Kickdown - really needed?
#2620418
02/12/19 07:20 PM
02/12/19 07:20 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Hello folks,
transmission builder is finishing my 904 and I told him that I wasn't planning to use the kickdown. He was very upset and said it´s mandatory to use it.
Sorry my ignorance but is this true? Wha would be the issues of not using it?
Car will be street/strip...
Thanks,
1973 Brasilian Dart E100, boosted 390"
Re: Kickdown - really needed?
[Re: dart_73_br]
#2620422
02/12/19 07:24 PM
02/12/19 07:24 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
If you are not using a manual valve body then yes, it is mandatory otherwise front clutch failure will soon follow.
[Re: stumpy]
#2620472
02/12/19 08:23 PM
02/12/19 08:23 PM
Posts: 10,752 North Dakota
6PakBee
North Dakota
You don't have to use the TV linkage. But when the trans takes a dump prematurely, you'll wish you had.
[Re: 6PakBee]
#2620473
02/12/19 08:26 PM
02/12/19 08:26 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
You don't have to use the TV linkage. But when the trans takes a dump prematurely, you'll wish you had. Ha ha, exactly.
Scott
1969 Super Bee, 383/4 speed
[Re: StukaJU87]
#2620495
02/12/19 09:35 PM
02/12/19 09:35 PM
RapidRobert
The TF-2 kit gets good reviews & I think with an adjusted correctly kickdown & the largest cooler that will fit in front of the rad that you will be good to go.
[Re: dart_73_br]
#2620703
02/13/19 10:35 AM
02/13/19 10:35 AM
dart_73_br
Sao Paulo, Brazil
Ok, so looks like the concense it that I need it.. I just want to find the best way to do it as I don't have the linkages.. maybe cable is the easier way to go... There´s some old chrysler video here... 1971 Master Technician Service Conference https://youtu.be/KsfI9cFFPpg
[Re: BulletBob]
#2620722
02/13/19 11:53 AM
02/13/19 11:53 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I picked up on where Doc was going with it. He was being sarcastic about why the OP would be questioning his trans guy's intelligence. To BullBob and the rest ! ..., no sarcasm on my part !! ... jsta total BRAIN FADE on my part ! I misread it..... BIG TIME. BUTTT .. You CAN drive without KD linkage if you tie the lever back about a third of the way ..., if you drive it EZ. Do thatt - then put in a WANTED AD back in the swap meet section here and get the right OEM parts. I have never used a cable set up .... I’ve heard mixed reports about that setup.... FRANKENfurter ... I’ll EAT CAKE on this one !
