Re: I hate to beg.... Summit Racing
[Re: DusterKid]
#2615724
02/01/19 09:22 PM
02/01/19 09:22 PM
BradH
Summit has code ALWAYS
$11 off $100 $26 off $250 $51 off $500 Jeg's added this today: Save $10 off $75, $20 off $150, or $30 off your $300 order! Use Code: WINLIGHT
[Re: BradH]
#2616091
02/02/19 06:55 PM
02/02/19 06:55 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
$11 off $100 $26 off $250 $51 off $500 Jeg's added this today: Save $10 off $75, $20 off $150, or $30 off your $300 order! Use Code: WINLIGHT Jegs actually listed it 1st lol... not that it matters, but both still active.
[Re: Jeepmon]
#2616137
02/02/19 08:01 PM
02/02/19 08:01 PM
Posts: 10,044 MN
JERICOGTX
MN
You can not use the discount code with the ProShop discount, unless you call Summit, and have to practically beg them for it. Not worth the time actually.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2616308
02/03/19 04:26 AM
02/03/19 04:26 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
You can not use the discount code with the ProShop discount, unless you call Summit, and have to practically beg them for it. Not worth the time actually. Thats probably it...
[Re: Jeepmon]
#2616448
02/03/19 03:07 PM
02/03/19 03:07 PM
Posts: 16,531 On the run…
BloFish
On the run…
No mention of weight. Are they supposed to be light, or just expensive 😆
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2616728
02/04/19 03:21 AM
02/04/19 03:21 AM
Jeepmon
Sunnyvale, CA
No mention of weight. Are they supposed to be light, or just expensive 😆 I called and asked Weld... the customer service guy didnt know the weight. My Centerlines are not all that heavy and the new Weld has double beadlock with all those steel bolts, so I seriously doubt its a weight savings... So if I had to guess, I would say its the cool factor.. Maybe someone else can chime in
[Re: Silver70]
#2616995
02/04/19 07:42 PM
02/04/19 07:42 PM
BradH
$11 off $100 $26 off $250 $51 off $500 Jeg's added this today: Save $10 off $75, $20 off $150, or $30 off your $300 order! Use Code: WINLIGHT Jegs actually listed it 1st lol... not that it matters, but both still active. Jeg's changed their offer today: Spring Is Coming! Save $50 Off $500, $75 Off $750, $100 Off $1000 Use Code: SPRING I didn't take advantage of any of them, but would have been more likely to have used the original Jeg's code than the new one, simply because I wasn't (and am not) in the market to spend $500+ to save a few bucks.
