change at the whim of the NHRA is just too much. I totally get some of the rules but seriously, my aluminum trans shield didn't go bad in 5 years or did my window net. It just got stupid ridiculous.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: J_BODY]
#2627735
03/02/19 12:36 AM
03/02/19 12:36 AM
Posts: 24 PA
1118Steve
PA
Maybe for a serious racer.....but tell the average guy who likes to go to the track and run his new car once in a while, that he has to put on an oil retention device on his brand new car and he won't be back.
Most of the oildowns I've seen in my fifty years of racing don't come from broken rods, etc.....they come from an oil line, a trans line, or something like that coming loose, or a leak. A Diaper won't help those anyway. A 6000 rpm bracket motor does not oil the track all that often.
Maybe those 9500 rpm small blocks do it, but not too many big block anything oil the track.
Just the fact that they are beating on the rank and file bracket guys to let one, but don't make the class racers put one on really makes me suspect of the reasoning behind it.
[Re: 1118Steve]
#2627797
03/02/19 03:51 AM
03/02/19 03:51 AM
Posts: 43 Otsego, mi. by Martin 131 stri...
JT612GTX
Serious racers or not, until you have wrecked a perfectly nice 70 Challenger RT or any other collectable mopar you would understand how important oil containment really is. Id bet Buckey Hess has one on now, how did he pass tech without one? anything can happen and will happen when your on the track beating the snot out of your hotrod! yes us serious racers have enough downtime at the track let alone having a oil down to boot, not to mention personal safety as well. I agree SFI requirements are a money maker for suppliers and should be only required for professional classes/ high HP classes. How much is your car worth to you? mine priceless!!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left 71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning 70 Challenger - mild 440/727 - 3475lbs - 10.96 best 70 GTX - future quick 16? more $$$$$$
[Re: JT612GTX]
#2627858
03/02/19 12:33 PM
03/02/19 12:33 PM
Posts: 24 PA
1118Steve
PA
Hess does not have one now. None of them do. They are not required in NHRA class racing, so it is not a tech item.
[Re: merpar]
#2627907
03/02/19 02:12 PM
03/02/19 02:12 PM
Al_Alguire
Las Vegas
Bucky Hess did not have one because Stock and Super Stock are not REQUIRED to have one. Loophole in the rules that gets many S/ST racers upset as its a requirement for them and many of the have stock front end cars. Its part of the enhanced NHRA experience. BTW the oil down policy is in place for EVERYONE that runs National events no matter who they are, hows that for enhanced experience. I diaper CAN be made to fit ANY combo. A belly pan can also be made to work if one really cares about keeping oil off the track. One last tidbit we have had two BB Mopars come apart that WOULD have oiled the track if not for the diapers, and one that in spite of having a diaper oiled the track anyway. All Bracket motors, one Hemi and two wedges. One of the wedges came in a car we purchased and 11 laps later hurt the block bad enough to get water on the track and pieces went THROUGH the diaper, and body panel.
[Re: merpar]
#2628359
03/03/19 06:32 PM
03/03/19 06:32 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I h ave a b body and a diaper would be difficult With the link through the pan.I'm thinking more and more about a large belly pan back to the trans pan.I wonder if there could be an aero advantage for the brick? I blew a freeze plug and tagged the wall back in '13.What a SLIDE!!!
[Re: merpar]
#2628361
03/03/19 06:38 PM
03/03/19 06:38 PM
hemi-itis
I am NOT a competitor,just a sreet car that morphed into what it is,,,,whetever that may be,,,,,,,,,
[Re: merpar]
#2628370
03/03/19 06:52 PM
03/03/19 06:52 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you've ever put the header, steering, torsion bar, starter, oil pan puzzle together under a legal Hemi Super Stock car, talking about adding a diaper to the mix would not be a welcome conversation.
[Re: dvw]
#2628378
03/03/19 07:13 PM
03/03/19 07:13 PM
Posts: 991 Addison,IL
OUTLAWSSAA
Addison,IL
Diaper on mine. Though it's a wedge, not a Hemi. Doug Not an A-body either
