Re: Original or repro fendertag RM21V0A
[Re: moparfan53]
#2615503
02/01/19 11:02 AM
02/01/19 11:02 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
For anyone who wants to compare the one above to the one posted by the op. Not sure if it is MANDATORY that every fender tag on a particular mopar left the assembly plant with an inspection mark. My gut says it is legit due to the appearance of pitting from corrosion on the bottom side.. Usually reproductions are nice and smooth everywhere on the tag...... my
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#2615540
02/01/19 12:22 PM
02/01/19 12:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
For anyone who wants to compare the one above to the one posted by the op. Not sure if it is MANDATORY that every fender tag on a particular mopar left the assembly plant with an inspection mark. My gut says it is legit due to the appearance of pitting from corrosion on the bottom side.. Usually reproductions are nice and smooth everywhere on the tag...... my Don't be fooled, I actually have a die plate stamp that embosses random pits on to fender tags before they're stamped, one comment from someone that I aged a repro tag for commented "now that tag looks really OLD"....
[Re: DAYCLONA]
#2615578
02/01/19 02:15 PM
02/01/19 02:15 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
For anyone who wants to compare the one above to the one posted by the op. Not sure if it is MANDATORY that every fender tag on a particular mopar left the assembly plant with an inspection mark. My gut says it is legit due to the appearance of pitting from corrosion on the bottom side.. Usually reproductions are nice and smooth everywhere on the tag...... my Don't be fooled, I actually have a die plate stamp that embosses random pits on to fender tags before they're stamped, one comment from someone that I aged a repro tag for commented "now that tag looks really OLD".... You mean like this !!
