Some questions about torque converters #2624078
02/21/19 03:50 AM
02/21/19 03:50 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
Up to this point, i have always been a stickshift guy my whole life believe it or not (aside from newer daily driver cars over the last 25 years or so). So, i am not familar at all firsthand with the details and habits of converters coupled to street/strip type cars. The car in question is a 73 charger with a reverse manual valve body. I dont know any specifics about it , other than it was built as a pro comp tranny by a guy here on the east coast named Freddy Brown. The paperwork states it is rated up to 650 hp as built. It came with a converter from his shop listed as s/s 3000-3500 stall. Thats it. It is a 10” unit.
It is going behind a newly built 440 based stroker with standard port stealth heads. Dynoed at 629 ft/lb at 3900 rpm and 609 hp at 6000 rpm.
My questions are: this is going to be mostly a street /highway cruiser and raced occasionally at the strip ( a million miles away crom us) a couple of times a year. What can i expect from a converter like this on the street as far as heat build up, issues, problems? Also highway on longer drives, will a typical converter like this build up too much heat with slippage? I have a nice b&m trans cooler mounted in front of rad isolated and i run the slightly deeper steel pan with extra quart capacity. I took off the real deep aluminum cast pan after i cracked it open in I78 on the way home from Carlisle a few years ago. Thats another crazy story!! Anything else i should know or be aware of?
Once i get the motor in, in a few weeks, i can test stall to see where we are at, but just ideas and info in general right now would be very helpful to me.
Thanks fellas.
Re: Some questions about torque converters [Re: Chargerfan68] #2624079
02/21/19 04:02 AM
02/21/19 04:02 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Sounds like it should be pretty dialed with that 10". They act a little slippery but drive and shift it just like a normal auto would shift. That is, never shift down unless there is throttle pressure. They can build some heat but cruise nice. I take it you're not climbing any mountains with it in New York?
Re: Some questions about torque converters [Re: Chargerfan68] #2624122
02/21/19 11:28 AM
02/21/19 11:28 AM
an8sec70cuda Offline
It'll be fine. W/ a cooler like you have, there shouldn't be any problems at all. Don't know him, but had Freddy Brown powerglides in a couple of grudge cars I helped my NY friend with. Seemed to be good stuff.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Some questions about torque converters [Re: Chargerfan68] #2624150
02/21/19 12:44 PM
02/21/19 12:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If I were the “project engineer”, in basic terms.........it would get as tight of a 9.5” or 10” converter as one of the more respected companies would build.
With that sized converter, behind that motor, in that weight car, with real street gears(3.23, 3.55, etc)........ even a really tight 9.5-10” unit will still stall at 3500-ish, or more.
Most off the shelf street units aren’t designed with 600+ Ft/lbs in mind.
If it wasnt built specifically for a stroker with that kind of torque, I’d just send it out now and have it adjusted before I bothered putting it in.
Re: Some questions about torque converters [Re: Chargerfan68] #2624153
02/21/19 12:54 PM
02/21/19 12:54 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What gears? Was the converter built for a stroker or for the 440?
Unless it was built with 600+ ft of torque in mind, I guarantee you it will flash much higher than 3,000-3,500. These torque monsters absolutely require a converter made just for them.
Before you stick it in, I would suggest that you find out all you can about who built the converter and to what spec. I have had my share of struggles getting a good converter for my street/strip strokers.
In case you need to make changes, it is much cheaper and easier to do it now. Lenny @ Ultimate finally got me a really good street/strip converter after several misses from other converter builders including PTC.
twocents
Master, again and still
Re: Some questions about torque converters [Re: Chargerfan68] #2624156
02/21/19 01:03 PM
02/21/19 01:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I agree
Boffin Emeritus
Re: Some questions about torque converters [Re: Chargerfan68] #2624215
02/21/19 02:43 PM
02/21/19 02:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
My experience with converter companies is that they can not predict how their finished units will perform. In the last 4 years I have filled out the forms for several major companies, and provided time slips, dyno sheets, and all the engine specs, everything they asked for. Not one of the companies spec'd the same size or type of converter, at over $1,000 I expect better than an educated guess. If the companies had it down to a science then I should get similar combinations from each company right? I have had several companies spec camshafts for example, and they almost always give me very similar choices. If you want the best performing converter be ready to buy and try several to get one that works with you combination. Just my experience.
Re: Some questions about torque converters [Re: Chargerfan68] #2624225
02/21/19 03:07 PM
02/21/19 03:07 PM
gregsdart Offline
gregsdart  Offline
If you value street drivability more than best ET,then a tight converter, similar to what a stock 383 roadrunner converter is, will be a good choice. The car will move out smartly when street driving without a lot of rpm, but obviusly more than a 383.
I have a 10 inch behind a 408 in a light Dart, supposed to be tight, flashes too high (4000) and feels like mush. Don't get me wrong, the car is very quick, i just don't like the loose feel. Many years ago i had a stock Hemi converter behind a 535 inch stroker, worked great for the handful of runs it survived. I think those converters were VERY similar to the 340 and 383 stock performance converters.
