Re: golf cart / pit vehicle
[Re: rowin4]
#2614848
01/31/19 12:37 AM
01/31/19 12:37 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Electric the only way to go.. Costco sells the six volt batteries for around eighty bucks each.. mine have lasted about five years I have never had problems with it starting never have I had to clean out the carburetor or fuel tank only charge and go..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: w2stroker]
#2614863
01/31/19 01:11 AM
01/31/19 01:11 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I love my Gas cart myself. Fuel once in a while and check the oil. Starts every time and no battery charger. I have an older Yamaha and it still runs like new. Gas my 2cents
6.50 @105.26
[Re: w2stroker]
#2614869
01/31/19 01:25 AM
01/31/19 01:25 AM
Posts: 4,590 Motor City
6PKRTSE
Motor City
I have a gas club car with a windshield (handy when cold out), lights, rear seat and radio as mentioned for hearing the announcers at the track. Also, has push bar for my car that attaches in the chute mount and a tow hook on the rear for pulling other people's cars also.
My buddies electric cart has a solar panel on the roof and keeps it charged all season long.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: w2stroker]
#2617095
02/04/19 11:39 PM
02/04/19 11:39 PM
Posts: 422 montana
BANDIT
montana
I sold my gas cart a few years back, it worked fine, painted it with some leftover FC7 from challenger and put Cragars on it. Bought a 72 volt GEM cause it’s unique. It’s street legal with limits, lays rubber and looks cool. Time will tell on the batteries.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2617189
02/05/19 04:51 AM
02/05/19 04:51 AM
Posts: 10,187 A Red State
SNK-EYZ
A Red State
I finally got one this last fall, a gas powered Yamaha G1 (two stroke). I couldn't pass it up for the price of $500. The guy said had been running, but I doubt it ever ran recently. After checking the compression which was about 10 psi I decided it needed a top end kit (piston, cylinder, etc). The kit was $225 and after installing it and a few other parts ($275 in all the parts total) I have a good running gas golf cart. I've pick up some deals on new tires for it too, which I was actually working on installing a few minutes ago in the garage. All in all I have less than $900 in a good running gas powered golf cart so I'm happy. Here's a pic I took just after getting it running. At some point I'll probably paint it and make it a bench seat and add a rear seat.
[Re: WHITEDART]
#2617214
02/05/19 10:29 AM
02/05/19 10:29 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Electric the only way to go.. Costco sells the six volt batteries for around eighty bucks each.. mine have lasted about five years I have never had problems with it starting never have I had to clean out the carburetor or fuel tank only charge and go.. Straight up Cali boy Prius envy going on right here!!
[Re: w2stroker]
#2617218
02/05/19 10:38 AM
02/05/19 10:38 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I work for a Battery Distributor. The GEM cars are not common around here but the original batteries seem to last a long time. It is expensive to replace the batteries in them but we sell a few sets a year, some people downgrade to a standard wet battery due to cost and some people pony up the money to keep an AGM battery in them. We don't see much trouble from them either way, which speaks for the owner using them properly and/or a good charging system.
People with electric golf carts always blame problems on the batteries but it is usually lack of use and/or improper care.
68 Barracuda Formula S 340
[Re: w2stroker]
#2617237
02/05/19 11:29 AM
02/05/19 11:29 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
We have an electric EZGo cart and like it. I do not tow a car with it, just to get around at the track. Had it 10 years, changed batteries in it once. A good friend of mine used to sell and modify/lift golf carts. His opinion was gas powered carts are like everything else w/ a small gas engine on it, sometimes they can be a PITA. He preferred the electric carts. One of my best friends and racing buddy had a gas cart and he liked it a lot better than the electric he had prior. If either is in good shape, I think you'll be happy with whichever you choose.
[Re: Brian Hafliger]
#2617267
02/05/19 12:38 PM
02/05/19 12:38 PM
Posts: 259 n.c.
geo.
n.c.
I vote a used side by side...plenty of power to pull the car anywhere, not much bigger than a golf cart, and more top speed if necessary! We considered a side by side, but because they're considered more as "off road" vehicles they come with very aggressive tires. Not good if you ever drive on a lawn you care about! Now I might look at a golf course maintenance-type vehicle. They come with tires designed to not tear up the lawn, and have very handy beds for "stuff" and trailer hitch too!
