Dash/ trim paint flattening agent
#2620135
02/12/19 02:31 AM
02/12/19 02:31 AM
Posts: 138 Los Angeles, CA
71_dramaqueen
Los Angeles, CA
I have the metal dash to paint on a 71 challenger. I would like it to be close to the original but i can't find any cross reference to the book listed interior paint code of AB61DX9. It was not originally a black interior so i have no physical reference either. My shop just wants to use ppg hot rod black with a flattening agent in the clear but I have no idea what percentage to add.
I'm at the same impasse for the black on the grille . The repo came unpainted. I have seen 20% flattening agent suggested for this on another post.
Thoughts?
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: Dash/ trim paint flattening agent
[Re: 71_dramaqueen]
#2620816
02/13/19 03:41 PM
02/13/19 03:41 PM
Posts: 499 Brownstown, PA
FJR doc
Brownstown, PA
I had my 1970 Duster dash frame powder coated with a fine grain suede finish that was an exact match to the original texture and color. I'm sure that the cost of blasting and powder coating was less than buying a quart of the original paint.
[Re: FJR doc]
#2620836
02/13/19 03:58 PM
02/13/19 03:58 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
I had my 1970 Duster dash frame powder coated with a fine grain suede finish that was an exact match to the original texture and color. I'm sure that the cost of blasting and powder coating was less than buying a quart of the original paint. $199 a pint.... pint was plenty
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: FJR doc]
#2620845
02/13/19 04:13 PM
02/13/19 04:13 PM
JMCFAN
New Mexico
My dash blasting and powder coating cost me $68 in 2013 nice! cheap
[Re: 71_dramaqueen]
#2620979
02/13/19 09:49 PM
02/13/19 09:49 PM
Posts: 12,053 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you are going for any semblance of originality, base coat, clear coat will never look the same as the old single stage.
You really need to find a single stage paint. Or the powder coating sounds interesting.
Master, again and still
