Re: Long rams vs modern dual planes [Re: ScottSmith_Harms] #2621378
02/14/19 06:23 PM
02/14/19 06:23 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Originally Posted By ScottSmith_Harms
Peak HP was 410 at 5,000, 421tq. It started falling off steadily past 5,000 rpm but the torque curve was very long and flat.
That's exactly what I'm looking for.
Consider the application.
5300 lbs
3.23 gears
tight converter
29" tires
Tons of torque everywhere is what I need.
- Stu Harmon
Re: Long rams vs modern dual planes [Re: feets] #2621395
02/14/19 07:55 PM
02/14/19 07:55 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I still like to put my '60 NewYorker on the dyno once to see what it makes with the longram stroker under the hood.
Unfortunatly I still need to fix a driveline balance issue which starts at higher 90-100mph speeds because of the custom made driveshaft and sliding yoke.
It also has 3.23 and the stock stall convertor in the transmission.
Re: Long rams vs modern dual planes [Re: ScottSmith_Harms] #2621403
02/14/19 08:15 PM
02/14/19 08:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I had a couple ram engines rebuilt, one was a 1960 300F 413 engine with 63 300J short ram intakes and 3505s carbs. Stock stroke, stock compression, stock small valve heads with a very light pocket cleanup and a mild cam (similar to stock, went with a hyd roller) basically a stock rebuild but with lighter pistons and a warmer cam. I had it dyno'd and it performed well. TQ peak was at 3,600 rpm/351hp. Peak HP was 410 at 5,000, 421tq. It started falling off steadily past 5,000 rpm but the torque curve was very long and flat.
Being frank, I would be disappointed with those numbers, unless those are at the wheel. This is not directed at your motor, it just might be what it is combo. shock
Re: Long rams vs modern dual planes [Re: feets] #2621503
02/15/19 01:00 AM
02/15/19 01:00 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It was about what I expected with restrictive heads and a very mild cam. Not a monster but it had gobs of torque all over the place. Better heads and a more aggressive cam would have certainly upped the ante, my goal was a fairly simple stock style rebuild with a few miner modern upgrades (lighter pistons, roller cam, etc.) they were added more for reliability than an attempt to add HP.
If I were building a ram engine for ultimate performance I'd build a 440 stroker with good flowing heads and would use a much more aggressive cam. The intakes would likely be more for show than anything at that point because with a build like that the intakes would become the choking point, a single plane with a big 4 barrel or EFI would be the choice for max HP. If I were wanting the max from the intakes on a big inch engine I'd likely have them extrude honed, or cut them open from the underside for some good material removal to increase the plenum size to the max then weld them back together.
Cam card was the first cam I used before going to the roller. Specs were similar.
.02
Re: Long rams vs modern dual planes [Re: ScottSmith_Harms] #2621673
02/15/19 02:22 PM
02/15/19 02:22 PM
moparx Offline
moparx  Offline
as the intended intake[s] on my 33 humpback panel, the intakes are really, as scott said, just for show.
however, there will be good heads, bigger cam, higher stall converter, bigger gears, and cut and welded intakes.
i know the shortcomings of this intake, but the truck shouldn't weigh much over 2500 lbs, so this combination should be a fun deal. [i hope !]
beer
Re: Long rams vs modern dual planes [Re: feets] #2621691
02/15/19 02:52 PM
02/15/19 02:52 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I say go for it. I don't know if I would get into EFI but a set of long rams, a 509 cam, 2500+ stall converter and 3:91s would be a fun combo. Sure you could probably go faster with a good single plane but I guarantee you'll have a bigger smile on your face with those long tubes under the hood.
Re: Long rams vs modern dual planes [Re: Montclaire] #2621733
02/15/19 04:41 PM
02/15/19 04:41 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Stating the obvious? laugh2 laugh2 up
Re: Long rams vs modern dual planes [Re: feets] #2624049
02/21/19 01:36 AM
02/21/19 01:36 AM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
there was a set of long rams on the Portland and or Seattle crags list that wear already cut up for for fuel injection I dint see then now they wear up fore a long time and he wanted a lot foe the setup
