Where to get these headlight door harness clips: 71 Charger #2620761
02/13/19 01:44 PM
02/13/19 01:44 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Is there a source for these 2 headlight clips? I've looked at all the usual places but can only find smaller clips for Cuda harness.
I have the one bolt-on clip but missing the other twothat are in 2nd. picture.
Is used the only way?
Thanks in Advance
Ron
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621001
02/13/19 10:25 PM
02/13/19 10:25 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Evening crowd??
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621010
02/13/19 10:46 PM
02/13/19 10:46 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I think Richard O'Shields might have them. I think his screen name on dodgecharger.com is 69Bfan.
inherited a 69 roadrunner from my grand pop.
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621044
02/13/19 11:40 PM
02/13/19 11:40 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
I do not make the ones that are pictured above. You might check Todd Hoffman's Winners Circle web site as he provides a variety of specialty clips. Like you said, it is probably going to mean finding good used samples. Good luck, if you find extras, I would be interested in seeing one if you should want to sell one for the sake of making samples.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Where to get these headlight harness clips: 71 Charger??? [Re: 69bfan] #2621061
02/14/19 12:30 AM
02/14/19 12:30 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Thanks guys, hopefully this post will shake some trees!!!
Ron
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621067
02/14/19 12:53 AM
02/14/19 12:53 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Thanks for bringing this up. I have found the bolt on one but could never find the other two. Would really like to get them if they were reproduced. Nice to know that I am not the only one in need. There are plenty of 71-72 charger SE’s, superbee’s and RT’s out there that would appreciate these detail items.
Re: Where to get these headlight harness clips: 71 Charger??? [Re: 340cpe] #2621102
02/14/19 02:29 AM
02/14/19 02:29 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Are they specific to the 71 to 72 Dodge B-Body applications or is it possible that they were used on the 71 to 72 Plymouth B-Body applications as well. The more applications that they were used in will impact the feasibility of reproducing them.
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621154
02/14/19 05:29 AM
02/14/19 05:29 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Not used on Plymouths.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621155
02/14/19 05:37 AM
02/14/19 05:37 AM
moparmarks Offline
moparmarks  Offline
I'm thinking all of those harness holders on for hide away headlights only.
Standard headlight and Plymouths the harness runs across the top of the core support and doesn't have any of those holders.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Where to get these headlight harness clips: 71 Charger??? [Re: moparmarks] #2621228
02/14/19 12:57 PM
02/14/19 12:57 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Mark you were the next guy I was going to ask if you had a couple??
Ron
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621458
02/14/19 11:00 PM
02/14/19 11:00 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Mark you are correct they are hideaway only, hence the SE, SuperBee and RT. The harness it supports is for the motor that operates the headlight doors, not the headlights.
Re: Where to get these headlight harness clips: 71 Charger??? [Re: 340cpe] #2621479
02/15/19 12:13 AM
02/15/19 12:13 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Jimmy Boros probably has some
Re: Where to get these headlight harness clips: 71 Charger??? [Re: mopargem] #2621489
02/15/19 12:23 AM
02/15/19 12:23 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Good idea!
Ron
Re: Where to get these headlight door harness clips: 71 Charger [Re: RJS] #2621490
02/15/19 12:25 AM
02/15/19 12:25 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Is one in the top photo the same as the one on the left in this photo?
Wire loom clips
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621609
02/15/19 11:59 AM
02/15/19 11:59 AM
moparmarks Offline
moparmarks  Offline
Ron
Sorry I don't
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Where to get these headlight harness clips: 71 Charger??? [Re: RJS] #2621610
02/15/19 12:00 PM
02/15/19 12:00 PM
moparmarks Offline
moparmarks  Offline
Good idea!
Ron
Yep Jimmy is your best bet.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Where to get these headlight door harness clips: 71 Charger [Re: Mattax] #2621622
02/15/19 12:37 PM
02/15/19 12:37 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I'm going to say not but I've never held the proper clip in my hand. I went back and forth between my and your picture.
Ron
Re: Where to get these headlight door harness clips: 71 Charger [Re: RJS] #2621631
02/15/19 12:49 PM
02/15/19 12:49 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Jimmy says he has two for me but he's away until the weekend so I'll wait and see.
Thanks everyone
Ron
