1995 3.9 V6 Magnum,stall/no start -UPDATE/(FIXED!)
#2617022
02/04/19 09:00 PM
02/04/19 09:00 PM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
My B1500 van quit on me last night,it is a 3.9 Magnum V6, port EFI.It started to miisfire and pop through the air cleaner and stalled.I got it to run again,had to feather the throttle,luckily I was less than a mile from home and made it. Well no start today,I checked fuel pressure it seems ok @ 40 psi and flow volume is good.It has spark but will not fire,even attempted starting fluid. I checed the timing mark vs distributor rotor alignment and it is good.I thought timing chain possibly but the van only has 40k on it. Spark at the plug is ok,maybe weak.Spark at coil term is very good.Is it possible for a crank sensor,or even the cam sensor/dist pickup to fail and still allow a spark? This is OBD I,Im going to see if my neighboring shop has a scanner that will check cranking rpm if it is possible.When my trucks crank sensor failed it was no spark at all.Just wondering if anyone has had a similar experience on a Magnum engine,V6 or V8. Thanks,RT
UPDATE: While the van had spark,it ended up being a weak ignition coil.The primary/secondary resistance seemed to vary when checked,I swapped a good coil on and it fired up.This wa sfinally after checking inputs using an OBD1 scanner,all sensors looked good,no codes.Checked fuel pressure and volume,even disconnected the fuel line and ran fuel from an alternate source thinking the fuel may have been bad.Did a compression test as well,checked TDC vs distributor rotor alignment...All the parameters were there,just one was lazy! Thanks for all the input. RT
Re: 1995 3.9 V6 Magnum,stall/no start
[Re: RTSrunner]
#2617123
02/05/19 12:34 AM
02/05/19 12:34 AM
RTSrunner
Pittsburgh,PA
Thanks Gene,The plugs/cap/rotor/wires all have about 5k on them,just over a year old.I do have spark at the plug end of the wire,but have yet to pull a plug out,I will do that tomorrow.The ignition rotor had some dust on it from the carbon center electrode but no tracking evidence.I won't rule out fuel yet but it looked ok when I checked pump volume to a glass jar.It would not fire on starting fluid,I will definitely pull the plugs tomorrow.Maybe bad fuel washed them out.I will report back! Ron
[Re: RTSrunner]
#2617250
02/05/19 11:55 AM
02/05/19 11:55 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
basically you need to do some investigating.
Run the computer codes, the Key on/off routine should work on the OBDI system. that will give you an area to look.
If there are no codes then you will have to verify fuel/spark/air and see which is failing.
No one is going to be able to remote view the answer without more info,
[Re: RTSrunner]
#2617263
02/05/19 12:27 PM
02/05/19 12:27 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
IIRc we had some at the shop that the drive gear wore out.Threw timing off.One guy played with one for 2 days before we found the dist drive gear was bad.They had a problem with them as we had more than one.Rocky
Chrysler Firepower
[Re: SattyNoCar]
#2621480
02/15/19 12:14 AM
02/15/19 12:14 AM
RTSrunner
Pittsburgh,PA
Glad you got it running! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif) I had rough running issues with my '93 Dakota with the 3.9 that were coil related. I installed a new (stock) one, problem came back within a few days. Just for giggles, I threw on an MSD coil and no more problem. Its been on there for 3 yrs now. In addition to eliminating the original problem, I noticed the truck started quicker and got more consistent MPG. Thanks,it was an odd one,I was betting on bad fuel from the way it stalled out.The coil resistance was a tad high,both primary and secondary.Easy fix once I figured it out! RT
