Re: 2012 Durango RT oil in coolant
[Re: Jambbii]
#2624294
02/21/19 04:12 PM
02/21/19 04:12 PM
Posts: 560 Mesa , Az
Jambbii
Mesa , Az
A little update. I dropped the new cylinder head off at the machine shop and they showed me the video of the pressure test. The leak is by one of the lower pushrod holes. There is seepage through what looks like the casting grains if that makes any sense. There are no visible cracks.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Jambbii]
#2624318
02/21/19 05:06 PM
02/21/19 05:06 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
That makes sense, air pocket in the casting process.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2630732
03/09/19 11:42 AM
03/09/19 11:42 AM
Jambbii
Mesa , Az
Got this thing back together a week ago. It is a beast! Going to need headers and a tune soon. Something else I noticed is that a one of the lobe on the cam had a "chip" on the top of it where it was wearing. The lifter had some shining spots on it but nothing that had started scoring and it still rolled smoothly. Obviously if I had not have the cylinder head issue with would have gone out at some point....
Does anyone have a real answer why hemis eat lifters/cams? I do realize the needle bearings go but is it a material or production defect? I have done some searching and have come up with earlier production of the mds lifters doing this but there is no definitive answer as far as specific part numbers go (at least I didn't find anything). From what I can tell all of the new mds hemis use the same lifter and they have superseded a fair amount of previous lifter models.
[Re: Jambbii]
#2630793
03/09/19 01:54 PM
03/09/19 01:54 PM
Posts: 12,492 Kalispell Mt.
HotRodDave
Kalispell Mt.
So what cam, heads, milled how much if any... did you end up putting in?
As for the lifter, I'm guessing bean counters had something to do with the lifters falling apart, I never seen a 6.1 or 08 back 5.7 do it, something changed in 09+.
[Re: HotRodDave]
#2631070
03/10/19 11:26 AM
03/10/19 11:26 AM
Jambbii
Mesa , Az
I did exactly what you said. Had to grab another new head (drivers side eagle), 6.4 srt cam and springs ,new lifters and took 20 thousandths off. I used all ARP hardware for the hell of it. Any idea what the compression is after taking 20 off the heads? I wanted to have the bad head cut apart to see what the heck happened but there was a $150 core charge so I sent it back. It amazed me how easy this engine was to work on. Almost makes me want to put one in my Challenger.
[Re: WO23Coronet]
#2631326
03/11/19 06:16 AM
03/11/19 06:16 AM
ric3xrt
Trumbauersville PA
I've read conflicting reports on this but do you have to notch the cylinders with 6.4 heads on a 5.7 or will the valves clear? I thought I saw a build on here where a 6.4 head will clear a 5.7 bore (close but it does) but several "experts" on sone Gen 3 groups on FB howl that they don't. Oh and if the heads are coming off may as well put headers on as well (it's very easy to spend your money lol) side track, my experience with 6.4 heads on 5.7 blocks....stock 3.917 bore.....too close needs to be notched if the factory bores are just slightly off you can have an issue, , 3.937 bore they'll clear ..but best results notch it, don't need much.
[Re: Jambbii]
#2631327
03/11/19 06:22 AM
03/11/19 06:22 AM
ric3xrt
Trumbauersville PA
I think it has to do with the VVT cam lobes, 53022064BD (cars) duration intake 258* exhaust 288* / lift intake .472 exhaust .461 53022314AD (trucks)duration intake/exhaust 290* / lift intake .472 exhaust .460Automatic 5.7 186/208 (4 lobes are actually 205 on the exhaust for MDS) 499/493 (4 lobes have 486 lift on the exhaust for MDS) 115LSA 103ICL Not sure why but I think when the oil is cut to the MDS lifters there not enough residual oil to keep the roller lubed and the aggressive nature of the MDS lobe puts more stress on the roller....so it's a design flaw in my opinion...…..Lifters don't fail on the Non VVT cams.
