Page 2 of 3 1 2 3
Re: What wheels and tires originally came on my E body [Re: 70gtx440dana] #2624873
02/22/19 08:41 PM
02/22/19 08:41 PM
FLPlum Offline OP
FLPlum  Offline OP
OK, I went out in the garage and pulled the trim ring off the 14” rally?
Per your date wheel mine is
Month 8.
Day27.
Part number 2944252.
It has been painted, I can’t tell the plant, it is blurry.
With car build date late September, I think these rallys could be original to car.what is your opinion.
Is there no year stamp?
Originally Posted By 70gtx440dana
Your wheels should have parts numbers and date codes stamped on them. They appear around the valve stem hole. You should inspect them to help determine if they are possibly original to your car. Your spare tire configuration and date codes may also lend some useful information.
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2624884
02/22/19 09:18 PM
02/22/19 09:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Part number 2944252
is a 1970 & 1971 14x5.5" Rallye wheel.
The year designator is under the plant code.
M is Motor Wheel.
Check another wheel if you can not read the one you checked?
Photos can help also.
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2624918
02/22/19 11:25 PM
02/22/19 11:25 PM
FLPlum Offline OP
FLPlum  Offline OP
I don’t have url or website to upload the photos, but it looks like a M but I don’t see a year
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2624923
02/22/19 11:31 PM
02/22/19 11:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I upload my photos from my PC, nothing else needed.
Check the other wheels under the M when you have time & report back.
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2624926
02/22/19 11:34 PM
02/22/19 11:34 PM
FLPlum Offline OP
FLPlum  Offline OP
Looks like a match.thanks to 6bblgt and 70gtx for the excellent numbers and charts.
So I learned something new today.my wheels match.
Thank you guys
There was a 9 under the M.
I’ll see if I can upload the photo from my pc.
Re: What wheels and tires originally came on my E body [Re: biggE] #2624993
02/23/19 04:21 AM
02/23/19 04:21 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Originally Posted By biggE
Another clue could be that if your lower control arms have a spacer underneath the rebound bumper. If so that would indicate 15 inch wheels. If there's no spacer it would indicate 14 inch wheels.
Would this be true on a superbird too?
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2625176
02/23/19 06:29 PM
02/23/19 06:29 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Thank you guys
the 9 is for 1969
I think you have a match up
Re: What wheels and tires originally came on my E body [Re: 4406bbl] #2625403
02/24/19 01:08 PM
02/24/19 01:08 PM
California
biggE Offline
biggE  Offline
California
Yes
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2625453
02/24/19 02:35 PM
02/24/19 02:35 PM
FLPlum Offline OP
FLPlum  Offline OP
Anybody want to decode my Goodyear polyglas tires date.
Obviously these are at least 25 years old, or more. I am going to put new ones on my wheels, but I thought it would be interesting to know how old they are.
Stamp code is:
CYLD B5KL056.
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2625470
02/24/19 03:19 PM
02/24/19 03:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
CYLD B5KL056
CY = manufacturer = McCREARY Tire, Indiana PA
LD = size = F70-14
B5KL = type = fiberglass-belted w/RWL
056 = date = 05th week of 1996
Re: What wheels and tires originally came on my E body [Re: 6bblgt] #2625471
02/24/19 03:23 PM
02/24/19 03:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
how to post pics on MOPARTS scope
Re: What wheels and tires originally came on my E body [Re: 6bblgt] #2625480
02/24/19 03:37 PM
02/24/19 03:37 PM
FLPlum Offline OP
FLPlum  Offline OP
Thanks so much.
I don’t think they have any value, and they are way too old to drive on
Now on to why it won’t start. Starts with priming carb, but stops when fuel is used from priming.
Won’t start unless primed.
I started a new thread over in the general area.
Thanks.
Re: What wheels and tires originally came on my E body [Re: 6bblgt] #2625547
02/24/19 05:46 PM
02/24/19 05:46 PM
FLPlum Offline OP
FLPlum  Offline OP
OK, so I get to #4, and under box it say 3 files.
but they are not shown, is there a next step.
Re: What wheels and tires originally came on my E body [Re: 6bblgt] #2625548
02/24/19 05:47 PM
02/24/19 05:47 PM
FLPlum Offline OP
FLPlum  Offline OP
OK, so I get to #4, and under box it says 3 files.
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2625640
02/24/19 10:03 PM
02/24/19 10:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
they need to be added as part of a reply ------ type something in the box
if next to ----- File Manager (Total Files: 3) ------ you have added the pics
hit submit
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2625641
02/24/19 10:04 PM
02/24/19 10:04 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Thanks so much.
Thanks.
sounds like clogged fuel lines and/or bad fuel pump
Re: What wheels and tires originally came on my E body [Re: mccannix] #2625657
02/24/19 10:48 PM
02/24/19 10:48 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Originally Posted By mccannix
Dealerships would also do a lot to appease customers.
An original owner of a 70 Cuda 340 contacted me years back looking for a spacesaver spare for his car.
He told me, that when he took delivery he told the dealership salesman he wanted a conventional spare after seeing that 'donut' in the trunk.
They gladly did so.
My hometown dealership changed out a set of 14 inch rallyes off a new 72 Cuda replacing them with 14 inch magnums from a 72 Satellite because the then purchaser of the new Satellite, a former school classmate of mine, liked the rallye wheel look.
So occasionally, changes happened to new cars at dealerships before they even left the lot.
This happens more than people think. If you have ever worked at a new car dealership service department you will know this is not at all unusual.
Re: What wheels and tires originally came on my E body [Re: FLPlum] #2625660
02/24/19 10:53 PM
02/24/19 10:53 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The dates on the wheels for this Challenger convertible are really nice and everyone is warm and fuzzy, thats great. But is doesn’t prove what it came with from the factory with. How many years have people been seeking out proper dated parts for these cars? How many cars had custom wheels on day 2?
Re: What wheels and tires originally came on my E body [Re: 6bblgt] #2625676
02/24/19 11:37 PM
02/24/19 11:37 PM
FLPlum Offline OP
FLPlum  Offline OP
Here is a picture:
hit submit
Re: What wheels and tires originally came on my E body [Re: NANKET] #2625678
02/24/19 11:39 PM
02/24/19 11:39 PM
FLPlum Offline OP
FLPlum  Offline OP
Absolutely,
I have the car traced back to 1973.
Before that, who knows.
Although it was pretty original when I bought it in 2000.
Page 2 of 3 1 2 3
