Re: Drag front shocks
[Re: fowl play]
#2616390
02/03/19 12:39 PM
02/03/19 12:39 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
What front shocks are you running? A body small block 10.60 cars. Think my car could use some help. Reasonably priced if possible. First, I think a couple of videos of the launch would help determine if there is a problem, or room for improvement, in the front suspension, rear suspension, weight transfer, hook. Almost anything in any car can be improved. Does it need it? Let's go to the instant replay first... I see you're new to this site. Don't let all of the cross bickering get to you. You will find a thousand different ways to do things, depending on circumstances. Note all of the replies, group them together. determine which solutions might work best for you and why. There are thousands of years of experience on this site. Some very accurate, precise info. And some stuff from left field. Then there are some that just like to stir the pot. You will see a pattern on your own, soon enough. Welcome. Glad to have you on board. You will be going 10.0's soon enough with the help on this site.
[Re: sgcuda]
#2616395
02/03/19 12:48 PM
02/03/19 12:48 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
What front shocks are you running? A body small block 10.60 cars. Think my car could use some help. Reasonably priced if possible. First, I think a couple of videos of the launch would help determine if there is a problem, or room for improvement, in the front suspension, rear suspension, weight transfer, hook. Almost anything in any car can be improved. Does it need it? Let's go to the instant replay first... I see you're new to this site. Don't let all of the cross bickering get to you. You will find a thousand different ways to do things, depending on circumstances. Note all of the replies, group them together. determine which solutions might work best for you and why. There are thousands of years of experience on this site. Some very accurate, precise info. And some stuff from left field. Then there are some that just like to stir the pot. You will see a pattern on your own, soon enough. Welcome. Glad to have you on board. You will be going 10.0's soon enough with the help on this site. . He has been a member since 2007 I'm just saying
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: fowl play]
#2616465
02/03/19 03:44 PM
02/03/19 03:44 PM
Posts: 11,550 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Mid 10 sec. car has outgrown the 1960s technology 90/10 shock and would benefit from an upgrade I would think. You really only need or want the car to pitch rotate as much as it needs to help out the rear suspension. You're not making so much power that it doesn't need some help, unless it has big tires on it.
[Re: fowl play]
#2616782
02/04/19 11:19 AM
02/04/19 11:19 AM
Posts: 10,021 MN
JERICOGTX
MN
Buy a shock that allows you to grow in the future.
69 GTX
68 Road Runner
[Re: fowl play]
#2616790
02/04/19 11:44 AM
02/04/19 11:44 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
For the money, the Viking DA shocks are hard to beat. I'm very happy w/ the set on my cuda. Did some chassis tuning this weekend at the track and they responded VERY well.
[Re: JACK1440]
#2616919
02/04/19 03:58 PM
02/04/19 03:58 PM
Posts: 4,457 Washington
madscientist
Washington
I went to Vikings DA last year and have struggled to get them to work with the super stock springs. But... that's just my lack of testing. Gotta find that sweet spot There may not be a sweet spot with that spring and shock combo. Think about what you are doing with the spring and how the shock is not helping. That spring is designed to arc and cause separation and smash the tire into the ground. For that to happen, the shock can have almost little to no rebound dampening. The shock you are using at its least amount of extension is too much dampening to allow the spring to work. IMHO, you're better off going to a split mono spring and a set of Asassin bars. I like them better than the Calverts for the adjustability. I also prefer the slide-a-links better than Calverts for street/strip stuff. With what you are doing, you are beating against the air. You want to make the shock control a spring that functions by not being controlled. Just my thoughts on your situation.
[Re: fowl play]
#2616924
02/04/19 04:10 PM
02/04/19 04:10 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
After smashing so many oil pans I went back to stock Monroe matics front shocks. $30. bucks each. Out of control wheelies with 90-10's was ridiculous . Now 10.30 at 130mph. is good enough with the wheels just up a little at launch. Could a multi adjustable be better? Not from my wallets view.
[Re: rowin4]
#2616929
02/04/19 04:42 PM
02/04/19 04:42 PM
madscientist
Washington
After smashing so many oil pans I went back to stock Monroe matics front shocks. $30. bucks each. Out of control wheelies with 90-10's was ridiculous . Now 10.30 at 130mph. is good enough with the wheels just up a little at launch. Could a multi adjustable be better? Not from my wallets view. You need DA shocks way more than you think. A stick DEMANDS a good shock.
[Re: fowl play]
#2616940
02/04/19 05:03 PM
02/04/19 05:03 PM
rowin4
So what will the DA shock do , I have weight transfer , I don't want the wheels in the air to shift , been there done that transmission carnage. It caries the wheels out 40-50 feet now , down for the shift then back up again.
