Re: 383 Valve Covers
[Re: 6bblgt]
#2620088
02/12/19 12:49 AM
02/12/19 12:49 AM
Posts: 1,164 Los Angeles, CA
JF_Moparts
Los Angeles, CA
did yours have studs or bolts on the outside corners & what's the SPD & plant of your RR - do you also have the Engine Assembly Date (EAD) off the pad by the distributor?
The outside corners have studs and the car was built in St. Louis. What does SPD stand for? I'd have to look up the EAD.
[Re: JF_Moparts]
#2620147
02/12/19 03:07 AM
02/12/19 03:07 AM
Posts: 6,224 JERSEY
RJS
JERSEY
The outside corners have studs and the car was built in St. Louis. What does SPD stand for? I'd have to look up the EAD. SPD Scheduled Production date
