73 Charger running NOW!!! All help appreciated
#2619920
02/11/19 06:19 PM
02/11/19 06:19 PM
Posts: 1,449 Martinsville, IN
cdwmotorsports
Martinsville, IN
https://www.dropbox.com/s/pcqefbefh9kuais/Video%20Feb%2011%2C%2014%2037%2033.mp4?dl=0
So it’s stated it’s carb cleaner not starting fluid I’m spraying in the carb to get it to fire.
This is a link to the video of what I’m dealing with right now. This 73 Charger was put away at least 10 years ago maybe 13 in the same state I have it right now. I know it has a vacuum cap missing on the metering block. I just put the FBO ignition on it today hoping that it would just fire up but all I get is the stuttering. I think I’m gonna pull the distributor cap and check the gap. The fuel pump is currently not running as I pulled the fuel line off it to ensure I don’t get any garbage in it. Any other ideas what I should look for?
eBay-cdwmotorsports
Re: 73 Charger won’t run, any help appreciated
[Re: cdwmotorsports]
#2619954
02/11/19 07:41 PM
02/11/19 07:41 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I'd suggest you change ALL the fuel in the car (gasoline goes bad in about 6 months) and go back to basics. Check your firing order, distributor rotation, cap/rotor/plugs. Best of Luck!
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
#2619976
02/11/19 08:32 PM
02/11/19 08:32 PM
cdwmotorsports
Martinsville, IN
I disconnected the fuel pump so it had no power. That was trying to run on straight carb cleaner. I didn’t even think about firing order. My parents let my ex brother in law jack with it so who knows what all isn’t right. Today I found the carb wasn’t bolted down.
eBay-cdwmotorsports
[Re: Fat_Mike]
#2620010
02/11/19 09:52 PM
02/11/19 09:52 PM
RapidRobert
I'd fill the carb bowl with (fresh) gas & run the pump inlet into a can of (fresh) gas & cap the carb nipple & I would preoil it after all this time & oil the cyls. I'm assuming it ran when parked so I would disable the starter (pull the yellow wire at the starter relay) & see if your connections are correct & everything is being fed in "crank" & "run" that should be. I'm assuming the dist has been moved so confirm basic timeing (15 BTDC is good)
[Re: RapidRobert]
#2620029
02/11/19 10:46 PM
02/11/19 10:46 PM
cdwmotorsports
Martinsville, IN
I'd fill the carb bowl with (fresh) gas & run the pump inlet into a can of (fresh) gas & cap the carb nipple & I would preoil it after all this time & oil the cyls. I'm assuming it ran when parked so I would disable the starter (pull the yellow wire at the starter relay) & see if your connections are correct & everything is being fed in "crank" & "run" that should be. I'm assuming the dist has been moved so confirm basic timeing (15 BTDC is good) It did not run when parked. My ex brother in law drove it, f-Ed it up and assured my parents he could fix it. He didn’t fix it and it has sat 10-13 years in a barn untouched. When I got it off the trailer after buying it from my parents and dragging it home I replaced the battery, ignition box and coil (now FBO stuff), and bypassed the ballast resistor. I bought new fuel filters and fuel line to ensure it’s not got fuel issues too, those have not been put on and I didn’t have the fuel pump turned on to avoid junking the carb, pump or regulator.
eBay-cdwmotorsports
#2620060
02/11/19 11:53 PM
02/11/19 11:53 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
It may be wrong to assume that you have oil in, and an oil filter on the motor? Spin the oil pump to prime the oil system.
I'd bring #1 up on compression and make sure it didn't jump the timing chain. Pull the plugs ans put a little oil into each cylinder, then spin the motor over with the starter. Bring # 1 back up on compression, install new plugs, and be sure the ignition wires are connected to the proper cylinders, in the proper rotation, and in the proper position. Check for spark. If you have compression, spark at the right place at the right time, all you should need is fuel, use gas. Fill the carb float bowl and try to start it. Gene
[Re: poorboy]
#2620070
02/12/19 12:13 AM
02/12/19 12:13 AM
cdwmotorsports
Martinsville, IN
I'd bring #1 up on compression and make sure it didn't jump the timing chain. Pull the plugs ans put a little oil into each cylinder, then spin the motor over with the starter. Bring # 1 back up on compression, install new plugs, and be sure the ignition wires are connected to the proper cylinders, in the proper rotation, and in the proper position. Check for spark. If you have compression, spark at the right place at the right time, all you should need is fuel, use gas. Fill the carb float bowl and try to start it. Gene Why would you assume it doesn’t have oil or a filter? 30 years of messing with cars, it has oil.