[Re: rowin4]
#2616962
02/04/19 05:46 PM
02/04/19 05:46 PM
madscientist
Washington
So what will the DA shock do , I have weight transfer , I don't want the wheels in the air to shift , been there done that transmission carnage. It caries the wheels out 40-50 feet now , down for the shift then back up again. Nothing. Sounds like you have it tuned perfect.
[Re: BradH]
#2617028
02/04/19 09:12 PM
02/04/19 09:12 PM
Posts: 9,831 MI, usa
dvw
MI, usa
The only reason why I'm OK w/ having S-A front dampers is because they're the QA-1 'R' series that have a very firm fixed compression circuit and a wide range of adjustment on the rebound (extension) circuit. For my nose-heavy junk, a stiff compression setting is kind of a given, so the primary changes of the front suspension are the ride height & available travel from the static ride height and the rate of extension off the line. I ran these same shocks on my 64 Belvedere before swapping to double adjustable Afcos. Ran them 2 clicks from full stiff. They were actually pretty good. Got the car below 1.3 60ft with them. Doug
[Re: dvw]
#2617179
02/05/19 04:06 AM
02/05/19 04:06 AM
Posts: 6,137 Melbourne , Australia
LA360
Buy the best DA shock you can afford. Not everone wants to, or has the money for Santhuffs. Strange Eng, Viking or AFCO's are more wallet friendly, all can be rebuilt and re-valved down the track.
Alan Jones
[Re: J_BODY]
#2617223
02/05/19 10:47 AM
02/05/19 10:47 AM
Posts: 10,021 MN
JERICOGTX
MN
Jay, did you order the bounce control also?
69 GTX
68 Road Runner
[Re: Cab_Burge]
#2617246
02/05/19 11:49 AM
02/05/19 11:49 AM
BradH
Its really to bad that Koni doesn't still sell the SPA speed sensing front shocks any more No great loss: they aren't very good compared to what's available now since they had limited extension adjustment and no compression adjustment (and were extremely soft on compression, which is why they recommended not using them on big-block cars). I had a set for B/E bodies where one stopped working. Koni said they could still rebuild them, but the cost was at least twice what I paid for the set originally. I got tired of them taking up shelf space about a year ago and sent 'em to the scrap heap. BTW, any good hydraulic valving design is "speed sensitive". A progressive shim stack allows for light damping at slow shaft speeds and increased damping at faster speeds. This goes back to the fact that "traditional" car dampers are freakin' archaic compared to what any production motocrosser made in the last 30 years came with.
[Re: dvw]
#2617248
02/05/19 11:54 AM
02/05/19 11:54 AM
BradH
The only reason why I'm OK w/ having S-A front dampers is because they're the QA-1 'R' series that have a very firm fixed compression circuit and a wide range of adjustment on the rebound (extension) circuit. For my nose-heavy junk, a stiff compression setting is kind of a given, so the primary changes of the front suspension are the ride height & available travel from the static ride height and the rate of extension off the line. I ran these same shocks on my 64 Belvedere before swapping to double adjustable Afcos. Ran them 2 clicks from full stiff. They were actually pretty good. Got the car below 1.3 60ft with them. Doug I'll need to tighten up mine a few clicks next time the car makes it to the track. IIRC, they were on the lightest extension setting and I could hear & feel the suspension bang up against the bumpers. If I can slow 'em down a tad w/o hurting the 60-ft, that'll be an improvement.
[Re: BradH]
#2617264
02/05/19 12:30 PM
02/05/19 12:30 PM
Posts: 10,021 MN
JERICOGTX
MN
The only reason why I'm OK w/ having S-A front dampers is because they're the QA-1 'R' series that have a very firm fixed compression circuit and a wide range of adjustment on the rebound (extension) circuit. For my nose-heavy junk, a stiff compression setting is kind of a given, so the primary changes of the front suspension are the ride height & available travel from the static ride height and the rate of extension off the line. I ran these same shocks on my 64 Belvedere before swapping to double adjustable Afcos. Ran them 2 clicks from full stiff. They were actually pretty good. Got the car below 1.3 60ft with them. Doug I'll need to tighten up mine a few clicks next time the car makes it to the track. IIRC, they were on the lightest extension setting and I could hear & feel the suspension bang up against the bumpers. If I can slow 'em down a tad w/o hurting the 60-ft, that'll be an improvement. This is where slow motion video, and a good person filming is valuable.
69 GTX
68 Road Runner
