98 Ram 5.9 no oil press UPDATE
#2620675
02/13/19 06:41 AM
02/13/19 06:41 AM
Posts: 6,847 Missouri
StrokerPost
Missouri
The other day, when it got way below zero here, when I started up my 98 Ram I noticed after several seconds that the oil press gauge was still on zero. I tapped on the cluster cover thinking possibly from the cold it might be stuck, it wasn't. I quickly shut it off and got out to look at the oil on the dipstick. It was right on the full mark, as if it had not been running. Im certain that shouldn't be the case, but I decided to start it (yeah I know) and check it while running and it was exactly the same, so I shut it off knowing its not pumping oil. The strange part, to me anyway, is that the motor sounded completely normal, no ticking, knocking or rattling from anywhere. Any other motor ive heard with no oil press it was immediately obvious. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Given its very close to 300K miles, im sure the pump end of the intermediate shaft it worn, possibly to the point where it rounded off that morning with the thick oil from the cold, or it just broke off. QUESTION: Does that sound feasible, and how would I verify that that's what has happened? The only ways I can think of is either pull the pan and drop the pump, or pull the distributor and try to fish out the shaft. Either one is a pain in the backside. If you have any input, suggestions or experiences with this Id REALLY like to hear from you. I need this truck back up soon! Thanks, Ken
Re: 98 Ram 5.9 no oil press
[Re: StrokerPost]
#2620679
02/13/19 07:21 AM
02/13/19 07:21 AM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
Put a mechanical gauge on it before you do anything. Pump drives breaking or wearing out is something I've rarely seen unless debris locked up the pump.
[Re: Guitar Jones]
#2620704
02/13/19 10:36 AM
02/13/19 10:36 AM
Posts: 10,167 A Red State
SNK-EYZ
A Red State
Put a mechanical gauge on it before you do anything. Pump drives breaking or wearing out is something I've rarely seen unless debris locked up the pump. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Until you put a mechanical gauge on it you really don't know what the oil pressure is.
