Page 4 of 7 1 2 3 4 5 6 7
Re: Small Block vs Big Block [Re: n20mstr] #2620357
02/12/19 05:51 PM
02/12/19 05:51 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Originally Posted By n20mstr
Originally Posted By scottb
Whitedart has be 5:30 on motor I’m sure he could run 4:7-4:8 on spray he and Brett have both those small block making some awesome power
Do you really understand what your saying?? These guys are making awesome NA hp, BUT its not that easy to just bolt on a plate and pick up 6tenths in the 1/8 let alone carry the weight and run on the 275 tire that Ultra street requires.
Maybe I shouldn't comment on this topic because im looking at it only from my narrow minded view of heads up small tire race cars. AND in that im saying where are all the fast Mopars...There are none ! THE only fast small tire car so far we can name here is Rob Goss.AND yes its a smallblock, but its a gen 3 hemi, not the "smallblock" that I think the OP was referring to.
Small block cars, I can say the ones I see that are wicked fast, Leon, Bill May...and ??
even at that im sure imleaving people out that are fast, but what do you consider "fast" I ask that because this is moparts...LOL Fast to me is 4.XX and even that I don't think Bill or Leon have done.
Flame on ! !
under West Coast rules you would have to weigh 3500 lb limited to two solenoids and a dash 4-line not a cheater line... I used to drag the big block shitro let's on spray.Completely different rules and I don't think this is about power adders we all know that your car is badass and leave it at that.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small Block vs Big Block [Re: n20mstr] #2620358
02/12/19 05:58 PM
02/12/19 05:58 PM
bean town ....Ca
W
W
bean town ....Ca
Flame on ! !
... in my opinion my car is not fast enough I will continue to work on it and it was never the subject it was small block vs Big Block.. there is a s*** ton a four second small Tire cars in this country only a handful of fast N/A cars.. look at the heads-up classes back East you will have five power Adder classes a total of God knows how many cars and only one naturally-aspirated class with maybe five cars or 10 why is that
Re: Small Block vs Big Block [Re: WHITEDART] #2620359
02/12/19 06:03 PM
02/12/19 06:03 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Flame on ! !
power adder is the "easy button" LOL
NA takes a lot more finesse and you have to actually use ALL the power you have. It is rare to see people go really fast NA because its a lot more work (at least my opinion) It is sad that more people don't race Mopars heads up. WIth the tall deck height and great heads available I just don't understand why you don't see more Small block mopars… It seems to me to be a way better platform than a big block. AND thanks for the compliment, but I consider my car slow, for now at least
....BAD A$$ STREET CAR.....
Re: Small Block vs Big Block [Re: n20mstr] #2620372
02/12/19 06:15 PM
02/12/19 06:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Some of the fastest mopar door cars I have seen in person have been SB powered with W series heads. One was a 70 Challenger that had a repurposed older Nascar engine. He changed the cam and made a dual 4 sheetmetal intake etc. The sound this engine made turned heads the moment it hit the water box.
Re: Small Block vs Big Block [Re: WHITEDART] #2620436
02/12/19 07:39 PM
02/12/19 07:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Any heads up stuff is a money pit. But N/A heads up, wow? Comp and Aussie Pro Stock have the most powerful SB's in the world. The cost isn't even on the same page as anything being discussed here. Neither is the longevity. There hasn't been a B-1 in Comp for years. There have been a scattering of SB Mopar but shortage of good blocks is an issue.
Doug
Re: Small Block vs Big Block [Re: WHITEDART] #2620457
02/12/19 08:03 PM
02/12/19 08:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
That's why there are limits on turbo and blower size: to keep you buying those $$$ N/A parts.
Boffin Emeritus
Re: Small Block vs Big Block [Re: polyspheric] #2620564
02/12/19 11:29 PM
02/12/19 11:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
And those $$$ n/a parts would be?
Re: Small Block vs Big Block [Re: WHITEDART] #2620717
02/13/19 11:36 AM
02/13/19 11:36 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Really - you don't know what I mean?
Boffin Emeritus
Re: Small Block vs Big Block [Re: polyspheric] #2620957
02/13/19 09:19 PM
02/13/19 09:19 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
I just like this sound 🙃
https://youtu.be/QfiwYYn4KQA
Re: Small Block vs Big Block [Re: W5DART66] #2621009
02/13/19 10:43 PM
02/13/19 10:43 PM
bean town ....Ca
W
W
bean town ....Ca
love the sound of it too
Re: Small Block vs Big Block [Re: WHITEDART] #2621034
02/13/19 11:24 PM
02/13/19 11:24 PM
Washington
madscientist Offline
Washington
That's how it should sound. Like old modified eliminator stuff. Very nice.
Re: Small Block vs Big Block [Re: WHITEDART] #2621050
02/13/19 11:46 PM
02/13/19 11:46 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
N/A 10.5 RULES.. these rules are somewhat to help keep the field level..
that is only part of the rules, the rest of the rules dictate the required weights for big block as well as small block combinations.
To keep the field level Big Blocks have to weigh more than small blocks at the same cubic inch.
