Mopar Performance P3690933 #2619878
02/11/19 04:38 PM
02/11/19 04:38 PM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
where is the best place to buy Mopar Performance P3690933 valve springs ?? or do you guys know of a spring that is the same only cheaper ??
Re: Mopar Performance P3690933 [Re: HEMI472] #2619904
02/11/19 05:36 PM
02/11/19 05:36 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mancini has historically had the cheapest price on that part number.
That said, it's still a little high for what you're getting.
The equivalent from somewhere like PAC should be cheaper yet.
Re: Mopar Performance P3690933 [Re: HEMI472] #2619929
02/11/19 06:39 PM
02/11/19 06:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Other than replacing the old springs on an OE or restored 426 Hemi and I wanted it to remain “correct”, I cant imagine any way I’d bother with those springs....... especially for what I see places selling them for.
Eh...... just looked on Mancini.
$9.95/ea........ not horrible.
Re: Mopar Performance P3690933 [Re: HEMI472] #2619973
02/11/19 08:19 PM
02/11/19 08:19 PM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
fast68plymouth what spring can I use to replace them ?? they are bone stock 1967 915 heads and the guy don't want to take them off motor to do machine work he just wants to to change valve spring and seals with no trouble. 933s is whats on the motor and I think it has around 480 lift cam thanks
Re: Mopar Performance P3690933 [Re: HEMI472] #2619982
02/11/19 08:38 PM
02/11/19 08:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
In a situation like that, I agree the path of least resistance is to just replace what’s there.
In the long run, they aren’t “that much” more money than something else that may require some other work around issues, which could(likely) be a PITA to do in the car.
Just spend the $160 and be done with it.
Re: Mopar Performance P3690933 [Re: HEMI472] #2620076
02/12/19 12:23 AM
02/12/19 12:23 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
why replace them if they are real 933 springs ?
my 440 was built in 1986 with the 933 springs with a cam of 490" lift
last season i was runing 12.5 at 110 regulary 3700 lb cuda .
they are verry good springs !
Re: Mopar Performance P3690933 [Re: HEMI472] #2620247
02/12/19 01:28 PM
02/12/19 01:28 PM
begood Offline
begood  Offline
I have a set that is NOS, that I will never use. I'll sell them to you for $100 shipped.
THERE IS NO SUCH THING, AS TOO MUCH HORSEPOWER
Re: Mopar Performance P3690933 [Re: HEMI472] #2620297
02/12/19 03:58 PM
02/12/19 03:58 PM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
begood I sent you a pm I will buy them thanks Ed
Re: Mopar Performance P3690933 [Re: HEMI472] #2620344
02/12/19 05:29 PM
02/12/19 05:29 PM
begood Offline
begood  Offline
I answered.
Re: Mopar Performance P3690933 [Re: HEMI472] #2623004
02/18/19 06:19 PM
02/18/19 06:19 PM
begood Offline
begood  Offline
HEMI472 clear out your PMs so I can send you a message.
Re: Mopar Performance P3690933 [Re: HEMI472] #2623021
02/18/19 07:01 PM
02/18/19 07:01 PM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
ok
Re: Mopar Performance P3690933 [Re: HEMI472] #2626206
02/26/19 05:05 AM
02/26/19 05:05 AM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
thanks begood they came today very happy and great person to deal with thank you Ed
Re: Mopar Performance P3690933 [Re: HEMI472] #2626234
02/26/19 11:01 AM
02/26/19 11:01 AM
begood Offline
begood  Offline
You're very welcome sir.
