Re: 318 LM and poly cranks and Poly cylinder walls
[Re: Retroboy]
#2612510
01/26/19 12:34 PM
01/26/19 12:34 PM
Posts: 4,210 New York
polyspheric
New York
Poly only has conventional 6 bolt (LA) crank flange 1962-66, earlier is 8 bolt.
Boffin Emeritus
[Re: Twostick]
#2612554
01/26/19 02:03 PM
01/26/19 02:03 PM
Posts: 22,697 Bitopia
jcc
Bitopia
My understanding is a poly can be bored .100" without issue. A sonic check would confirm for you.
Kevin And lighten the anchor while at it.