[Re: WO23Coronet]
#2631366
03/11/19 09:18 AM
03/11/19 09:18 AM
Jambbii
Mesa , Az
So you’re running a stock tune with the 6.4 cam? Yup, for now. Waiting on headers (which are freaking expensive for this thing) before a tune. Runs fine....
[Re: ric3xrt]
#2631367
03/11/19 09:22 AM
03/11/19 09:22 AM
Jambbii
Mesa , Az
I think it has to do with the VVT cam lobes, 53022064BD (cars) duration intake 258* exhaust 288* / lift intake .472 exhaust .461 53022314AD (trucks)duration intake/exhaust 290* / lift intake .472 exhaust .460Automatic 5.7 186/208 (4 lobes are actually 205 on the exhaust for MDS) 499/493 (4 lobes have 486 lift on the exhaust for MDS) 115LSA 103ICL Not sure why but I think when the oil is cut to the MDS lifters there not enough residual oil to keep the roller lubed and the aggressive nature of the MDS lobe puts more stress on the roller....so it's a design flaw in my opinion...…..Lifters don't fail on the Non VVT cams. That makes sense. It looks like there has been a few iterations of lifters since the intro of MDS. I wonder if they have actually solved the issue with new vehicles.
[Re: Jambbii]
#2631448
03/11/19 01:13 PM
03/11/19 01:13 PM
HotRodDave
Kalispell Mt.
It is definately NOT because of the MDS, I have done many on 3/4 ton trucks including one I bought in tuscon with a flat cam and drove all the way here (2000 miles) and fixed. I still have that cam laying here, is there a way to prove what it came out of?
[Re: Jambbii]
#2631450
03/11/19 01:20 PM
03/11/19 01:20 PM
HotRodDave
Kalispell Mt.
The non MDS engine has full pressurized lube to the lifter body all the time
[Re: HotRodDave]
#2631454
03/11/19 01:28 PM
03/11/19 01:28 PM
ric3xrt
Trumbauersville PA
The non MDS engine has full pressurized lube to the lifter body all the time Correct,... you have 2500 NON MDS ? what year is it ?
[Re: ric3xrt]
#2631459
03/11/19 01:49 PM
03/11/19 01:49 PM
HotRodDave
Kalispell Mt.
09. It's the one I put the 6.4 SRT cam in.
[Re: HotRodDave]
#2631530
03/11/19 05:48 PM
03/11/19 05:48 PM
Jambbii
Mesa , Az
It is definately NOT because of the MDS, I have done many on 3/4 ton trucks including one I bought in tuscon with a flat cam and drove all the way here (2000 miles) and fixed. I still have that cam laying here, is there a way to prove what it came out of? Interesting. Where they all 5.7s?
[Re: Jambbii]
#2631540
03/11/19 06:08 PM
03/11/19 06:08 PM
HotRodDave
Kalispell Mt.
2009 through about 2012 5.7 is what I have seen and as low as 101,000 mileson up to my 2011 with almost 300,000 miles. Never an earlier one, no 6.1, 6.2< or 6.4 either flavor. Anything newer is probably ending up at the dealer so I don't know if it's a continuing issue or if they fixed it yet. I am looking for a decent 1/2 ton 4 door 09+ I can buy cheap and swap in my 6.4.
[Re: HotRodDave]
#2631699
03/12/19 07:04 AM
03/12/19 07:04 AM
ric3xrt
Trumbauersville PA
the issue happens with high idle hours, most common is when Idle hours exceeded 7% of total hours. my youngest stepsister works for AutoAssure warranty company and according to their records 90% of all lifter claims are 5.7s with idle hours between 7% and 9% of total hours usage the other 10 are 6.4s with Idle usage above 5%. The Dodge dealership my nephew works at does 2-3 a month same common thread High idle hours ...my brother is a fleet mechanic for a local Municipality, they do 1-2 pursuit charger week and 1-5 1500 2-3 2500 rams a month, keep in mind that when the engine goes in to ECO mod the computer registers that as idle hours,
Dave that 09 2500 you did , did it have solenoids or plugs?
