Re: Need more rear spring [Re: mickm] #2623148
02/19/19 12:32 AM
02/19/19 12:32 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If you are completely satisfied with the ride quality and spring rate of your present set up, do not add a leaf.
If the only complaint is it has sagged an inch. Get them rearched to sit 1 in higher.
Adding a leaf will significantly increase the spring rate, which is not spring height. Which is okay if that is also what you want
For something that all Mopar experts understand. We don't change to a thicker torsion bar if we ONLY want to change ride height. We change the position.
Re: Need more rear spring [Re: DaveRS23] #2623180
02/19/19 01:26 AM
02/19/19 01:26 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The Hellwig part number for the helper springs that I use is 1265EZ. Now that is for 4 identical helper leafs that go on the front segments and on the rear segments. I only use them on the rear segments. Which means that that part number will do two cars. If they are available as a pair of springs rather than four, I don't know.
I have pics of the way I have them mounted on my Cuda, but without Photbucket, I can's figure out how to post them. If anyone wants the picture, shoot me an E-mail and I can send them that way.
As to any change in the ride with the helper springs, I didn't notice it much. The Cuda rides a bit stiff in the rear anyway, so it wasn't a big difference.
P.S. I hit the archives on how to post them and couldn't get them up like that either. shruggy
Master, again and still
Re: Need more rear spring [Re: DaveRS23] #2623451
02/19/19 09:19 PM
02/19/19 09:19 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
These are DaveRS23's pictures of the Hellwig kit on his Cuda.
Mike.
Re: Need more rear spring [Re: mickm] #2623624
02/20/19 10:42 AM
02/20/19 10:42 AM
Torq37 Offline
Torq37  Offline
Thanks. So the adjustment is in the preload on the U-bolts. You are one step ahead of me on flipping the rear U-bolt to hide the installation.
I'm wondering if the 550EZ set is possibly one half of the 1265EZ set.
Re: Need more rear spring [Re: Torq37] #2623641
02/20/19 11:52 AM
02/20/19 11:52 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Yes, the Hellwigs have enough lift that the rear clamp can be used as an adjustment. The only mod I needed to do was to take a long bolt, cut the threads and head off, and weld the shank on the flat plate so that it would lay in the lip of the spring.
There may be cheaper brands of helper springs. But the Hellwigs are known good quality. These have been on this car several years.
Besides, I bought this particular set off Amazon as a re-box for $35.
Re: Need more rear spring [Re: mickm] #2626982
02/28/19 02:46 AM
02/28/19 02:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You could do what I did. When I put my SS springs on years ago my 63 actually sat about 1" lower then what I wanted. So I bought some aftermarket shackles from Mr Gasket I believe. I compared the holes as they have about 5 holes to choose from for more height and I selected the one that I felt would raise it a bit. It worked perfect and then I cut the extra shackle off and rounded the edges a bit to make them look stock. And that's because I hate to see a longer shackle hanging under our Mopars. Its been like that since 2008 when I installed the springs. You can see in this pic they look like stock shackles. Ron
Re: Need more rear spring [Re: mickm] #2626984
02/28/19 02:47 AM
02/28/19 02:47 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
And this is how my car still sits just how I like it. Ron
Re: Need more rear spring [Re: 383man] #2627107
02/28/19 02:37 PM
02/28/19 02:37 PM
moparx Offline
moparx  Offline
i just love that side shot ron ! up
beer
Re: Need more rear spring [Re: mickm] #2627161
02/28/19 05:09 PM
02/28/19 05:09 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted By mickm
Originally Posted By jcc
Nothing to add, but you are the world travel writer, correct?
Anything forthcoming? work
Nothing new, but this is what I'm up to...
Interesting up , but for me, only in a younger day, looks like I'll stick to reading. biggrin
Re: Need more rear spring [Re: moparx] #2627420
03/01/19 10:35 AM
03/01/19 10:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
beer
Thank you. wave Ron
