69 woodgrain wheel hardware #2618108
02/07/19 02:41 AM
02/07/19 02:41 AM
New Jersey
69Chrgr Offline OP
69Chrgr  Offline OP
New Jersey
I have a complete 69 woodgrain wheel. wheel, adapter, horn contact switch, and button. I have no harware other than the steering shaft nut. Is the hardware special? Year one has with there repro wheels it says " must use original hardware" I'm not sure if there are insulators? or anything else special. Any help would be appreciated on what it consists of and where to get it.
Duane
Re: 69 woodgrain wheel hardware [Re: 69Chrgr] #2618222
02/07/19 01:17 PM
02/07/19 01:17 PM
New York
rarefish Offline
rarefish  Offline
New York
To me it sounds like you have all the parts. You will need the attaching screws for the horn switch and adapter.
Re: 69 woodgrain wheel hardware [Re: rarefish] #2618233
02/07/19 01:24 PM
02/07/19 01:24 PM
New Jersey
69Chrgr Offline OP
69Chrgr  Offline OP
New Jersey
Im just wondering if the switch screws have some kind of insulator bushing?
Re: 69 woodgrain wheel hardware [Re: 69Chrgr] #2618236
02/07/19 01:30 PM
02/07/19 01:30 PM
moparx Offline
moparx  Offline
wouldn't the insulators be in the horn switch itself ? kind of going by memory on my charger's wood wheel.
beer
Re: 69 woodgrain wheel hardware [Re: 69Chrgr] #2618284
02/07/19 02:57 PM
02/07/19 02:57 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Duane
U have everything you need. Just add normal hardware, no insulators required.
Re: 69 woodgrain wheel hardware [Re: 69Chrgr] #2618387
02/07/19 06:22 PM
02/07/19 06:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1) The switch screws to the adapter that holds the horn pad.
2) The switch screws to the wheel.
As stated no insulators on this wheel
You need a washer for the large but.
Re: 69 woodgrain wheel hardware [Re: NANKET] #2618693
02/08/19 03:28 PM
02/08/19 03:28 PM
New Jersey
69Chrgr Offline OP
69Chrgr  Offline OP
New Jersey
Thank you!
