Page 2 of 3 1 2 3
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620655
02/13/19 04:00 AM
02/13/19 04:00 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Food for thought: If I were looking for something “trick” in a Mopar front suspension, I’d sure be talking to the super stock chassis guys before I’d talk to any parts peddlers that are clueless about what they sell.
Mandella, Keir and such have forgotten more about FAST Mopar suspensions that most will ever know.
Re: MAGNUM FORCE WHAT THE ???? [Re: WHITEDART] #2620708
02/13/19 10:52 AM
02/13/19 10:52 AM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Originally Posted By WHITEDART
Originally Posted By n20mstr
Called on Nov 19th, ordered drop spindles and upper control arms. Paid in full.
As of today, NO product delivered, NO email answered, NO phone call returned.
Get an answering machine ??
About to just get the money back from my bank and buy the stuff from someone else
I'm not a front-end Guru but would it be possible to get enough adjustment out of adjustable upper control arms to get things. Adjusted and low enough without using a drop spindle.. or would shock length become an issue I wouldn't think you would require much travel upfront
Upper control arms will fix it for sure. I wanted to get the Magnumforce ones that are double adj. But now so turned off im about to dispute the charge with my bank and get the money back that way.
I use as much front travel as I can get, control it with the shocks. I have Santuffs up front.
....BAD A$$ STREET CAR.....
Re: MAGNUM FORCE WHAT THE ???? [Re: cudadoug] #2620709
02/13/19 10:54 AM
02/13/19 10:54 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
In theory sounds good, BUT these guys usually don't hand that info out so easily. I have crawled under some SS Hemi darts and Cudas. You can tell that the front has been fudged with, but it does still look like "stock" parts as NHRA requires.
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620720
02/13/19 11:50 AM
02/13/19 11:50 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I know one example of a Gerst set-up in an A-Body that had flexing issues... tsk
JB Rhinehart, Realist
A-Body's RULE!
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620725
02/13/19 12:04 PM
02/13/19 12:04 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
was it yours ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620822
02/13/19 03:48 PM
02/13/19 03:48 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Most, if not all, tubular upper control arms are built with additional caster in them. The only real advantage of the MF double adjustable is they can be adjusted on the car without taking them apart. If you buy heim ended arms, you should be able to rough in extra caster over stock prior to assembly and use the eccentrics to finalize it. Once its set, you likely won't be changing it regularly anyway.
But, you could look also at SPC if you want the on car adjustability.
https://www.spcalignment.com/component/content/article?id=370
Other places sell the drop spindles too, like Firm Feel, PST, and probably a few others.
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620876
02/13/19 06:03 PM
02/13/19 06:03 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
What do drop spindles do, I'm ordering the RMS or Gerst front end this week.
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620879
02/13/19 06:05 PM
02/13/19 06:05 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Drop spindles lower the front of the car
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2620889
02/13/19 06:25 PM
02/13/19 06:25 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Magnum Farce is the HARBOR FREIGHT of suspension components.
Re: MAGNUM FORCE WHAT THE ???? [Re: bigdad] #2620953
02/13/19 09:09 PM
02/13/19 09:09 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Thanks I thought if the spindles were dropped it would raise the car.
My bad.
I need taller front tires to get oil pan clearance.
So that's out. Thankyou
Re: MAGNUM FORCE WHAT THE ???? [Re: Kern Dog] #2620968
02/13/19 09:33 PM
02/13/19 09:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
At their pricing? work
I was thinking more Bernie Madoff.
Actually I wish them no malice, but one has to admit, they got the "sizzle" and marketing happening.
Re: MAGNUM FORCE WHAT THE ???? [Re: jcc] #2620988
02/13/19 10:01 PM
02/13/19 10:01 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
Hey Tony, doesn't QA1 sell tubular A arms? on another note a friend of mine actually from your neck of the woods bought a MF tubular front end for his big block Dart years ago and had many problems with the installation. Its actually in another friends Dart now but again it took some mods to make it work.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2621056
02/13/19 11:58 PM
02/13/19 11:58 PM
AndyF Offline
AndyF  Offline
Your deposit was spent on hair care products.....
Re: MAGNUM FORCE WHAT THE ???? [Re: AndyF] #2621119
02/14/19 03:04 AM
02/14/19 03:04 AM
cudadoug Offline
cudadoug  Offline
OMG...That was Funny!
Re: MAGNUM FORCE WHAT THE ???? [Re: AndyF] #2621129
02/14/19 03:27 AM
02/14/19 03:27 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
AND T-shirts that are a size or two smaller than he should be wearing.
Re: MAGNUM FORCE WHAT THE ???? [Re: AndyF] #2621137
02/14/19 03:50 AM
02/14/19 03:50 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mopar Fabio! laugh2
Re: MAGNUM FORCE WHAT THE ???? [Re: n20mstr] #2621178
02/14/19 10:52 AM
02/14/19 10:52 AM
Washington
madscientist Offline
Washington
Damn you guys are BRUTAL! Truthful, but brutal.
Re: MAGNUM FORCE WHAT THE ???? [Re: AndyF] #2621204
02/14/19 11:53 AM
02/14/19 11:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Oh Andy.... so technical, so serious. Then this falls out! laugh2
Re: MAGNUM FORCE WHAT THE ???? [Re: J_BODY] #2621236
02/14/19 01:07 PM
02/14/19 01:07 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Was thinking the same thing Jay. had to do a double take on who posted it. LOL.
69 GTX 68 Road Runner
Re: MAGNUM FORCE WHAT THE ???? [Re: 11secdart] #2621316
02/14/19 03:32 PM
02/14/19 03:32 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
QA1 does make tubular arms, upper and lower for that matter, but they are the bushing style upper arms. I believe MF, Hotchkis, and SPC are the only companies out there making units that can be adjusted on the car. One could make a set with swedged tubes and ball joint plates from the Speedway Motors catalog, but this would require changing the arm mounting style to a through stud arrangement like a GM.
Page 2 of 3 1 2 3