Re: Some questions about torque converters [Re: jwb123] #2624240
02/21/19 03:29 PM
02/21/19 03:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, and forum advice can be just as bad. Converters are black art.
Re: Some questions about torque converters [Re: Chargerfan68] #2624253
02/21/19 04:00 PM
02/21/19 04:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Find a GOOD converter company and give them GOOD quantifiable information and they will get it spot on. Give them inaccurate pie in the sky numbers and info then they will not get it right.
Re: Some questions about torque converters [Re: Al_Alguire] #2624271
02/21/19 04:20 PM
02/21/19 04:20 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Yep...smae UCC converter in my car for 12 years. I have made some changes and it's been fine...but...I may send it back this year to have it massaged a bit for the extra HP this motor makes compared to the rest I've had in the Arrow.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Some questions about torque converters [Re: Chargerfan68] #2624364
02/21/19 07:53 PM
02/21/19 07:53 PM
New York, USA
New York, USA
Thanks for all the good info and advice so far. The only other info that i can think of is weight is 4240 lbs with driver. Rear gears will be 3.23 for street/highway trips, and 3.91 for track. 8-3/4 rear. I will be running drag radials 28 “ tall.
Only actual numbers i have are dyno numbers. They are as follows:
Rpm. Tq. Hp
3900. 609.7. 452.7
4000. 608.3. 463.3
4100. 610.6. 476.7
4200. 613.1. 490.3
4300. 621.1. 508.5
4400. 625.5. 524.1
4500. * 629.6. 539.5
4600. 628.6. 550.6
4700. 625.4. 559.7
4800. 622.0. 568.4
4900. 619.1. 577.6
5000. 616.3. 586.8
5100. 611.7. 594.0
5200. 605.8. 599.8
5300. 599.4. 604.9
5400. 592.6. 609.3
5500. 581.4. 608.8
5600. 571.2. 609.0
5700. 561.3. 609.2. *
5800. 550.7. 608.2
5900. 540.3. 607.0
6000. 531.3. 607.0
6100. 515.7. 600.6
Avg. 602.07. 559.43
So, peak torque is at 4500 rpm. Does that chang anything? I guess for strictly racing, i woukd want a 4500 stall, but for combo driving, what woukd you guys be looking for? Aside from calling and having one built, or my 10” adjusted. I will do that, but trying to understand the fundamentals and theory of it.
If i can think of any other info, ill add it
Re: Some questions about torque converters [Re: Chargerfan68] #2624368
02/21/19 08:03 PM
02/21/19 08:03 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
what cam is in the motor?
does the motor have a 4.25" stroke?
Re: Some questions about torque converters [Re: Chargerfan68] #2624402
02/21/19 09:32 PM
02/21/19 09:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If you already have the stuff, just send it! That kind of power overcomes a lot of things that aren't perfect. It will be ultra fun to drive. It will use a truckload of gas.
Re: Some questions about torque converters [Re: Dave Hall] #2624408
02/21/19 09:48 PM
02/21/19 09:48 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
If that converter wasn't built for the level of torque his motor is putting out won't it cause the TC to stall way too high? Sounds like the issue I was having towards the end of last season. I have a 10" converter that was built for use behind a small block and I when built the 512 I reused it. Chassis dyno results were lackluster as the torque curve wasn't flat at all behind the peak number. Still hashing it out...
Re: Some questions about torque converters [Re: Chargerfan68] #2624422
02/21/19 10:10 PM
02/21/19 10:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
Really nice looking power curve😎
Re: Some questions about torque converters [Re: Chargerfan68] #2624425
02/21/19 10:11 PM
02/21/19 10:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You really don't need to fill out a tech sheet for this application. Just have the converter built as tight as possible. With over 4,000lbs, 3.23 gears, 600+ lbs of torque, and street driven, you can't get it too tight with the 10" converter cores available.
Now, if it were a track car trying to hit the number, it would be a different story. But being primarily a street car, it won't be too tight. In fact, I would be surprised if you can get a converter that would flash below 4,000 with that combo and a little traction. I haven't been able to.
Re: Some questions about torque converters [Re: Chargerfan68] #2624426
02/21/19 10:12 PM
02/21/19 10:12 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Put it together, enjoy it, fine tune it later if you start chasing ET's.
Re: Some questions about torque converters [Re: Chargerfan68] #2624520
02/22/19 12:31 AM
02/22/19 12:31 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
FWIW, I daily (couple times a week anyway) drive a car with a converter that "flashes" to 4,100. All the control is under your right foot.
Re: Some questions about torque converters [Re: krautrock] #2624547
02/22/19 01:42 AM
02/22/19 01:42 AM
New York, USA
New York, USA
It does have the 4.25” stroke. The cam was speced out by “The Wizard” Dwayne Porter. Well thats what i call him. Thank you Dwayne!! It is a solid roller with lift of .577 / .583 and 248 / 254 @ .050
