Re: Factory Showdown and SS/AH allowed in Comp
[Re: theraif]
#2615461
02/01/19 04:53 AM
02/01/19 04:53 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
I haven't raced at a NHRA division or National event in the last ten years so Comp Eliminator may now be short on racers as I seem to remember a race last year in National dragster that had only 3 cars in Comp Eliminator It use to be a 16 or 32 car field only and not all racers qualified to race at those races that exceeded the field size I can remember 50 + cars enter for a 16 car feild 130 stockers, 130+ S/G and so on You needed to be at least .55 under to qualify, then the instant comp adjustment if you ran more than .58 under would make your car obsolete from one run A lot of those racers where holding .85+ under their indexes to make sure they wouldn't get factor out of the race before the money runs
[Re: theraif]
#2615512
02/01/19 11:31 AM
02/01/19 11:31 AM
Posts: 4,213 New York
polyspheric
New York
NHRA clutching desperately at vanishing market.
Boffin Emeritus
[Re: theraif]
#2615552
02/01/19 12:48 PM
02/01/19 12:48 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
this is because comp is a dyeing class. I think at the columbus divisional we had like 15 car in comp. Comp now has personal indexes to help get some more people to show up and be competitive.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: theraif]
#2615587
02/01/19 02:30 PM
02/01/19 02:30 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A lot of the Hemi guys don't like bracket racing. The FS and AH guys like to race first to the finish wins, hence the popularity of the Shootouts. I believe Welker and Comella have run their cars in Comp in A/SM last year. This year they have their own class. The 8.75 index is not going to allow them to be competitive though, if they have to run SS/AH legal..
[Re: theraif]
#2615600
02/01/19 03:01 PM
02/01/19 03:01 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I looked through some qualifying sheets from last year.
The Comp fields are dwindling big time. I saw one event that had a field of 3, another was 5.
I don’t see how it’s feasible to keep that going.
By comparison, at the same event that had 3 cars in Comp, there were 42 in Stock.
[Re: theraif]
#2615613
02/01/19 03:27 PM
02/01/19 03:27 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
CIC will always be in affect in Comp. Don't think the AH guys will care given the index the FSS guys that may be a different story. Im sure it has a lot to do with input from the big 3 getting those cars more exposure. As for AH I think its already been mentioned those guys for the most part don't wanna bracket race, so this would give them another option.
[Re: theraif]
#2615620
02/01/19 03:57 PM
02/01/19 03:57 PM
fast68plymouth
So. Burlington, Vt.
I thought if you went quicker than .6 under the index, the index for the class got changed before the next pass.
[Re: fast68plymouth]
#2615623
02/01/19 04:00 PM
02/01/19 04:00 PM
Posts: 4,103 Yes
sixpakdodge
Yes
I thought if you went quicker than .6 under the index, the index for the class got changed before the next pass. That is for the "personal" index, and does not apply until the following event. It is also only based upon runs in eliminations. They still grade the overall index based upon all the passes made in that class for the year, at year end. If you ran 8.05 on the 8.75 index at Orlando this weekend, it would change your "personal" index to 8.65 for the next race you entered. The index for everyone else would remain 8.75.
[Re: theraif]
#2615624
02/01/19 04:02 PM
02/01/19 04:02 PM
Al_Alguire
Las Vegas
Yep there is a personal and a class index. Not sure how successful it has been as most the guys running comp want to be THE fast guy, but its been in place for a few years now.
[Re: theraif]
#2615625
02/01/19 04:05 PM
02/01/19 04:05 PM
fast68plymouth
So. Burlington, Vt.
From what I just read(don’t know if it’s current or not), the personal index hit starts at .50 under. The permanent hits start at .610 under, and are on a sliding scale. https://www.dragzine.com/features/car-fe...ion-eliminator/ Edit....... that appears to be out of date. The new rule seems to be personal hit at .610, permanent hit at .710 during eliminations.
[Re: theraif]
#2615671
02/01/19 06:22 PM
02/01/19 06:22 PM
fast68plymouth
So. Burlington, Vt.
The way I read it, the cars must remain in ss and fs legal trim........ so raising the cr wouldn’t be legal.
[Re: theraif]
#2615708
02/01/19 08:33 PM
02/01/19 08:33 PM
fast68plymouth
So. Burlington, Vt.
The way I read what I believe is the current incarnation of the CIC........ you want to run(as good as) .609 under........ and have that be quick enough to get it done.
I looked through the Hemi challenge times for Indy and the Dutch....... I didn’t see any 8.20’s.
[Re: theraif]
#2615719
02/01/19 09:05 PM
02/01/19 09:05 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you run over .50 under in eliminations, you get hit with the amount that you went under for the rest of the event. Over .50 under that and you get hit again. It's not permanent until you go .60 under. They are always tinkering with the CIC, but I believe that's correct.
Qualifying doesn't count. At the last race in Pomona, 23 cars showed up, #1 qualifier went .72 under and the #21 guy was .488. So a Hemi car in AH/SM, the new class designation, going .35 under at 8.40, is going to need some help.
