Page 1 of 3 1 2 3
Suspension Resto progress and experimentation..... #262312
03/22/09 08:54 PM
03/22/09 08:54 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I've been in the process of restoring my suspension on my A12. This is the first time I've really tried to do a more authentic resto than just POR paint and rattle cans.
I cleaned/blasted my LCA's then painted them with Seymours Stainless steal paint. (i know, its rattle can!) Then found this product called Weathershed that is cosmoline in a can. I sprayed for about a week 2-3X a day with letting it dry in between. 1 can did both arms.
Tell me what you think. Still have paint daubs to go.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262313
03/22/09 08:57 PM
03/22/09 08:57 PM
MO
cdp Offline OP
cdp  Offline OP
MO
The struts were rusty as usual and I soaked them in a 2" pipe filled with Evapo-rust. Man that is some impressive stuff. They look like new and only soaked for a day. I took them out and scrubbed them with a plastic bristle brush a few times during the soak.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262314
03/22/09 09:02 PM
03/22/09 09:02 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I found these products by accident online. To buy direct, I had to buy a case of 12, but they allowed me to mix and match.
The "cosmoline" is actually a penetrating oil.
The "rust veto" is a dry film protectant. Like MP50.
The "weather shed" is the cosmoline like we all look for. A heavy wax base product.
Cost with shipping was about $7.00 a can.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262315
03/22/09 09:18 PM
03/22/09 09:18 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Looks great.. Much better than mine.. If I was going to do it over again, I would have done it straight from this stuff.. Have a can, but didn't have the patience...
Look forward in seeing your next step...
Troy
Houston Mopar Connection Club
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262316
03/22/09 09:18 PM
03/22/09 09:18 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I soaked these parts in Saferustremovel.com's product and I have to say I was again impressed with the results. These were just a little cruddy and had surface rust. A soak for about 3 hours had them all cleaned up.
I sprayed Rust Veto on them to keep them from flashing.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262317
03/22/09 09:20 PM
03/22/09 09:20 PM
MO
cdp Offline OP
cdp  Offline OP
MO
after soak.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262318
03/22/09 10:23 PM
03/22/09 10:23 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Great thread!
why didnt you use the Evapo-rust again?
Re: Suspension Resto progress and experimentation..... [Re: LimeliteAero] #262319
03/23/09 07:57 AM
03/23/09 07:57 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I ordered the saferustremover, then, by chance, I was at Harbor Freight and they had Evapo-rust. So I decided to do some experimenting.
I think the evapo rust is a little more aggressive and I soaked my struts and drag link in it. In the end, I think they both work well.
Since Saferustremover is "green", I ordered more to soak me brake pedal assembly and Ebrake assemly in.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262320
03/23/09 08:42 AM
03/23/09 08:42 AM
cataclysm80 Offline
cataclysm80  Offline
looks good, keep posting please.
Tav
Re: Suspension Resto progress and experimentation..... [Re: cataclysm80] #262321
03/23/09 09:36 AM
03/23/09 09:36 AM
Houston, Tx
Houston, Tx
Chris..
Great information and good idea on the e-brake mechanism and pedal assembly. I'm in need of addressing these soon on my '68 to get them back in the car...
Troy
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262322
03/23/09 07:14 PM
03/23/09 07:14 PM
PA
BS27ROB Offline
BS27ROB  Offline
PA
What do you mean by more aggressive? Faster acting or does it affect the original surface appearance in some way?
Thanks Cy
Re: Suspension Resto progress and experimentation..... [Re: BS27ROB] #262323
03/23/09 08:06 PM
03/23/09 08:06 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I really can't tell. Both say they are biodegradable and non toxic. The Evapo Rust has a bit of a chemical smell. Maybe its so people can tell your not suppose to drink it. The other stuff is oderless and colorless. From what I can tell, they both work equally well.
Here is my drag link before and after as well as a side by side comparison on some door hardware.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262324
03/23/09 08:09 PM
03/23/09 08:09 PM
MO
cdp Offline OP
cdp  Offline OP
MO
just pulled it out after work today. Its basically been in for 24 hours. I think it was OK to take out this morning, but didn't have time.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262325
03/23/09 08:17 PM
03/23/09 08:17 PM
SE Pa.
SE Pa.
how often do you need to use fresh solvent?
Do you think its safe to be submerging the tie rod ends?
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262326
03/23/09 08:21 PM
03/23/09 08:21 PM
MO
cdp Offline OP
cdp  Offline OP
MO
one more. The tie rod ends are the originals with the factory knock of zerks.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262327
03/23/09 08:26 PM
03/23/09 08:26 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I think the tie rod ends will be fine. One of them is bad and needs replaced. I have noticed that the solution had alot of grease in it. I used a whole gallon to do these and am soaking more right now. Its pretty dirty, so I think you should spend quit a bit of time cleaning with Mean Green (i get at the dollar general along with $1 cans of oven cleaner). I didn't get the tie rod end sleeves clean enough before derusting.
This is what I have soaking now.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262328
03/23/09 08:27 PM
03/23/09 08:27 PM
MO
cdp Offline OP
cdp  Offline OP
MO
and these....
The directions say keep reusing it until the activation power is lost.
I thought about using muratic acid thats diluted, but its some pretty nasty stuff.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262329
03/23/09 08:49 PM
03/23/09 08:49 PM
MO
cdp Offline OP
cdp  Offline OP
MO
my rusty assembly...after tear down.
Re: Suspension Resto progress and experimentation..... [Re: cdp] #262330
03/23/09 09:13 PM
03/23/09 09:13 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I find this interesting I've never really heard of this stuff before. I've used muratic acid with great results, but if the parts are not attended t right away they will flash rust pretty quick.
Two Questions:
What do you rinse the parts with after soaking?
Will the parts flash rust?
CHECK OUT MY NEW WEB SITE !
Re: Suspension Resto progress and experimentation..... [Re: anlauto] #262331
03/23/09 09:25 PM
03/23/09 09:25 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Parts will flash right away. The pics I took after work today were basically flash rusting during the pics.
I neutralized with water and let dry. The wind is blowing at about 40mph right now, so it was a quick air dry.
I followed up by using the Rust Veto. If I need to paint later on or something, I can resubmerge or clean off the Rust Veto with lacquer thinner.
Page 1 of 3 1 2 3
