Page 2 of 4 1 2 3 4
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614418
01/30/19 02:06 AM
01/30/19 02:06 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
I thought 4.75 stroke was the largest you could put in a standard Block.
Kevin
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614425
01/30/19 02:21 AM
01/30/19 02:21 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Correct, I thought you said you had a raised cam block, if so 5" crank will fit.
My standard height block fits a 4-3/4 crank nicely. A couple cam lobes though are at .060 from hitting the rods.
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614443
01/30/19 03:30 AM
01/30/19 03:30 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Ron Flood at Cedar Machine in North Branch , Mn. would be a very good choice.
He may well be Jericho's one man shop......he is one of the best around and relatively unknown by most measures.
But he breathes precision and has a lot of Hemi experience.
He has the fixtures and tooling for most blocks.
And is a stand up individual.
It would be worth a call.
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614516
01/30/19 11:52 AM
01/30/19 11:52 AM
New York
polyspheric Offline
polyspheric  Offline
New York
A screw blower is how you get power without the destructive RPM that chews up your valve gear.
Boffin Emeritus
Re: Gen 2 Hemi Bracket Motor? [Re: tubtar] #2614523
01/30/19 12:15 PM
01/30/19 12:15 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I do not, and will not go through Ron. My second choice (if I had to) would be Line's. They do very nice work, and Lance is as hard of a worker as you will find. I have a few friends that go through Lance, and all have been happy with his work.
69 GTX 68 Road Runner
Re: Gen 2 Hemi Bracket Motor? [Re: quickd100] #2614526
01/30/19 12:25 PM
01/30/19 12:25 PM
ONTARIO,CANADA
ONTARIO,CANADA
Yes I’ve got a raised cam KB Block and always thought that the largest stroke was 4.75.
Kevin
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614642
01/30/19 05:03 PM
01/30/19 05:03 PM
an8sec70cuda Offline
I think sticking w/ the single 4 Indy manifold is best for what you're describing. Add a fogger and have some fun w/ it when you want. Bracket race it NA otherwise.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614691
01/30/19 06:37 PM
01/30/19 06:37 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
It sounds like to me you want the WOW factor when someone looks at the motor or the car and a blower will give you that, there is a Duster in town like that. If your car was going to run at the track only a 605 with two carbs on a good intake and lots of Compression and good gas and I would pick a Hogan intake can make you a ton of horse power for an easy 9 second pass. Most of the racers around me run NSS. All run in the 8s and some have run as low as 8.20 in a Super Stock A Body that came apart at just over 1100ft doing this. This car had the special set of Aluminum heads from FHO. I was wondering how much spring pressure are you going to run and what valves and what valve seats. Most of these guys have bigger that a 750 lift cam, all but one guy and he runs 890s with the lift you have. I was going to say you will have to check things on the motor each year but since it snows early were you are you will have all Winter to do that.
1971 HEMI E BODY REGISTRY
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614781
01/30/19 10:01 PM
01/30/19 10:01 PM
ONTARIO,CANADA
ONTARIO,CANADA
The heads have Copper alloy valve seats, titanium valves and not sure on spring pressure
Kevin
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614835
01/30/19 11:59 PM
01/30/19 11:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My Keith Black stage 7 compucam roller [Crane] is a 750 lift that requires 606 lbs. open 220 lbs. closed set at 2"
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614858
01/31/19 01:03 AM
01/31/19 01:03 AM
ONTARIO,CANADA
ONTARIO,CANADA
When I got the cam from comp cams they sent all necessary parts to assemble heads.
MCH put them together
Kevin
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614894
01/31/19 03:12 AM
01/31/19 03:12 AM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
Kevin
Kevin, I've never done anything with a raised cam, so I'm no expert. But guys are building 4.75" stroke hemis without the raised cam. I would have thought you could go 5 " with a raised cam?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614905
01/31/19 06:42 AM
01/31/19 06:42 AM
ONTARIO,CANADA
ONTARIO,CANADA
It’s to bad I didn’t know that before I started the build, I would of ordered a 5” stroke crank.
But I’ll run what I have and make the best of it.
Plus I know if I go big boost it’ll handle the power.
Kevin
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2614917
01/31/19 08:35 AM
01/31/19 08:35 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
With the cam raised in the block I believe it requires a special cam core and also a belt drive.
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2615088
01/31/19 03:06 PM
01/31/19 03:06 PM
rowin4 Offline
rowin4  Offline
That's correct on the special cam , 48* and belt drive. I think someone makes a gear drive also. Any crank over the 4.5 gets hard to find a lot more expensive and longer lead times.
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2615104
01/31/19 03:16 PM
01/31/19 03:16 PM
ONTARIO,CANADA
ONTARIO,CANADA
KB makes a gear drive, Jessel makes a belt drive and I never knew anything about a special cam.
Ken Black never mentioned it when I ordered my block.
I’ll need to shot KB a email and find out for sure
Thanks for the info guys
Kevin
Re: Gen 2 Hemi Bracket Motor? [Re: 604 Hemi GTX] #2615114
01/31/19 03:29 PM
01/31/19 03:29 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
gen 2 hemis is not a bracket motor
Re: Gen 2 Hemi Bracket Motor? [Re: dart games] #2615130
01/31/19 03:51 PM
01/31/19 03:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Sure they are. I can't run with these heads up guys anymore. So a bracket weenie I have become.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Gen 2 Hemi Bracket Motor? [Re: dart games] #2615132
01/31/19 03:51 PM
01/31/19 03:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Why not?
Re: Gen 2 Hemi Bracket Motor? [Re: dart games] #2615157
01/31/19 04:13 PM
01/31/19 04:13 PM
Minnesota
Minnesota
iagree
If it's a 14 second bracket. thumbs grin
Page 2 of 4 1 2 3 4