SMALL BLOCK BASE WEIGHT (max cubic inch 470)
300 = 2400 + Over 300 add 1.25 lbs. per cubic inch
340 = 2450 + Over 340 add 2.50 lbs. per cubic inch
360 = 2500 + Over 360 add 2.75 lbs. per cubic inch
380 = 2555 + Over 380 add 2.70 lbs. per cubic inch
400 = 2609 + Over 400 add 2.65 lbs. per cubic inch
420 = 2662 + Over 420 add 2.60 lbs. per cubic inch
440 = 2714 + Over 440 add 2.55 lbs. per cubic inch
460 = 2765 + Over 460 add 2.50 lbs. per cubic inch
470 = 2815
BIG BLOCK BASE WEIGHT (max cubic inch 640)
440 = 2860 + Over 440 add 2.60 lbs per cubic inch
460 = 2900 + Over 460 add 2.55 lbs per cubic inch
480 = 2940 + Over 480 add 2.50 lbs per cubic inch
500 = 2990 + Over 500 add 2.45 lbs. per cubic inch
520 = 3039 + Over 520 add 2.40 lbs. per cubic inch
540 = 3086 + Over 540 add 2.35 lbs. per cubic inch
560 = 3133 + Over 560 add 2.25 lbs. per cubic inch
580 = 3178 + Over 580 add 2.10 lbs. per cubic inch
600 = 3220 + Over 600 add 2.00 lbs. per cubic inch
620 = 3260 + Over 620 add 1.80 lbs. per cubic inch
640 = 3296
Even with the deduction of 125 lbs the big block still has to weigh slightly more than the small.
Not sure if I agree but the example of the N/A class would suggest that Big Block are quicker per cubic inch.
76 Duster work in progress
Re: Small Block vs Big Block [Re: W5DART66] #2621401
02/14/19 08:06 PM
02/14/19 08:06 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Love the sound of a high winding small block
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Small Block vs Big Block [Re: WHITEDART] #2621402
02/14/19 08:15 PM
02/14/19 08:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
So, the best engineer using the best parts and most experience and driving skill shouldn't win?
Level field: heads up.
Anything else: give your friends* an advantage. NHRA started doing it in the 1950...
* important sponsors, people with money - like NASCAR
Boffin Emeritus
Re: Small Block vs Big Block [Re: WHITEDART] #2621433
02/14/19 09:52 PM
02/14/19 09:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
In any MAX EFFORT deal power per cube is ALWAYS going to be a SB end of discussion. Anyone who thinks different is in denial period!! It aint just a Mopar thing it is a thing for all. Look no farther than a class like Comp or NA 10.5
Ultimate NA power, again MAX EFFORT it is always going to go to the BB hands down end of discussion!!
As for NA10.5 rules. those weights listed are just the BASE weights. There will be adds and minuses depending on combo. They get way more into the weeds than most on Moparts will care to know. Rules are in place to try and level the playing field and in our class are ever evolving, as racers are ever pushing.
A BB Chrysler only gets a weight break for a TRUE wedge head. A 600-13 head would actually get a weight penalty for its NON STOCK bore space, we also have a weight structure tier that takes into account distance from the deck to the intake port. As most everyone runs heads that are extensively modified from stock.
Chris went 8.40's in the Cuda with the B1. Eventually I went 7.90's at 171 with the same engine after some updates at 2975.
Re: Small Block vs Big Block [Re: WHITEDART] #2621599
02/15/19 11:23 AM
02/15/19 11:23 AM
Washington
Washington
Al is correct. HP/CID will always favor the SB. BUT... At equal displacement the bigger bore will ALWAYS make more power. Always. I don't even know why this is argued.
If you can run a small displacement BB or a big displacement BB I'm picking the BB every single time. I don't give a single crap what the HP/CID is.
I'll always take the biggest bores, the widest bore spacing and the biggest intake valve I can get. That makes horsepower. And horsepower always wins...if you can get it to hook.
Look at the turbo guys switching to big singles. They don't have to pull as much power out down low as the big single turbo doesn't make as much power down low.
Re: Small Block vs Big Block [Re: WHITEDART] #2621627
02/15/19 12:40 PM
02/15/19 12:40 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
what Bore,stroke combo are the top fuel Hemis?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Small Block vs Big Block [Re: ric3xrt] #2621675
02/15/19 02:29 PM
02/15/19 02:29 PM
Washington
Washington
Fuel is a liquid bomb. Fuel hates big bores. Fuel engines use small bores and long strokes because of the detonation prone nitro.
What the hell does a blown fuel burning engine have to do with a N/A anything?
Re: Small Block vs Big Block [Re: WHITEDART] #2621677
02/15/19 02:33 PM
02/15/19 02:33 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Just asking..
Re: Small Block vs Big Block [Re: ric3xrt] #2621682
02/15/19 02:39 PM
02/15/19 02:39 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Most are as follows:
4.200" bore
4.500" stoke
499CID
But again they have nothing to do with HP in a N/A motor
55lbs of boost running 100% Nitro
The cylinder wall need to be extremely thick to make sure they stay round and they don't break.
One Cylinder makes more HP than most complete N/A engines