eBay-cdwmotorsports
#2620114
02/12/19 01:38 AM
02/12/19 01:38 AM
RapidRobert
I may have missed something but I would start from scratch & change oil/filter & drill prime it. oil the cyls. check/clean plugs. confirm the ign connections (while you are priming, good opportunity to spin the dist by hand & see if it sparks at the plug wires). fill the carb bowl. gas to pump inlet. clean large cables/terminals (including ground paths) for good cranking. static time at 15 BTDC compression. cap the open carb nipple. EDIT & get the crank on #6 TDC compression & preoil then go CCW 3/4 of a turn (to #8 TDC compression) & preoil again to oil both heads. easiest is get rotor at #8 before you even pull the dist then preoil there then come forward CW till the marks are at TDC on the tab (3/4 turn) at #6 TDC compression & preoil again
[Re: SattyNoCar]
#2620139
02/12/19 02:38 AM
02/12/19 02:38 AM
cdwmotorsports
Martinsville, IN
Why? What's wrong with the stock ignition?
The stock ignition was all junk replacement parts bought from autozone or some other crap box auto parts store! Because my ex BIL is a cheapskate and doesn’t ever do anything right.
eBay-cdwmotorsports
#2620216
02/12/19 12:03 PM
02/12/19 12:03 PM
Posts: 16,819 Between Houston & Galveston TX
SattyNoCar
The stock ignition was all junk replacement parts bought from autozone or some other crap box auto parts store! Because my ex BIL is a cheapskate and doesn’t ever do anything right. Is it installed correctly? IE: did you wire it up correctly? Installing a new ignition system just because the old one had 'crap' parts on it was kinda stupid. Nothing wrong with the stock electronic ignition, 'crap' parts or not. I'd be willing to bet the not starting issue lies right here.
[Re: stumpy]
#2620328
02/12/19 05:11 PM
02/12/19 05:11 PM
cdwmotorsports
Martinsville, IN
The stock ignition was all junk replacement parts bought from autozone or some other crap box auto parts store! Because my ex BIL is a cheapskate and doesn’t ever do anything right. Is it installed correctly? IE: did you wire it up correctly? Installing a new ignition system just because the old one had 'crap' parts on it was kinda stupid. Nothing wrong with the stock electronic ignition, 'crap' parts or not. I'd be willing to bet the not starting issue lies right here. Crap parts that have kept Mopars running for years? Satilite73- I'm not sure what you're saying I removed a box coil and ballast resistor and replaced them with a box coil and ballast resistor. I'm gonna go ahead and restate it since I'm pretty sure you didn't read it up top the starting issue is a ten year old problem not a new issue Stumpy- I'm not opposed to those parts if they were original MoPar stuff but they aren't they are made by some no name company that had them made in some god forsaken country by cheap labor.
eBay-cdwmotorsports
#2620356
02/12/19 05:47 PM
02/12/19 05:47 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Air, fuel, ignition, and compression, in the right amounts, at the right time. That is all that required for an engine to start and then run.
I'd try gas instead of carb cleaner. Fill the fuel bowls, pump the pedal, fire it up. It is starts, it will run until the bowl is sucked dry, which may be about a minute or less. If that happens, then clean the tank and fuel line and hook it up so it will pump fuel.
[Re: TC@HP2]
#2620485
02/12/19 09:02 PM
02/12/19 09:02 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
I'd try gas instead of carb cleaner. Fill the fuel bowls, pump the pedal, fire it up. It is starts, it will run until the bowl is sucked dry, which may be about a minute or less. If that happens, then clean the tank and fuel line and hook it up so it will pump fuel. Hell starter fluid vs carb cleaner..... carb cleaner is not fuel...
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
#2620546
02/12/19 10:58 PM
02/12/19 10:58 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
Did you already establish the timing chain was OK or not?
