Re: NHRA require sfi engine diapers in 2019 ?
[Re: WO23Coronet]
#2625529
02/24/19 05:03 PM
02/24/19 05:03 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That's pretty good of your track guy to sell them at cost Yes it is and he’s a good friend but look at it this way. He made the rule at our track before the division officially did. It helps both him financially with track cleanups and us for wasted time waiting on cleanups and possible wrecks. Ohhhh ya we be-itched and moaned and some are still skirting the rule but it kicked us guys on the fence to finally put one on. I wish others would
[Re: WO23Coronet]
#2625543
02/24/19 05:43 PM
02/24/19 05:43 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's pretty good of your track guy to sell them at cost Rice hull ash is expensive. Guy sounds pretty smart to me.
[Re: DusterKid]
#2625546
02/24/19 05:46 PM
02/24/19 05:46 PM
BradH
I've heard NHRA will require engine diapers for cars 10:90 and quicker. If so at what point do they have to be sfi? Did you just hear that or did you actually see it somewhere from NHRA? I have the same question.
[Re: merpar]
#2625596
02/24/19 08:22 PM
02/24/19 08:22 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
You do not need an SFI lower containment device until Pro Mod, Alky and Fuel classes. Otherwise you just need a diaper, NOT an SFI one. So in theory you should have zero issues with you expired SFI device.
According to the newest rulebook you do not need one unless you run Advanced ET, S/G, S/C or S/ST and Pro Stock, all non SFI required. Otherwise I don't see anywhere it is required other than those, and the aforementioned pro and alky classes.
[Re: scottb]
#2625625
02/24/19 09:44 PM
02/24/19 09:44 PM
Posts: 43 Otsego, mi. by Martin 131 stri...
JT612GTX
Hey Scott I believe your referring to my wreck, yes Im a firm believer in diapers on any modified drag car, I did actually have one on the challenger but it was placed back to cover minor rear main leak,not covering but only third of the block,gonna cost me dearly to restore the wifes challenger, I had one on my daytona at pinks all out at martin 131 windowed the block, not a drop of oil on the track, every track should make them a requirement!!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left 71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning 70 Challenger - mild 440/727 - 3475lbs - 10.96 best 70 GTX - future quick 16? more $$$$$$
[Re: Al_Alguire]
#2625642
02/24/19 10:05 PM
02/24/19 10:05 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
According to the newest rulebook you do not need one unless you run Advanced ET, S/G, S/C or S/ST and Pro Stock, all non SFI required. Otherwise I don't see anywhere it is required other than those, and the aforementioned pro and alky classes. It's mostly the tracks taking the lead on this with bracket racing. Can't blame them. Time and resources to clean up a mess. It's not like they all have their own Safety Safari.
[Re: merpar]
#2625684
02/24/19 11:53 PM
02/24/19 11:53 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I run the J&J generic fit on both my 71 Cuda (rack, struts and custom headers so easy fit)and in my 68 Cuda (SB, stock front end, Milodon pan and TTI headers).
It was tight on the A body but worked fine and passed NHRA tech for Super Street.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: CMcAllister]
#2625853
02/25/19 02:18 PM
02/25/19 02:18 PM
Al_Alguire
Las Vegas
I agree, everyone should have one and many tracks require it at 10.00. When I was in cali my business paid anyone who won S/Pro at Sonoma $100 if they had a diaper on their car for two years. I have run one for a very long time myself and we have scattered a couple engines and not put anything on the track. But the OP asked about NHRA and SFI and that's where they stand
[Re: BradH]
#2625878
02/25/19 03:09 PM
02/25/19 03:09 PM
BradH
It is a tough deal for us street car guys that need to keep things cool...
Who has a diaper on a small block A-body with TTI headers? One of the tubes is almost in the oil pan and the centerlink almost touches the milodon pan. x2 In my case, it would be an RB E-body with TTI headers. SFI or not (The MoPig ain't never gonna see a single-digit 1/4-mile ET), where should I be looking for a diaper for this type of application? Also, how easy is it to remove one for basic service such as oil & filter change?
[Re: merpar]
#2625893
02/25/19 03:47 PM
02/25/19 03:47 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I see a lot of good things said about DRE - enginediapers.com. No first hand experience though.
[Re: CMcAllister]
#2625906
02/25/19 04:10 PM
02/25/19 04:10 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought my first diaper for my Daytona back around 2006-2008. It’s still sitting unused on my shelf somewhere . It’s big, bulky, heat resistant, and free to anyone local when I find it. I will post up some pictures and like I said if someone local wants to drive here to pick it up they can have it. Sorry but I will not ship. I will try to post pictures today. This would be perfect for a tube chassis, rack n pinion big block car and was made for a Charlies or Dragster type of oil pan
[Re: BradH]
#2625911
02/25/19 04:16 PM
02/25/19 04:16 PM
BradH
Not my car, but a representative enough pic to give people an idea of how a diaper would need to fit the application...
