Re: 2.15 int. Valve too big for 318 @30 over? [Re: 1DGEMAN] #2623719
02/20/19 02:58 PM
02/20/19 02:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By 1DGEMAN
I'm pretty sure that is the difference on the ProMAXX 63 and 65 CC heads. The 65 have a little more room for the positive height pistons. I think the Edelbrock do the same, hence the 340 version?
So the 65cc heads are an open chamber design to clear the piston. The only pics i could find of them looked like closed chambers but maybe that was a generic pic?
[/quote]
One phone call will give you better answers than any of us can give you. He kindly answered every question I had for him and if I was still in the head porting business I would have grabbed a few sets.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 2.15 int. Valve too big for 318 @30 over? [Re: roadrunninMark] #2623890
02/20/19 08:06 PM
02/20/19 08:06 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
If you scroll through the pics at the top of the page it shows two chamber designs. I'm not smart enough to know if the one is big enough to clear a 340 piston with the right head gasket thickness. However, it seems silly to go through all the work of having two designs with 2cc difference if not. Maybe I'm all wet so call first as suggested.
https://promaxxperformance.com/product/shocker-185-mopar-cnc/
Re: 2.15 int. Valve too big for 318 @30 over? [Re: roadrunninMark] #2624546
02/22/19 01:40 AM
02/22/19 01:40 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Seems that the 340 piston was .018 or so above the deck, why not just run a .054 fel pro and have .036 quench distance? If that nu number is not exactly right you can order different thickness gaskets from different places but I am sure that .018 is close.
